RXB Posted February 10 Share Posted February 10 Me too I would like a bigger SAMS Quote Link to comment Share on other sites More sharing options...
JasonACT Posted February 12 Share Posted February 12 On 5/3/2016 at 4:16 AM, arcadeshopper said: 2: other memory expansion is incompatible, so it doesn't work with any programs written for say the myarc 128/512k cards or the foundation cards or the corcomp cards.. This is really a limited issue since the only real useful thing written for those cards is XBII from Myarc. Some people enjoy using the ramdisk functionality of those cards but since they were volatile (no power = empty ram) they had limited usefulness for anything but temporary storage. SAMS is also volatile memory, there's no battery backup or nvram.. and it is not a ramdisk though with software you can have some ramdisk"like" functionality (see below) Kind of silly to implement the Myarc standard then, isn't it? Only the one product using it? On 2/10/2024 at 5:47 PM, arcadeshopper said: Marketing... Ha This is hobby stuff at this point if people really want something. Make it you may sell 10-100 A ram board that can be compatible with all the different memory standards for the 4a would be the game changer. Add a DSR and make it switchable for sams and myarc at least to make it xbii capable and maybe partitions as a RAM disk with backup battery or nvram .. but you better do it for the fun as the market is small and unless you make both peb and sidecar models it's even smaller It's an interesting thought though... I guess I can add a runtime-switch? Lots to sort out though with the Cart RAM on my device though, as I only really did the Mini Memory 4K RAM... At the moment, I'm just running the global RAM enable mode which un-protects all the memory in my device. I did also look at the XBII DSR loader, and the 2nd Cart RAM loader, and the 3rd Cart RAM loader from file (Foundation model, not Myarc, as it seemed a tad bit smaller). Here's the last loader, as commented assembly: Spoiler aorg >7c00 7c00 06a0 bl @>7d28 Display ' LOADING EXTENDED BASIC II ' 7c04 0200 li r0, >0f09 PAB Filename Length 7c08 0420 blwp @>7ff2 Read 1 byte from VDP 7c0c c081 mov r1, r2 Save a copy in R2 7c0e 0221 ai r1, >ff00 -1 7c12 0420 blwp @>7fee Write 1 byte to VDP 7c16 0982 srl r2, 8 Convert byte to int 7c18 0580 inc r0 PAB Filename 7c1a 0201 li r1, >7d3a Read PAB Filename into Cart RAM 7c1e 0420 blwp @>7fea Read R2 bytes from VDP 7c22 0705 seto r5 -1 7c24 0585 inc r5 0 7c26 9831 cb *r1+, @>7d0e Compare Cart RAM copy to '.' 7c2a 16fc jne >7c24 Keep counting until '.' is found 7c2c 0585 inc r5 Skip '.' 7c2e 0200 li r0, >0f0a PAB Filename 7c32 a005 a r5, r0 Skip Device 7c34 0201 li r1, >7d0f 'XBII' 7c38 0202 li r2, >0004 Write our filename after the device '.' 7c3c 0420 blwp @>7fe6 Write R2 bytes to VDP 7c40 c140 mov r0, r5 >0f0a 7c42 8d75 c *r5+, *r5+ >0f0a+4 = >0f0e (skip XBII) 7c44 0204 li r4, >3100 '1' 7c48 0206 li r6, >7d13 Attributes for each of 7 files 7c4c c044 mov r4, r1 Get File Number 7c4e c005 mov r5, r0 Set file number in PAB 7c50 0420 blwp @>7fee Write 1 byte to VDP 7c54 c820 mov @>7cd2, @>8356 >0f09 into Scratch 7c5a 0420 blwp @>7ff6 CALL DSR 7c5e 0008 data >0008 DSR-For-LOAD 7c60 1319 jeq >7c94 File Error, go to routine below 7c62 c320 mov @>7ffa, r12 Get device's CRU address 7c66 0200 li r0, >0f32 VDP RAM address 7c6a 04c1 clr r1 Clear bottom byte 7c6c 04c2 clr r2 Clear bottom byte 7c6e d076 movb *r6+, r1 Get Parm 7c70 d0b6 movb *r6+, r2 Get Parm 7c72 d0f6 movb *r6+, r3 Get Parm - Page Number 7c74 0983 srl r3, 8 Convert page byte to int 7c76 3123 ldcr @>7ffc(r3), 4 Set correct 32KB page 7c7a 0420 blwp @>7fea Read R2 bytes from