petit chou Posted April 27, 2016 Share Posted April 27, 2016 (edited) I am so confused. I am typing to compile a simple program (http://pastebin.com/wSdYfPAq) which appears to be causing IntyBASIC and as1600 to have a bit of a disagreement. I'll link the INCLUDEd file if needed -- it's just halfwidth alphabet data as a bunch of DATA statements with no execution. Anyway, IntyBASIC with the --jlp switch is processing it just fine: IntyBASIC compiler v1.2.5 Feb/16/2016 © 2014-2016 Oscar Toledo G. http://nanochess.org/ 4 used 8-bit variables of 228 available 76 used 16-bit variables of 8000 available Compilation finished ...but as1600 doesn't like what it's outputting and won't compile it: ERROR SUMMARY - ERRORS DETECTED 1 - WARNINGS 0 When I look in the .lst file that as1600 generates for the error, a few thousand lines in I see the following: 50F6 0283 033F MVI _color,R3 50F8 0284 033E MVI _screen,R4 CALL PRNUM16.l alphabet2.asm:3216: ERROR - undefined symbol PRNUM16.l 50FA 0004 0100 0000 50FD 0244 033E MVO R4,_screen Does anyone have any idea what's going on here? I'm still trying to learn IntyBASIC but I'm absolutely baffled here. Thanks in advance! Edited April 27, 2016 by petit chou Quote Link to comment Share on other sites More sharing options...
intvnut Posted April 27, 2016 Share Posted April 27, 2016 It appears you didn't close a PROCEDURE (WriteString), if I read your code correctly. 1 Quote Link to comment Share on other sites More sharing options...
petit chou Posted April 27, 2016 Author Share Posted April 27, 2016 Aha! Okay, easy fix - I'm surprised the compiler didn't complain about it though. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
freewheel Posted April 27, 2016 Share Posted April 27, 2016 Aha! Okay, easy fix - I'm surprised the compiler didn't complain about it though. Thanks! There are still many things the compiler doesn't complain about. Some is by design, some is just due to nanochess's time. You'll learn pretty quick what you can get away with. I'm surprised you aren't seeing a warning from this, though: DIM #TILES(4 * 18). IntyBASIC only allows 47 16-bit values, max. You're trying to define 72! 1 Quote Link to comment Share on other sites More sharing options...
+Tarzilla Posted April 27, 2016 Share Posted April 27, 2016 He said he was using the jlp switch... 2 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted April 27, 2016 Share Posted April 27, 2016 Aha! Okay, easy fix - I'm surprised the compiler didn't complain about it though. Thanks! I'll add a warning in next IntyBASIC version 1 Quote Link to comment Share on other sites More sharing options...
freewheel Posted April 28, 2016 Share Posted April 28, 2016 He said he was using the jlp switch... Duh. I didn't have my --eyes switch enabled. 4 Quote Link to comment Share on other sites More sharing options...
petit chou Posted April 28, 2016 Author Share Posted April 28, 2016 I'll add a warning in next IntyBASIC version You're awesome - thanks! 1 Quote Link to comment Share on other sites More sharing options...
