1 Meg Super AMS Discussion Thread
Omega-TI
OK I have a new question? I would like to build a RS232 loop back plug so I can run diagnostic software  and get a response back from rs232. I have seen diagrams in the past 5 to 8 years ago but have never taken time to build one. If you know of a site that has diagram to construct one I would like to have a link to it. Thanks in advance. I think I even saw one that had led's on it to signal traffic. Might be more than what I need though.
Edited by johnph3
forgot to check auto reply
I'm pretty sure that the CorComp Peripheral Diagnostic Cartridge manual included the pinout for a loopback plug.
The only differences for the TI cards is that they are wired DCE instead of DTE. That reverses the signals on pins two and three compared to just about every other computer system out there. The other pins are the same (but also note, the four identified pins are for port 1 of the RS-232 card, and the four pins used to communicate on port 2 will all be different, but are identified in the RS-232 manual).
This is probably the most confusing thing about the RS232 on the TI: The TI is, by this interface, configured as an end device, as you would expect from a modem. One could imagine that you can take a "real" terminal and let it talk to the TI.
This is a real challenge for emulations that have to somehow adapt the wiring to the real PC interface. In MAME, I designed a "line mapper" for that purpose (see https://www.ninerpedia.org/wiki/MESS_Serial_connection).
19 hours ago, johnph3 said:
Sorry I know we are getting off subject for this thread but do you know where I can download the Corcomp PDM manual? I just spent the last hour checking sites to try and find it. The funny thing is I have a PDM module but never got a manual.
I found it hope somebody might need it here it is:
CC_PDM99 cover.pdf CC_PDM99 page 1-2.pdf CC_PDM99 page 3-4.pdf CC_PDM99 page 5-6.pdf CC_PDM99 page 7-8.pdf CC_PDM99 page 9-10.pdf
  • Like 5
7 hours ago, HOME AUTOMATION said:
I believe that my associate AtariAge, senior-programmer, and BFF... @GDMike, has one application running...
...and another in-the-works!:cool:
Whooha!:party:
Yeah, Foxit might be dead now, as SNP ver3 would take on the new task at hand.
I sure hope nobody sees us skipping down the program path hand in hand, BFF.... so, please, none of that is necessary, uh..in public, even though, you have held my programming hand at some point or another...shhhh... Hope your not wearing one of those cameras on your neck tie.
Edited by GDMike
  • Haha 3
As you wish...
4 hours ago, Ksarul said:
Here is one that should do the job for you--and it is set up to work with RS-232/1 and RS-232/2 already. Bonus is that it has a parallel test plug as well.
Here, I tried to fix this for you...|:)
Yeah. The RS232 card is set up as DCE. It should have been DTE. It should mean than a straight-through cable can be used to connect a modem, but that's about the only advantage. It's created literally decades of confusion!
The p-code system does allow you to redirect screen input and output to the RS232 port. Then you can connect a terminal to your TI and run it from the other end of the desk, or even further away. Until you need to replace a diskette or something.
I'm of course convinced that it's this very common ? reason that caused them to turn things upside down with their serial ports.
Great for my HDX setup as I can just plug the PC's DB25 right into the TI's port.
