Two-in-the-Belfry Posted March 24, 2016 Share Posted March 24, 2016 Does anyone know the best way to hook up the Model 1 for RGB output? I was thinking of ordering this SCART cable and using this SCART to component converter to hook the system up to my CRT. Is there a better way to do it/a better SCART to component converter (a lot of reviews say they have a problem getting sound from it). I know an XRGB Mini Framemeister is often recommended, but I can't really spend $300+ on something like that at this time. Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted March 24, 2016 Share Posted March 24, 2016 Genesis natively puts out RGB. Get a scart cable, JPN adaptor, and plug it into an XRGB Frammeister. VOILA Quote Link to comment Share on other sites More sharing options...
+Black_Tiger Posted March 29, 2016 Share Posted March 29, 2016 I use that component transcoder and it works pretty good as long as you have the correct c-sync or non-c-sync scart cable for the console. In most cases you want the c-sync version. The best place I've found for scart cables and framemeister accessories is: http://www.retrogamingcables.co.uk/ But if you're just using it on a normal non-HD crt, then you don't need a framemeister at all. Just hook your c-sync Euro scart cable from your Genesis to the transcoder and component cables from the transcoder to your TV. Quote Link to comment Share on other sites More sharing options...
