Christophero Sly Posted April 25, 2016 Share Posted April 25, 2016 (edited) Atari Power Supply Adapter. Part # C014319 400,800,822,850,1010,1200XL Adapter tested with a multimeter; output is nominal. I don't have anyway to test the adapter under an actual load, however. $8 + 2 lb. shipping costs ($6 - $11). Shipping to Canada ~$16. Or make me an offer, if you wish. PM if interested. Edited April 26, 2016 by Christophero Sly Quote Link to comment Share on other sites More sharing options...
BillC Posted April 27, 2016 Share Posted April 27, 2016 This is the 15VA version, my 1980 400 came with one. Discontinued as it was too low in power output for many devices, the internal fuse blew in mine after a Mosaic 64K upgrade was installed in the 400. Works fine with an 850, probably with a 1010/1200XL, probably not with a 48K 800, and definitely not with an 810/1050/XF551. 1 Quote Link to comment Share on other sites More sharing options...
Christophero Sly Posted April 28, 2016 Author Share Posted April 28, 2016 This is the 15VA version, my 1980 400 came with one. Discontinued as it was too low in power output for many devices, the internal fuse blew in mine after a Mosaic 64K upgrade was installed in the 400. Works fine with an 850, probably with a 1010/1200XL, probably not with a 48K 800, and definitely not with an 810/1050/XF551. Thank you so much for this information. I wondered about the output. The voltage measured within specs on a multimeter, but it was on the low side. I wondered how it might perform under load. Do A8'ers generally avoid this adapter? Should I just pitch it? Quote Link to comment Share on other sites More sharing options...
Broderbund Posted April 29, 2016 Share Posted April 29, 2016 PM sent Quote Link to comment Share on other sites More sharing options...