VDP 7c7e 3120 ldcr @>7ffc, 4 Back to Page 0 7c82 0224 ai r4, >0100 Next file '2' 7c86 0284 ci r4, >3800 Stop once '7' is done 7c8a 16e0 jne >7c4c Do Next File 7c8c 3120 ldcr @>7fff, 4 Set Page 3 7c90 0460 b @>a000 ****************** RUN! ****************** 7c94 0200 li r0, >0100 7c98 0201 li r1, >7cd4 Display ' CAN'T ACCESS FILE XBII' 7c9c 0202 li r2, >001b 7ca0 0420 blwp @>7fe6 Write R2 bytes to VDP 7ca4 d804 movb r4, @>8c00 Write R4 byte to VDP RAM (after "..FILE XBII") 7ca8 0200 li r0, >0f01 Clear PAB Status Byte 7cac 04c1 clr r1 7cae 0420 blwp @>7fee Write 1 byte to VDP 7cb2 02e0 lwpi gplws Wait for Key Press 7cb6 0300 limi >0003 Someone got excited 7cba 0300 limi >0000 7cbe 06a0 bl @>000e Scan Keyboard 7cc2 02e0 lwpi >83a0 7cc6 d060 movb @>837c, r1 7cca 13f3 jeq >7cb2 7ccc 06a0 bl @>7d28 Display ' LOADING EXTENDED BASIC II ' 7cd0 10bd jmp >7c4c 7cd2 0f09 Address in VDP RAM where filename length goes 7cd4 2020 ' CAN'T ACCESS FILE XBII' 7cee 4920 ' LOADING EXTENDED BASIC II ' 7d0e 2e58 '.XBII 7d13 23 1d 01 = XBII1 : 2300, 1d00, 01 (Fill page 1 content) 7d16 20 20 02 = XBII2 : 2000, 2000, 02 (Fill page 2 content) 7d19 20 20 03 = XBII3 : 2000, 2000, 03 (Fill page 3 content... All 4 8KB segments) 7d1c a0 20 03 = XBII4 : A000, 2000, 03 (...) 7d1f c0 20 03 = XBII5 : C000, 2000, 03 (...) 7d22 e0 20 03 = XBII6 : E000, 2000, 03 (...) 7d25 60 1c 00 = XBII7 : 6000, 1C00, 00 (Cart RAM, but also resets page to standard 32KB) 7d28 0200 li r0, >0100 7d2c 0201 li r1, >7cef ' LOADING EXTENDED BASIC II ' 7d30 0202 li r2, >001f 7d34 0420 blwp @>7fe6 Write R2 bytes to VDP 7d38 045b rt 7d3a f0f0 Space to read from VDP ... A whole lotta other initial loader stuff ... 7ffa 1e02 CRU Address of config bits 7ffc 0001 CRU for 4 pages... 7ffe 0203 3 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 12 Share Posted February 12 29 minutes ago, JasonACT said: Kind of silly to implement the Myarc standard then, isn't it? Only the one product using it? It's an interesting thought though... I guess I can add a runtime-switch? Lots to sort out though with the Cart RAM on my device though, as I only really did the Mini Memory 4K RAM... At the moment, I'm just running the global RAM enable mode which un-protects all the memory in my device. I did also look at the XBII DSR loader, and the 2nd Cart RAM loader, and the 3rd Cart RAM loader from file (Foundation model, not Myarc, as it seemed a tad bit smaller). Here's the last loader, as commented assembly: Reveal hidden contents aorg >7c00 7c00 06a0 bl @>7d28 Display ' LOADING EXTENDED BASIC II ' 7c04 0200 li r0, >0f09 PAB Filename Length 7c08 0420 blwp @>7ff2 Read 1 byte from VDP 7c0c c081 mov r1, r2 Save a copy in R2 7c0e 0221 ai r1, >ff00 -1 7c12 0420 blwp @>7fee Write 1 byte to VDP 7c16 0982 srl r2, 8 Convert byte to int 7c18 0580 inc r0 PAB Filename 7c1a 0201 li r1, >7d3a Read PAB Filename into Cart RAM 7c1e 0420 blwp @>7fea Read R2 bytes from VDP 7c22 0705 seto r5 -1 7c24 0585 inc r5 0 7c26 9831 cb *r1+, @>7d0e Compare Cart RAM copy to '.' 7c2a 16fc jne >7c24 Keep counting until '.' is found 7c2c 0585 inc r5 Skip '.' 7c2e 0200 li r0, >0f0a PAB Filename 7c32 a005 a r5, r0 Skip Device 7c34 0201 li r1, >7d0f 'XBII' 7c38 0202 li r2, >0004 Write our filename after the device '.' 