Graphics on the 7800 is very different from the 2600, so you're going to need different tools. (Which might exist, who knows?)
First, graphics data is laid out "upside down" with the last scanline on the lowest address and each scanline on a separate page. e.g. for a 2 byte x 16 line sprite
$e000-$e001 bottom line
$e100-$e101 2nd last line
$ee00-$ee01 2nd line
$ef00-$ef01 top line
(Sprites are typically 16 or 8 lines high and will be on even 4K (16 line) or even 2K (8 line) address blocks.
Second, while sprites on the 2600 are 1 bit per pixel, sprites on the 7800 may be 1, 2 (most common), or 4 bits per pixel depending upon the graphics "mode". The bits from the graphics data are combined with bits in the display list entry to determine if the pixel is transparent or the output color (from a 24 of 256 entry palette).
lol - you guys are too funny. Thanks for the vote of confidence. :) It's actually 7800 development-related, not a game.
@Inky - sorry for the de-rail.
Only the 320A mode games (i.e. Frenzy, RipOff, etc.) would work with Hack-O-Matic (they would still be upside-down though).
I used to use something called "Tile Molester" for the 160A mode games (i.e. the most common mode), but it uses Java (which I hate) and it is a *pain* to set up.
One thing to note, however - Ms. Pac-Man (the original 7800 version) is the only one that has the graphics stored differently than every other game. They are not in the page format as Eric described, but the graphics are stored 'vertically' - 8 bits wide but 2bpp (2 bytes per scanline) then moves down to the next scanline. It has to do with the way they display list kernel is made.
Bob
Edited by PacManPlus
If you'd like to make changes to Pac-Man or Scramble, Jeff Wierer made specific graphics editors just for those two games. You can find them here and here.
I just came across the scramble editor. I may play with that one.
Specifically I'd like to try my hand at cleaning up the graphics in Scrapyard Dog, and changing your character in Xenophobe to be more like Dr. Kwak.
Bob
Did anyone else here the sound of the guy going off the cliff on the cliffhanger price it right game in their head after reading this??
Hi Bob!! :) Found you!! :P
I made a Mario hack and used
Scrapyard Dog for it.I never released it.
Reason is,that I cannot test all changes
cause Scrapyard Dog is damn heavy to play.
I used Tilemolester.....only thing..I cannot
find is this damn SELLER graphics....all
other graphics,I was able to find.So if there
is somebody,who could help with the SELLER
screen.....
greetings Walter
Edited by gambler172
screen.....
greetings Walter
I wouldn't be surprised if the seller graphic was the same graphic used for the silly puzzle at the end of the game.
