Internetronic Posted April 13, 2016 Share Posted April 13, 2016 Hello, I'd like to figure out what the best way to dial a BBS from my Enhanced Apple //e would be. This is what I currently have: * A Lantronix UDS-10 * An Uthernet II card * A DB-25M to DB-25M * A DB-25 to RS-232 * (Obviously) A few working Ethernet cords * A Super Serial Card in my Apple //e * A Raspberry Pi 2 and Raspberry Pi 3 Thanks! 1 Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted April 13, 2016 Share Posted April 13, 2016 find proterm for the apple 2 you can dial into a bbs with that with ibm emulation in the terminal setup. i use proterm with applewin emulater and my lantronix device works fine. Quote Link to comment Share on other sites More sharing options...
Internetronic Posted April 13, 2016 Author Share Posted April 13, 2016 Oh, I also have a DB-25 to USB. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted April 13, 2016 Share Posted April 13, 2016 Oh, I also have a DB-25 to USB. Just a heads up on the serial/USB interface. In the past I've heard of people not being able to get their UDS-10's to work with modern day PC's or Mac's... it has ALWAYS been due to cheap Chinese units not being up to the task. However there is one unit that to my knowledge has NEVER FAILED to perform, and that's the Keyspan. So IF you find you have an issue, this might be something to consider. Some information from their website: Certified: Microsoft WHQL approved Compatible with Apple Sandbox applications High Speed: Supports 230 Kbps - twice the speed of a built in serial port Detachable Cable: Use adapter with any USB cable (up to 5 meters long) LED: Shows adapter status and data activity Plug & Play: Appears as standard COM port Mobile: Easy to carry - weighs just 2 oz. Bus Powered: No external power adapter required Analytic Tools: Includes Windows line monitor and data trace software Field Upgrade: Easy to update over time with free software downloads Easy Expansion: Supports use of multiple adapters on one PC Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Typical Applications Connect older serial devices such as mice, keyboards, modems, GPS devices, barcode scanners, point-of-sale devices, lab equipment, programmable logic controllers (PLCs), digital signage and AV equipment to your new Mac or PC. System Requirements See "Support" tab for drivers. Windows: An available USB port Compatible with Windows 98, 98 SE, Me, 2000, XP, 2003 Server, Vista, 7, 2008 Server R2, 8, 2012 Server, 2012 Server R2, and 8.1. Compatible with 32- and 64-bit versions. Macintosh: An available USB port Compatible with Mac OS 8.6 through 9.x, Mac OS X 10.2.8 through 10.10. Compatible with 32- and 64-bit versions. Compatible with Apple Sandbox applications Quote Link to comment Share on other sites More sharing options...
Grimakis Posted April 20, 2016 Share Posted April 20, 2016 Very Easy. I do it with my SDS-1101 from Lantronix.http://www.lantronix.com/wp-content/uploads/pdf/UDS10-UDS100_UG.pdfDownload the guide for your UDS-10 and look at around page 30, it explains which settings work for Modem Mode. Then I recommend creating a copy of Modem.MGR using ADTPro. In Modem.MGR, you can configure it to work with a Generic 2400 Baud modem. Then you need to configure the Lantronix as 2400 Baud. Then enable half-duplex mode in Modem.MGR which basically turns on Local Echo, so you can see what you are typing. Now the way you can connect to a BBS from here is simply typing ATDT xxx.xxx.xxx.xxx:nnnnWhere x represents the IP, and n represents the port. I would look for BBS that have Telnet web addresses and use your PC to find the IP address. I occasionally use: http://ping.eu/nslookup/ my favorite bbs is borderlinebbs.dyndns.org port:6400 At the time of my writing this, the IP is: 75.82.9.195 So in Modem.Mgr you would type ATDT 75.82.9.195:6400 The Lantronix should do the rest. Make sure you are hooked up with a Modem Cable, and your SSC is set up for Modem. If you have any other questions, you can PM me. ~George Quote Link to comment Share on other sites More sharing options...
desiv Posted April 22, 2016 Share Posted April 22, 2016 Yeah, another happy Lantronix user. Although I've only used it with my Amiga, but modem emulation mode works fine.... Even played a game of Firepower with someone in Georgia... (Make sure your router/switch supports 10M if your Lantronix is a 10M device...) desiv Quote Link to comment Share on other sites More sharing options...
Internetronic Posted April 24, 2016 Author Share Posted April 24, 2016 Thanks for all of the replies! I actually got it working using my Pi 3 and tcpser along with MODEM.MGR. 1 Quote Link to comment Share on other sites More sharing options...