7c3c 0420 blwp @>7fe6 Write R2 bytes to VDP 7c40 c140 mov r0, r5 >0f0a 7c42 8d75 c *r5+, *r5+ >0f0a+4 = >0f0e (skip XBII) 7c44 0204 li r4, >3100 '1' 7c48 0206 li r6, >7d13 Attributes for each of 7 files 7c4c c044 mov r4, r1 Get File Number 7c4e c005 mov r5, r0 Set file number in PAB 7c50 0420 blwp @>7fee Write 1 byte to VDP 7c54 c820 mov @>7cd2, @>8356 >0f09 into Scratch 7c5a 0420 blwp @>7ff6 CALL DSR 7c5e 0008 data >0008 DSR-For-LOAD 7c60 1319 jeq >7c94 File Error, go to routine below 7c62 c320 mov @>7ffa, r12 Get device's CRU address 7c66 0200 li r0, >0f32 VDP RAM address 7c6a 04c1 clr r1 Clear bottom byte 7c6c 04c2 clr r2 Clear bottom byte 7c6e d076 movb *r6+, r1 Get Parm 7c70 d0b6 movb *r6+, r2 Get Parm 7c72 d0f6 movb *r6+, r3 Get Parm - Page Number 7c74 0983 srl r3, 8 Convert page byte to int 7c76 3123 ldcr @>7ffc(r3), 4 Set correct 32KB page 7c7a 0420 blwp @>7fea Read R2 bytes from VDP 7c7e 3120 ldcr @>7ffc, 4 Back to Page 0 7c82 0224 ai r4, >0100 Next file '2' 7c86 0284 ci r4, >3800 Stop once '7' is done 7c8a 16e0 jne >7c4c Do Next File 7c8c 3120 ldcr @>7fff, 4 Set Page 3 7c90 0460 b @>a000 ****************** RUN! ****************** 7c94 0200 li r0, >0100 7c98 0201 li r1, >7cd4 Display ' CAN'T ACCESS FILE XBII' 7c9c 0202 li r2, >001b 7ca0 0420 blwp @>7fe6 Write R2 bytes to VDP 7ca4 d804 movb r4, @>8c00 Write R4 byte to VDP RAM (after "..FILE XBII") 7ca8 0200 li r0, >0f01 Clear PAB Status Byte 7cac 04c1 clr r1 7cae 0420 blwp @>7fee Write 1 byte to VDP 7cb2 02e0 lwpi gplws Wait for Key Press 7cb6 0300 limi >0003 Someone got excited 7cba 0300 limi >0000 7cbe 06a0 bl @>000e Scan Keyboard 7cc2 02e0 lwpi >83a0 7cc6 d060 movb @>837c, r1 7cca 13f3 jeq >7cb2 7ccc 06a0 bl @>7d28 Display ' LOADING EXTENDED BASIC II ' 7cd0 10bd jmp >7c4c 7cd2 0f09 Address in VDP RAM where filename length goes 7cd4 2020 ' CAN'T ACCESS FILE XBII' 7cee 4920 ' LOADING EXTENDED BASIC II ' 7d0e 2e58 '.XBII 7d13 23 1d 01 = XBII1 : 2300, 1d00, 01 (Fill page 1 content) 7d16 20 20 02 = XBII2 : 2000, 2000, 02 (Fill page 2 content) 7d19 20 20 03 = XBII3 : 2000, 2000, 03 (Fill page 3 content... All 4 8KB segments) 7d1c a0 20 03 = XBII4 : A000, 2000, 03 (...) 7d1f c0 20 03 = XBII5 : C000, 2000, 03 (...) 7d22 e0 20 03 = XBII6 : E000, 2000, 03 (...) 7d25 60 1c 00 = XBII7 : 6000, 1C00, 00 (Cart RAM, but also resets page to standard 32KB) 7d28 0200 li r0, >0100 7d2c 0201 li r1, >7cef ' LOADING EXTENDED BASIC II ' 7d30 0202 li r2, >001f 7d34 0420 blwp @>7fe6 Write R2 bytes to VDP 7d38 045b rt 7d3a f0f0 Space to read from VDP ... A whole lotta other initial loader stuff ... 7ffa 1e02 CRU Address of config bits 7ffc 0001 CRU for 4 pages... 7ffe 0203 Hmm RXB has built in support for SAMS up to 16 Meg! That is quite a bit more then 128K Foundation card or 256K Myarc memory card. I have demoed a game IN THE DARK using 960K before. 2 Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 12 Share Posted February 12 I wonder, how well written is XB2? Maybe it'd be easier to patch it to know AMS? (I don't know how different the Myarc 512k was) 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted February 12 Share Posted February 12 4 hours ago, Tursi said: I wonder, how well written is XB2? Maybe it'd be easier to patch it to know AMS? (I don't know how different the Myarc 512k was) Probably the most important thing to remember with Myarc XB-II is that development stopped before they'd shaken all of the bugs out of it. It has a lot of potential, but IIRC, some of the bugs could seriously bite you when writing complex programs. Commented source code isn't in the wild, unfortunately, so the only way to improve it now would be a careful disassembly/bug hunt. . .unless Lou Philips still has a copy of the source stashed somewhere, which would still leave the bug-hunting exercise. 3 Quote Link to comment Share on other sites More sharing options...
+9640News Posted February 13 Share Posted February 13 1 hour ago, Ksarul said: unless Lou Philips still has a copy of the source stashed somewhere, which would still leave the bug-hunting exercise. I have inquired with Lou about the source but have bene unsuccessful. Quote Link to comment Share on other sites More sharing options...
