dhoser Posted February 19, 2016 Share Posted February 19, 2016 If anyone has a U.S. version of the Master 3S floppy I would be interested in purchasing it if it has the power supply as well. TIA Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted March 10, 2017 Share Posted March 10, 2017 If anyone has a U.S. version of the Master 3S floppy I would be interested in purchasing it if it has the power supply as well. TIA You wouldn't happen to know the pinouts/power specs on this, would you? I just got one of these . . . without the power supply. Quote Link to comment Share on other sites More sharing options...
ijor Posted March 10, 2017 Share Posted March 10, 2017 PSU photo ... 1 Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted March 14, 2017 Share Posted March 14, 2017 PSU photo ... I got very happy about this post . . . . and then I got very sad: Quote Link to comment Share on other sites More sharing options...
ijor Posted March 14, 2017 Share Posted March 14, 2017 Seems your is a different revision, probably older. Your uses the same connector as original Atari drives (SF 314/354), so chances it uses the same or equivalent power supply. Open the enclosure, the power signals might be labelled on the board. Or there might be a standard internal floppy connector inside and then you should be able to deduce the pinout. Quote Link to comment Share on other sites More sharing options...
