6502 to cload audio
If I understand your question correctly, it would be at least a two step process:
1. Run a cross assembler to make a binary executable out of your ASM source code. It would need to generate an Atari compatible program.
2. Run some other program to make an audio file that resembles a tape loading of your binary file. You might need to put the binary executable into an emulator style tape image first, and then convert that one to audio.
You might get more and faster responses if you ask in the Atari 8-bit section or one of the sub categories.
