peteym5 Posted April 23, 2016 Share Posted April 23, 2016 (edited) I have a 130XE that the video starts going bad after being on for a few minutes. First I see an interference pattern start running through the screen, then the chroma shifts from its standard blue screen to cyan/green. I hooked it up to several different displays with the Chroma/Luma to S-Video split cable, all getting the same results. I have no devices that I can hook direct RF-Out to since everything I have is modern digital devices. It is likely not the cable because if it was, I would not be seeing anything immediately. I just swapped out the power supply and for some reason it looks more normal and stayed. Someone made me this custom power supply many many years ago, but it seems like the standard Atari made one works better. I had the same power supply hooked up to an 800XL and the screen totally went blank after about 5 minutes, until I turned the power off and back on. Edited April 23, 2016 by peteym5 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted April 23, 2016 Share Posted April 23, 2016 Definitely sounds like a power supply issue. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted May 4, 2016 Share Posted May 4, 2016 definately the power supply, please don't cook Atari.... they are much yummier when when fresh not crispy! Quote Link to comment Share on other sites More sharing options...
