Diaperboy Posted September 18, 2016 Share Posted September 18, 2016 Regarding the EA skew align (40 sector boot) copy protection. My crack patches sector #11,#18,#19,#40. I use sector #11 for my first "hook" to execute custom subroutines. I use sectors #18,#19,#40 to contain the extra subroutines. These subroutines temporarily exist in memory and must be used quickly before getting over-written. My first "hook" WILL get detected by a data check, so the first subroutine patches it back to the unaltered value before the data check. Because of the temporary nature of my "injected" subroutines, the third subroutine "writes" the fourth subroutine to memory starting at location $0100. This area seems to be safe from data checks and from being over-written. This fourth subroutine is the one used to redirect the second read of the double sector, thus tricking the protection into thinking it is a genuine disk. The variations on this copy protection (2 so far) effect where my "injected" code ends up in memory and where the copy protection itself ends up in memory. (type A) Archon and M.U.L.E. have the same memory layout and can use the IDENTICAL CRACK. You can't swap sectors between the two, but you can modify the same sectors in the same locations with the same code. (type B) Pinball Construction . and Seven Cities Of Gold (first edition) also have the same memory layout. This memory layout is different than (type A), but uses the same code. The same "injected" subroutines are used, but they are modified to support the new memory layout. 4 Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 19, 2016 Share Posted September 19, 2016 Here is the Electronic Arts titles that I have modified so far. Archon (40 sector boot - skew align copy protection - type A) M.U.L.E. (40 sector boot - skew align copy protection - type A) Pinball Construction Set (40 sector boot - skew align copy protection - type B) Seven Cities Of Gold (first edition - black disk) (40 sector boot - skew align copy protection - type B) Archon II (36 sector boot - super tracks copy protection) These titles are cracked but have the original EA loading screen INTACT. They all go through the entire copy protection routine, performing all checks just the same as an unmodified disk. The added subroutines mimic what the copy protection expects to see on an original disk. These have ONLY been tested using Altirra 2.60 emulator. I would greatly appreciate if somebody could test these titles on genuine Atari hardware. Thanks in advance! Electronic Arts.rar 8 Quote Link to comment Share on other sites More sharing options...
FULS Posted September 20, 2016 Share Posted September 20, 2016 Diaperboy, These are amazing. Keep up the great work. Minimal change to the original is always the best. Electronic Arts games were always my favorites. I think these were the 19 titles for the Atari. Were there more? Age of Adventure Electronic Arts 1986 Archon Electronic Arts 1983 Archon II - Adept Electronic Arts 1984 Axis Assassin Electronic Arts 1983 D-Bug Electronic Arts 1983 Hard Hat Mack Electronic Arts 1983 Lords of Conquest Electronic Arts 1986 Mail Order Monsters Electronic Arts 1985 MULE Electronic Arts 1983 Murder on the Zinderneuf Electronic Arts 1983 One-on-One Electronic Arts 1983 Pinball Construction Set Electronic Arts 1983 Racing Destruction Set Electronic Arts 1985 Realm of Impossibility Electronic Arts 1984 Seven Cities of Gold (The) Electronic Arts 1984 Super Boulder Dash Electronic Arts 1986 Touchdown Football Electronic Arts 1986 Word Flyer Electronic Arts 1983 Worms? Electronic Arts 1983 Hope you can do some more of these before you lose interest. Your time and research are invaluable!! Thank you! 2 Quote Link to comment Share on other sites More sharing options...
Tempest Posted September 20, 2016 Share Posted September 20, 2016 These titles are cracked but have the original EA loading screen INTACT. They all go through the entire copy protection routine, performing all checks just the same as an unmodified disk. The added subroutines mimic what the copy protection expects to see on an original disk. These have ONLY been tested using Altirra 2.60 emulator. I would greatly appreciate if somebody could test these titles on genuine Atari hardware. So does that mean they won't work with the Happy board? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted September 20, 2016 Share Posted September 20, 2016 From memory the originals would not work on a Lazer or Happy, had to be dropped in to UN-Happy mode.. From running the supplied files on Altirra 2.80 any faster drive made them crash, only with accurate timing did they work which sort of confirms my memory.. Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted September 20, 2016 Share Posted September 20, 2016 EA games do not like modified drives or OS for the most part. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted September 20, 2016 Author Share Posted September 20, 2016 I cracked some MicroProse games which seem(!) to be protected by a modified track alignment. What stumped me is the fact that I cannot FAIL the protection in emulation. The routine reads one sector from each of five consecutive tracks; once in ascending order and then in descending order. The time needed to do this may only vary by one jiffy. Since standard emulation does not take time to wait for rotational delays, it will never fail. But after copying the whole disk image to an ATX which was created from a plain standard formatted disk (with no specific alignment) the games still load. Could anyone write the attached dumps to a real floppy and try to load them? My expectation is that the files ending in "orig" have to crash and the ones without "orig" will run. Some info about the protection can also be found inside the attached archive. MicroProseAlignment.zip 2 Quote Link to comment Share on other sites More sharing options...
