Need help with NES-001
Man I've opened up carts with actual rust on the contacts and the little grey eraser got EVERYTHING off. I've never had that fail to get anything to work.
In my experience, if you didn't actually open up the cart to clean it, you didn't do much of anything however else you did it.
I'll also say....I've gotten a bad brand new aftermarket connector (the plastic frame was actually not square), and then got an aftermarket connector which literally never fails. I tend to think a good new one beats one you boiled (I tried that too)
Anyone try the "Blinking Light Win"? I've heard good things about it and other than it being a very tight fit, it seems to be a good solution.
I have one, and it is a must have. It's easy to install and fixes the bad design of the original. I couldn't repair my original connector, even with the boil trick, and the aftermarket ones never last. The BLW should be like standard issue for an nes. Much better than trying to buy a modded toploader!
Not hard, it's a matter of finding a supplier of 36/72 pin card edge connector that has the right spacing and is angled to PCB. The NES board already have convenient solder spot when you remove the original NES connector so just wedge the new angled connector onto the edge and solder it on. You will need to build support under it so pushing the cart won't cause the connector to flex and snap off the board.
Great but seriously how hard would it be to make a right angle connector. I mean essentially turn the toaster into a top loader. Granted I would have to cut a whole in the top of the case but still.
The original pin connector does have right angle on it. It starts out flat then right angles up and then right angles back forward again. If you want to tinker, cut the connector and solder it to a game genie connector or similar.
I have a couple of front loader NES systems that I have messed with to make work better. For each one, I cut power to the 10NES lockout chip and installed a new 72 pin connector. When I reassembled them, for some reason the load tray didn't push down anymore, so essentially, you just put the cartridge straight in. Since the lockout chip is disabled, it works fine with the tray up. It works as well as my friend's top loader, and has better video output without extra modification. No need to hack the case up! Just clean the games, disable the lockout chip, make sure your connector is good, and you'll be fine.
You are reassembling the tray incorrectly. There is a plastic tab in the middle of the plastic tray that has to go under the main board. It wants to go above but you have to make it go below it.
Yeah, I figured I was somehow reassembling it wrong. I'd go back and fix it, but being able to just shove the game in and have it work is good enough for me!
http://atariage.com/forums/topic/198455-the-nes-toaster-toploader/
But according to this link I found yesterday that I already mentioned. He did not solder he just bent the connector upright. So it should not be hard to make or 3d printer connectors right just like he made? Or like they made the blinking light win or what ever it was called?
What does that gain? That would be purely cosmetic. That will have zero difference over how well the pin connector contacts pins and plays games. Maybe we got off track along the way but I was under the impression this thread was about making the nes play games better?
Well that is cosmetic. But if keep inserting and reinserting the games the pins wear out. But if I leave a game genie in and use that then the pins stay in place and don't wear out like my top loader which I shoved a genie into. Same for the toaster expect you can't leave the genie in. It comes out every time you take the game out. Except as in my video but that is ugly taping 2 genies together. This 2012 atariage mod by ATARITARD is so much better. It is upright so the genie stays in place and if it stops working you just remove it and add another genie. And the genie stays in place so the pins never wear out. The pins stay bent in one direction. So it always makes contact.