hhos Posted February 13 Share Posted February 13 How does the Myarc memory expansion card work? Did it have DSR ROM? Where can I read about how they paged the memory in that unit? Quote Link to comment Share on other sites More sharing options...
hhos Posted February 13 Share Posted February 13 (edited) 48 minutes ago, hhos said: How does the Myarc memory expansion card work? Did it have DSR ROM? Where can I read about how they paged the memory in that unit? Ooohh. That's very different..... Never mind. https://web.archive.org/web/20070203221436/http://pw2.netcom.com/~mjmw/myarc512.pdf If anyone wants to design a new memory expansion board, I would like to place my vote for NOT using the Myarc solution as its basis. Look at page 23(29) of this PDF for a short synopsis of the Myarc paging scheme. Edited February 13 by hhos Added page # to look at in PDF 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted February 13 Share Posted February 13 My 512k MEXP-1 also conflicts with my WHT SCSI. I am almost certain the CRU-based memory banking scheme is not responsible, but rather the RAM disk is the culprit. Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 14 Share Posted February 14 19 hours ago, hhos said: Ooohh. That's very different..... Never mind. Ahh... so it swaps out the entire 32k space with two CRU control bits. That's awkward to simulate with the AMS though it could be done if we can make some ROM space for a larger paging function. But, if XB2 was never really finished and there's no pressing software that needs it, maybe it best remains a historical artifact... 1 1 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted February 14 Share Posted February 14 6 hours ago, Tursi said: it best remains a historical artifact... SAMS is slow... DSK1.zip 3 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 14 Share Posted February 14 28 minutes ago, JasonACT said: SAMS is slow... DSK1.zip 40.58 kB · 2 downloads What is this supposed to do? 1 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted February 14 Share Posted February 14 20 minutes ago, Asmusr said: What is this supposed to do? Run Myarc XBII from SAMS in Classic99 - if all the planets are aligned. 3 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted February 14 Share Posted February 14 4 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted February 14 Share Posted February 14 8 hours ago, Tursi said: Ahh... so it swaps out the entire 32k space with two CRU control bits. My internal 64 K expansion did that too, to begin with. But then I realized it was a bad idea, and changed to eight CRU bits each controlling 8 Kbytes of RAM being paged in or out. It's a lot easier to handle if not all your program's memory disappears for you when you switch a bank. 4 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 14 Share Posted February 14 1 hour ago, JasonACT said: Run Myarc XBII from SAMS in Classic99 - if all the planets are aligned. Whoa, that's very exciting, but I must be missing something because when I press 2 for MYARC XBII-212 I just get an empty screen. I have the files on DSK1. Do I also need the Myarc DSR ROM? 3 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 14 Share Posted February 14 7 hours ago, JasonACT said: SAMS is slow... DSK1.zip 40.58 kB · 8 downloads I would say the problem is how Myarc Basic works with SAMS as it was never designed with SAMS in mind, using SAMS with Myarc Basic is going to be a bad match. I am running this from XB GPL using SAMS and does this look slow? Quote Link to comment Share on other sites More sharing options...