ijor Posted September 20, 2016 Share Posted September 20, 2016 Here is the Electronic Arts titles that I have modified so far. Archon (40 sector boot - skew align copy protection - type A) ... Pinball Construction Set (40 sector boot - skew align copy protection - type B) Amazing work! Btw, there should be a third type of EA skew align code. It is earlier than those, incompatible with XL/XE. Should be in Worms?, IIRC, may be also in D-BUG. From memory the originals would not work on a Lazer or Happy, had to be dropped in to UN-Happy mode.. Not exactly unhappy mode is needed. Slow mode is enough. I cracked some MicroProse games which seem(!) to be protected by a modified track alignment. What stumped me is the fact that I cannot FAIL the protection in emulation. Yes, jaja. See my article at: http://vapi.fxatari.com/docs/Microprose-skew.html Since standard emulation does not take time to wait for rotational delays, it will never fail. But after copying the whole disk image to an ATX which was created from a plain standard formatted disk (with no specific alignment) the games still load. Reuse a real ATX image from some title you know it is not aligned. Altirra is probably creating an aligned image by default. And remember to turn off SIO patch and enable accurate disk timing. I had a special debug switch in VAPI to randomize the skew align 2 Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 21, 2016 Share Posted September 21, 2016 To Ijor, You are correct about there being a third type of memory layout in the EA skew align (40 sector boot) copy protection. So far I have Type A: Archon M.U.L.E. Music Construction Set Type B: Pinball Construction Set Seven Cities Of Gold(first edition) Axis Assassin Financial Cookbook Hard Hat Mack Word Flyer Type C: Murder on the Zinderneuf Worms All of these titles are 130XE OS compatible. I have been unable to find an .atx copy protected copy of D-Bug. Interestingly enough...an Altirra emulator Cheat Code can make an unaltered copy of an EA skew align protected title boot correctly. If you copy the .atx title with Disk Wizard II, the output will be an .atr image. This .atr image can't duplicate the copy protection and will not boot. Using a cheat code it Will boot. Cheat codes: Type A: Mem Loc $0A10 - Value $01 Type B: Mem Loc $B390 - Value $01 Type C: Mem Loc $7390 - Value $01 I'm not sure if I missed any titles with this copy protection scheme. I have found a bunch of titles with the super tracks (36 sector boot) copy protection but I have only worked on one of those (Archon II). I do know that there is more than one memory layout used. Lords of Conquest uses the same layout as Archon II, but the rest are different. Pulling off a hack on the super tracks (36 sector boot) copy protection could be difficult on some titles. This hack requires remapping 20 sectors and they need to be in-a-row (At least a group of 3 and a group of 17). I'm not sure how "full" some titles are. 1 Quote Link to comment Share on other sites More sharing options...
ijor Posted September 21, 2016 Share Posted September 21, 2016 Type C: Murder on the Zinderneuf Worms All of these titles are 130XE OS compatible. Ok, checked these two titles. There are two versions of each of them. One is XL/XE compatible, the other is not. So it should be a type "D", that actually is probably the earliest. I'm not sure if I missed any titles with this copy protection scheme. I assume you mean EA titles with skew align, correct? Off the top of my head ... One on one Realm of Impossibility Cut & Paste Movie Maker Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 22, 2016 Share Posted September 22, 2016 Thank you for offering these. I always liked originals. Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 22, 2016 Share Posted September 22, 2016 Thanks for all the encouragement! I'd like to thank the original poster for all his hard work as well. Here are the rest of the EA titles (skew align copy protection - 40 sector boot) that I have. I don't have a copy protected image of D-Bug, so that will have to wait...for nowType A:Music Construction SetType B:Axis AssassinFinancial CookbookHard Hat MackWord FlyerType C:Murder On The ZinderneufWorms?Electronic Arts II.rar 3 Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 22, 2016 Share Posted September 22, 2016 All other EA titles that I have use the Super Tracks (36 sector boot) copy protection scheme. I'm gonna try to crack them all if possible. Finding some titles in the original unmodified form with copy protection intact could be tricky. This is what I was able to find:Archon II (I cracked this one)Age of AdventureLords of ConquestMail Order MonstersOne-On-OneRacing Destruction SetRealm of ImpossibilitySeven Cities of Gold (second edition - grey disk)Super Boulder DashTouchdown Football Any contributions would be appreciated. Which titles am I missing? Any ideas where I might find missing titles? Quote Link to comment Share on other sites More sharing options...
eccofonic Posted September 22, 2016 Share Posted September 22, 2016 (edited) Thanks for all the encouragement! I'd like to thank the original poster for all his hard work as well. Here are the rest of the EA titles (skew align copy protection - 40 sector boot) that I have. I don't have a copy protected image of D-Bug, so that will have to wait...for now Type A: Music Construction Set Type B: Axis Assassin Financial Cookbook Hard Hat Mack Word Flyer Type C: Murder On The Zinderneuf Worms? Electronic Arts II.rar Just noticed that Music Construction Set in the rar file is still an atx file dated dec 2005... is this a mistake? Edited September 22, 2016 by eccofonic Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 22, 2016 Share Posted September 22, 2016 Whoops! Yes that is a mistake. Here is the REAL cracked version of Music Construction Set. Music Construction Set.atr 2 Quote Link to comment Share on other sites More sharing options...
