16-bit add less 1
I need to add two 16-bit integers (let's call them A and B; A is signed, B isn't) and get the result, less 1. Sure I can do a 16-bit decrement on the result of the addition, but 16-bit DECs require a branch instruction (for MSB roll-over) and I'm trying to save cycles. I considered using a 256 byte look up table of the index value less 1, but this comes unstuck when then LSB is zero, since element 0 is $FF:
	ldx a
	lda Less1Tab,x
	clc
	adc b
	sta c
	lda a+1
	adc b+1
	sta c+1
	rts
Less1Tab
	.byte $FF
?Value = $0
	.rept 255
	.byte ?Value
?Value = ?Value+1
	.endr
Making the first element of the LUT $FF seemed like a great idea until I realized it sets the carry flag when subtracting 1 from 0, messing up the MSB. Any more complex and it'll be easier to DEC the result. Any ingenious ideas?
I don't see why the branch is an issue. This is the first straight optimized way that comes to my mind
clc
lda a
adc b
tax "+2
lda a+1
adc b+1
cpx #0 "+2
beq not_0 "+2/+3
sbc #1 "+2/0, C==1 because X>0
not_0
dex "+2
stx c
sta c+1
sums up to 9/10 additional cycles
A is signed, B is not (which is just to say B is never >32767). So result may be negative.
Just tested Mapa's modified version of Peter's code and it works nicely, of course. I'll take the three cycle saving, and it looks less clumsy than sticking a DEW after the addition. ;)
Thanks for your help. I thought this quite an interesting little problem. The chosen solution also has the advantage that the second set of coordinates are left pre-loaded in the A and X registers, meaning I can fall straight into the first signed 16 bit clipping comparison without re-loading anything. :)
	.proc Clip
	clc
	lda cx1
	adc Width
	tax
	lda cx1+1
	adc Width+1
	cpx #1
	sbc #0
	sta cx2+1
	dex
	stx cx2
	cpx XMin		; is cx2 < XMin?
	sbc XMin+1
	svc
	eor #$80
	bmi NoDraw
	clc
	lda cy1
	adc Height
	tax
	lda cy1+1
	adc Height+1
	cpx #1
	sbc #0
	sta cy2+1
	dex
	stx cy2
	cpx YMin		; is cy2 < YMin?
	sbc YMin+1
	svc
	eor #$80
	bmi NoDraw
	cmps16 YMax cy1		; is YMax < cy?
	bmi NoDraw
	cmps16 XMax cx1		; is XMax < cx?
NoDraw
	rts
	.endp
Edited by flashjazzcat
  • Like 5
