decle Posted April 24, 2016 Share Posted April 24, 2016 (edited) Hey, I posted this on the main forum, but it was suggested it might also be of interest here. I have put together an emulator of the Science Fair Microcomputer Trainer for the Intellivision. This is a programmable electronics kit from the mid 1980's based around the TMS-1100 4bit micro-controller. If you fancy trying it the ROM image and some technical details can be found on this thread: http://atariage.com/forums/topic/251791-nybl-a-science-fair-microcomputer-trainer-emulator/ Thanks, and apologies for double posting decle Edited May 14, 2017 by decle Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted April 25, 2016 Share Posted April 25, 2016 Hey, I posted this on the main forum, but it was suggested it might also be of interest here. I have put together an emulator of the Science Fair Microcomputer Trainer for the Intellivision. This is a programmable electronics kit from the mid 1980's based around the TMS-1100 4bit micro-controller. If you fancy trying it the ROM image and some technical details can be found on this thread: http://atariage.com/forums/topic/251791-nybl-a-science-fair-microcomputer-trainer-emulator/ Thanks, and apologies for double posting decle curious, what does nybl stand for? Quote Link to comment Share on other sites More sharing options...
carlsson Posted April 25, 2016 Share Posted April 25, 2016 (edited) Nybble (or nibble) is a computing term that refers to four bits, similar to how "byte" usually refers to eight bits. If you consider taking a nibble is half a bite, you see the analogy. In this case, it seems that "nybl" is a variant spelling of nybble, since the emulated system operates with 4-bit memory as far as I understand. Edited April 25, 2016 by carlsson Quote Link to comment Share on other sites More sharing options...
decle Posted April 25, 2016 Author Share Posted April 25, 2016 Nybble (or nibble) is a computing term that refers to four bits, similar to how "byte" usually refers to eight bits. If you consider taking a nibble is half a bite, you see the analogy. In this case, it seems that "nybl" is a variant spelling of nybble, since the emulated system operates with 4-bit memory as far as I understand. Yup, that's it. The TMS-1100 being emulated is a 4 bit processor. I quite liked the look of Nybl, similar to byte, and I thought it might have the same pronunciation as nibble. Quote Link to comment Share on other sites More sharing options...
carlsson Posted April 25, 2016 Share Posted April 25, 2016 Sorry for going a bit off-topic, but as I've come to understand there is a bit of bacon obsession here in the Intellivision section, I just wanted to point out there is a local pig farmer called Nibble. http://nibble.se/gardsgrisuppfodning/ Quote Link to comment Share on other sites More sharing options...