tjlazer Posted September 22, 2016 Share Posted September 22, 2016 (edited) Keep up the good work! So these can be written to real disks and ran no issues? Edited September 22, 2016 by tjlazer Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted September 22, 2016 Share Posted September 22, 2016 All of these titles are 130XE OS compatible. I have been unable to find an .atx copy protected copy of D-Bug. I have an original D-Bug but wasn't able to VAPI image it, I do have a .pro of it though. I've also got a Seven Cities grey, Racing Destruction Set and Mail Order Monsters, all of which I believe I could not VAPI image either. Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 22, 2016 Share Posted September 22, 2016 tjlaser, I'm not sure if my EA cracks can be run from an actual floppy disk. I suspect that they can, but I don't have the equipment to try. Hopefully somebody can test and find out for sure Quote Link to comment Share on other sites More sharing options...
firestorm Posted September 23, 2016 Share Posted September 23, 2016 I copied MULE and Murder On The Zinderneuf on floppy and boot it from 1050, sorry to say it doesn't work Quote Link to comment Share on other sites More sharing options...
ijor Posted September 23, 2016 Share Posted September 23, 2016 Hi Remo, I have an original D-Bug but wasn't able to VAPI image it, I do have a .pro of it though. I've also got a Seven Cities grey, Racing Destruction Set and Mail Order Monsters, all of which I believe I could not VAPI image either. I might try to improve the VAPI imaging tool for the Happy, if there is enough demand, but it is a bit of a PITA currently. Don't you happen to have low level imaging hardware? Kryoflux or SCP? Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 23, 2016 Share Posted September 23, 2016 Firestorm, Bummer that it didn't work. I actually had my suspicions that they may not. Thanks so much for trying it on a floppy on a 1050 drive though. I think the issue is the same problem faced by Djaybee regarding being unable to make the skew align FAIL when running on an emulator. Did you / could you test Archon II on a floppy? That title has a different copy protection than ALL the others I have posted. I actually think it has a better chance of working because it doesn't seem to use skew alignment (I might be wrong though) Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 23, 2016 Share Posted September 23, 2016 To Djaybee, Did you ever figure something out regarding making skew alignment FAIL using an emulator (hopefully Altirra)? According to firestorm my titles won't boot on a floppy and a suspect that it's the same issue you faced with Microprose titles (not being able to make the protection fail). Did using an .atx (as suggested by ijor) work? If so what .atx did you use? I wish there was a option on Altirra to mimic a random skew alignment Quote Link to comment Share on other sites More sharing options...
firestorm Posted September 23, 2016 Share Posted September 23, 2016 Firestorm, Bummer that it didn't work. I actually had my suspicions that they may not. Thanks so much for trying it on a floppy on a 1050 drive though. I think the issue is the same problem faced by Djaybee regarding being unable to make the skew align FAIL when running on an emulator. Did you / could you test Archon II on a floppy? That title has a different copy protection than ALL the others I have posted. I actually think it has a better chance of working because it doesn't seem to use skew alignment (I might be wrong though) Archon II works just few extra pixels on loading screen . To copy files from sio2sd to floppy I'm using copy program from Alternate Reality disk 2 side 2. Testing on Atari 800XL PAL and stock Atari 1050. Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 23, 2016 Share Posted September 23, 2016 To anybody who is interested. I have found a blank disk in .atx format that has a RANDOM SECTOR SKEW! Running the Altirra emulator, I loaded Disk Wizard II. Using Disk Wizard II, I copied one (several) of my EA cracks and used this .atx image as a blank disk WITHOUT FORMATTING. *IMPORTANT* When saving the disk image after being written to, MAKE SURE you select "VAPI protected disk image (*.atx)", because Altirra defaults to "Atari disk image (*.atr.) Using this blank seemed to "trip up" every one of my EA cracks. The ONLY exception to this was my crack of Archon II. As I suspected it doesn't seem to use skew alignment as part of it's copy protection. Hopefully this image can be of use to somebody who is investigating sector skew alignment copy protection. BLANK-random sector skew.rar 2 Quote Link to comment Share on other sites More sharing options...
Diaperboy Posted September 23, 2016 Share Posted September 23, 2016 Thanks for doing the test Firestorm! You rock! I'm actually thinking about revisiting my Archon II crack to patch out those pixels. I've got some work ahead of me now that I can test sector skew alignment copy protection. I really don't think it will be too difficult to crack the sector skew part of the EA copy protection. I'll hopefully be posting more correctly cracked EA titles in the near future. 3 Quote Link to comment Share on other sites More sharing options...
