Drive!
Lumi
[Make sure you download the files attached to this post, as they are the most recent. I only have permission to edit this post.]
Hello, everyone!
I've been developing an Atari 2600 homebrew game for the last little while, and I think it's nearing completion, but I'd like to get more feedback before I call it final. It's a 4K, single player paddle game with SaveKey/AtariVox support.
post-44583-0-09793900-1457458441_thumb.png post-44583-0-83159000-1464648192_thumb.png
Plot:
In this game, you are an explorer from the year 2050. Much of the world's rainforests have been logged, leading to the discovery of a large temple constructed by ancient civilizations eons ago. You are among the first to be allowed to explore it.
The entrance to this temple is across a long stone bridge, which you have chosen to drive across. Inside the temple you find a golden idol on a stone pedestal. Although you are supposed to leave everything you find, your greed gets the better of you and you remove the idol from where it has sat for thousands of years.
Suddenly, the ground begins to shake. Bricks fall from the ceiling. Maybe this wasn't such a good idea! You run outside just as the entrance caves in. As you get in your car and drive away, you realize that the bridge's supports have dislodged and it's all collapsing behind you! There's no time to think - just drive!
In this game, you must use the paddle controllers to steer your car left and right, avoiding obstacles in your path while collecting treasures.
When you touch a treasure, you will get 1500 points and it will be added to your collection (the yellow dots on the left side of the status bar). You can have up to 5 treasures in your collection at a time. At any point, you can press the paddle controller's trigger to "burn" a treasure, giving you the energy to jump a short distance over any obstacles in your path. Any treasures you have left when your game ends will grant you an extra 1500 points. The game is won upon reaching 99,999 points.
There are different kinds of treasures. Some of them will grant you unique powers:
post-44583-0-87321600-1457458910.png Gold coin: Does not grant any powers, is only worth points.
post-44583-0-66216500-1457458918.png Necklace: Gives you an extra life (the red dots on the right side of the status bar). You can have up to four lives at a time.
post-44583-0-30472500-1457458934.png Jar: Lets you pass through all barriers for a few seconds.
post-44583-0-24946100-1457458939.png Statuette: Lets you jump as much as you want with no penalties for a few seconds.
The game will speed up when you get enough points. There will be a transition period where the game stops generating obstacles briefly, and the speed-up will occur while there are no obstacles on the screen.
The difficulty switches toggle certain features. I highly recommend setting both to A for the full experience (Note: Stella sets both to B by default):
- The left difficulty switch will make obstacles farther apart (B) or closer together (A).
- The right difficulty switch turns moving obstacles off (B) or on (A).
If the game feels too easy for you, enable Speed Freak mode! Simply press the game select switch at any point. When the title screen's background is red, this mode is enabled.
Finally, the most important feature: if you press the paddle trigger while you have no treasures in your collection, you can honk the horn! Wow!
As previously mentioned, the SaveKey and AtariVox are fully compatible for saving high scores (although there are no AtariVox speech functions). It saves unique high scores for Normal and Speed Freak modes. If you want to clear your high scores, press the game select and game reset switches at the same time.
So, that's everything you need to know! Feel free to give feedback. However, there is very little free space in the ROM, so I probably won't be able to implement any extensive new features. Sorry about that.
[Please make sure you download the following files]
Drive! v1.5.3 NTSC.bin
Drive! v1.5.3 PAL.bin
Edited by Lumi
  • Like 15
Thanks, everyone!
Nice job ! I love the music, did you use your own music routine ?
Yes, actually! I designed the music routine to play only that one song, so it's easy on RAM and ROM space, but isn't very useful if you want other songs.
I noticed a lot of jittering though my paddles were cleaned quite recently. Did someone else noticed that too (PAL60) ?
Hmm. I don't know why it would be jittering, I hope it doesn't have anything to do with it being PAL60. In any case, here's a standard PAL version that's been speed optimized (except for the sound effects):
Drive! v1.3 PAL.bin
Edited by Lumi
Thanks for this rom ! It doesn't jitter anymore ! Well except for some rare times but they are for sure caused by my paddles. It's now far more playable en enjoyable, great :thumbsup:
I haven't ckecked how many scanlines you're firing, but just to let you know, I'm afraid this is not the right amount for pal 50, as I get artifacts on the top of the screen.
Drive! PAL
Edited by Cambouis de l'Atari
Hmmm.
According to Stella the PAL version is 312 lines, so I have no idea why there would be artifacts.
I'm mainly guessing at this point because I can't test it, but try this. I may have misunderstood how PAL sets interpret the VBLANK signal.
Drive! v1.3.1 PAL.bin
Hey, me again ;)
I distella'd your rom. I modified the start of frame in a more traditional way : 2 > vsync, 3 wsync then 0 > vsync. To keep the count, I removed 3 following wsync and 0 > vsync, between F061 and F0BD
In your code, vsync is asked at scanline 276 and closed at 312, which is probably in the visible section of the screen.
Your game is now perfect on a PAL console ! :)
Drive! PAL 50 ok
Drive! PAL 50.bin
Hey, me again ;)
Really? Vsync is kept on for that long? That's not how I programmed it! (But I guess mistakes happen when you don't comment your code thoroughly...)
I'll take another look at it to see where it went wrong. Unfortunately my laptop had to go in for repairs, along with the most recent version of the source code, so I can't check it at the moment. But thank you for taking the time to fix my mistake! I'm very happy to know PAL users can play it without jitter or artifacts now :)
By the way, just a question... I'm not saying it will, but if this game were sold as a cartridge in this form, would anyone actually buy it?
Edited by Lumi
Hello. I added both NTSC versions to my Harmony cart and can't get the game to start. I see the main menu and the music plays (very nice by the way), but I can't start the game. :?
Should it not work on the Harmony?
Hmm, it should definitely work on a Harmony.
Two ideas:
1) Are you using paddle controllers? This game is like Kaboom! or Circus Atari in that it can't be played with a joystick.
2) Are you trying to start the game with the game reset switch? That switch is used to re-boot the game. You have to use the left paddle's fire button to progress past the title screen. It also has to be plugged into the left controller port (you used to be able to plug it into either port, but it caused issues with the AtariVox features).
Edited by Lumi
This game has me hooked. The crash sound scares me and make me jittery.
HS save is working fine via AtariVox.
Definitely has that "one more try" appeal. - Thanks.
Did I say, one more try? Gosh, 30,050 is hard to beat. Hats off to chavert!
  • 2 weeks later...
  • 1 month later...
As of version 1.4, I think I'm ready to call this game finished! I can't find any bugs to fix, the NTSC60 and PAL50 versions run at the same speed, and there isn't really any space left to add new features.
Unless anyone finds serious bugs, I think I can officially call this the final version!
A big thank you to everyone to helped me and offered advice and suggestions. I learned a lot, and I'm quite happy with the final product! :)
Very good game Lumi!
But for some reason, Drive v1.3 played thru Stella 4.0 will let me use my computer mouse as a controller (paddle) but not on v1.2 or v1.4.
Thank you! :)
Hmm... you might need to manually switch to paddle mode. Try pressing tab while the game is running > Game Properties > Controller. Then set P0 Controller to Paddles in Left Port. Then you'll have to close the ROM and reopen it for the changes to take effect.
(Also, if you want to be able to save your high scores, set P1 Controller to AtariVox in Right Port.)