hhos Posted February 14 Share Posted February 14 6 hours ago, Asmusr said: Whoa, that's very exciting, but I must be missing something because when I press 2 for MYARC XBII-212 I just get an empty screen. I have the files on DSK1. Do I also need the Myarc DSR ROM? I didn't think Myarc had a ROM on its memory expansion board. TI started it with its own board, I guess. They only had to map 32K worth of memory into 32K of memory space, though. They didn't need DSR ROM to do that. While I would agree that they should have a DSR, I don't think they do, but if I'm wrong I would be pleased. The Super AMS does not have a ROM. HH Quote Link to comment Share on other sites More sharing options...
RXB Posted February 14 Share Posted February 14 1 hour ago, hhos said: I didn't think Myarc had a ROM on its memory expansion board. TI started it with its own board, I guess. They only had to map 32K worth of memory into 32K of memory space, though. They didn't need DSR ROM to do that. While I would agree that they should have a DSR, I don't think they do, but if I'm wrong I would be pleased. The Super AMS does not have a ROM. HH The SAMS does not need a ROM as the DSR space is all Mapper Registers. PAGE S3 SAMS MAPPER ****************************************************************** The SAMS card has tons of documents as to its function and use. So to re-explain these docs would be pointless. Read the docs or find some, sorry but the RXB package is already huge. In PASS mode the mapper register setup is equivalent to: mapper address mapper page num address range -------------- ------ -------- ------------- HEX Dec HEX Dec memory area --- --- --- --- ----------- >4004 = 16388 is MR02 = >02 = 02 points to >2000 - >2FFF range >4006 = 16390 is MR03 = >03 = 03 points to >3000 - >3FFF range >4014 = 16404 is MR10 = >0A = 10 points to >A000 - >AFFF range >4016 = 16406 is MR11 = >0B = 11 points to >B000 - >BFFF range >4018 = 16408 is MR12 = >0C = 12 points to >C000 - >CFFF range >401A = 16410 is MR13 = >0D = 13 points to >D000 - >DFFF range >401C = 16412 is MR14 = >0E = 14 points to >E000 - >EFFF range >401E = 16414 is MR15 = >0F = 15 points to >F000 - >FFFF range (MR=Mapper Register) In MAP mode the mapper register setup is equivalent to: EXAMPLE1 mapper address mapper page num address range -------------- ------ -------- ------------- HEX Dec HEX Dec memory area --- --- --- --- ----------- >4004 = 16388 is MR02 = >10 = 16 points to >2000 - >2FFF range >4006 = 16390 is MR03 = >11 = 17 points to >3000 - >3FFF range >4014 = 16404 is MR10 = >12 = 18 points to >A000 - >AFFF range >4016 = 16406 is MR11 = >13 = 19 points to >B000 - >BFFF range >4018 = 16408 is MR12 = >14 = 20 points to >C000 - >CFFF range >401A = 16410 is MR13 = >15 = 21 points to >D000 - >DFFF range >401C = 16412 is MR14 = >16 = 22 points to >E000 - >EFFF range >401E = 16414 is MR15 = >17 = 23 points to >F000 - >FFFF range (MR=Mapper Register) PAGE S4 SAMS MAPPER ***************************************************************** In map mode the mapper register setup is equivalent to: EXAMPLE2 mapper address mapper page num address range -------------- ------ -------- ------------- HEX Dec HEX Dec memory area --- --- --- --- ----------- >4004 = 16388 is MR02 = >62 = 98 points to >2000 - >2FFF range >4006 = 16390 is MR03 = >63 = 99 points to >3000 - >3FFF range >4014 = 16404 is MR10 = >64 = 100 points to >A000 - >AFFF range >4016 = 16406 is MR11 = >65 = 101 points to >B000 - >BFFF range >4018 = 16408 is MR12 = >66 = 102 points to >C000 - >CFFF range >401A = 16410 is MR13 = >67 = 103 points to >D000 - >DFFF range >401C = 16412 is MR14 = >68 = 104 points to >E000 - >EFFF range >401E = 16414 is MR15 = >69 = 105 points to >F000 - >FFFF range (MR=Mapper Register) In MAP mode the mapper register setup is equivalent to: EXAMPLE3 mapper address mapper page num address range -------------- ------ -------- ------------- HEX Dec HEX Dec memory area --- --- --- --- ----------- >4004=16388 is MR02 =>1FF9 = 8185 points to >2000 - >2FFF range >4006=16390 is MR03 =>1FFA = 8186 points to >3000 - >3FFF range >4014=16404 is MR10 =>1FFB = 8187 points to >A000 - >AFFF range >4016=16406 is MR11 =>1FFC = 8188 points to >B000 - >BFFF range >4018=16408 is MR12 =>1FFD = 8189 points to >C000 - >CFFF range >401A=16410 is MR13 =>1FFE = 8190 points to >D000 - >DFFF range >401C=16412 is MR14 =>1FFF = 8191 points to >E000 - >EFFF range >401E=16414 is MR15 =>2000 = 8192 points to >F000 - >FFFF range (MR=Mapper Register) I try to explain how it works as much as possible in RXB documents. Originally RXB 2001 had AMS (SAMS) support. 1 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted February 14 Share Posted February 14 8 hours ago, Asmusr said: Whoa, that's very exciting, but I must be missing something because when I press 2 for MYARC XBII-212 I just get an empty screen. I have the files on DSK1. Do I also need the Myarc DSR ROM? Have you configured the Classic99 ini file (using details in the ini.txt) so the cartridge is in RAM instead of ROM? Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 14 Share Posted February 14 4 minutes ago, JasonACT said: Have you configured the Classic99 ini file (using details in the ini.txt) so the cartridge is in RAM instead of ROM? Oh, that must be it. I just opened the cartridge file as a user cartridge. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 14 Share Posted February 14 10 minutes ago, JasonACT said: Have you configured the Classic99 ini file (using details in the ini.txt) so the cartridge is in RAM instead of ROM? Now it works like a charm. I guess the reason you say SAMS is slow is that it takes a while longer to set up 8 memory words than 2 CRU bits? 3 Quote Link to comment Share on other sites More sharing options...
JasonACT Posted February 14 Share Posted February 14 4 minutes ago, Asmusr said: Now it works like a charm. I guess the reason you say SAMS is slow is that it takes a while longer to set up 8 memory words than 2 CRU bits? Yes, along with Myarc XBII constantly swapping pages, which you can see in the debugger. It runs a fair bit slower than the real thing. 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted February 14 Share Posted February 14 1 minute ago, JasonACT said: Yes, along with Myarc XBII constantly swapping pages, which you can see in the debugger. It runs a fair bit slower than the real thing. It's still quite fast. And quite an accomplishment that you managed to get this to work. 4 Quote Link to comment Share on other sites More sharing options...
RXB Posted February 14 Share Posted February 14 52 minutes ago, Asmusr said: Now it works like a charm. I guess the reason you say SAMS is slow is that it takes a while longer to set up 8 memory words than 2 CRU bits? Which is the reason in RXB I put the program in FAST RAM SCRATCH PAD to change or set up SAMS pages. 1 Quote Link to comment Share on other sites More sharing options...
