Building a G7400 RGB cable
rhcocker
So I completed the G7400 RGB addition mod as described here. It was surprisingly simple and took me about an hour to finish.
I now need to build the 8 pin DIN to SCART cable. I am not familiar with building these, but I can't imagine it would be too difficult. So I hope someone here could give me some tips to help me complete it.
Here is DIN Connector Pinout (according to the website at the link above)
1: RGB status (75 Ohm, 3 V)
2: Ground (0 V)
3: Blue (75 Ohm, 0.7 Vtt)
4: Composite Video (CVBS) (75 Ohm, 1 Vtt)
5: Red (75 Ohm, 0.7 Vtt)
6: Status CVBS (VCR) (10 kOhm, 12 V)
7: Sound
8: Green (75 Ohm, 0.7 Vtt)
Here are my questions:
1) Do I add a 10 kOhm resistor to scart pin 6 and 75 Ohm resistors to scart pins 1, 3, 4, 5, and 8?
2) Does the symbol on scart pin17 (see fig) mean that I just connect it to the metal connector (pin 21)?
3) Are there any other components that I should be adding to the cable?
Any help or additional info would be greatly appreciated.
Thanks
Edited by rhcocker
2: Ground (0 V)
7: Sound
Thanks
Sir,
Don't Add Resistor and, No Other Wiring/Connections.
Here G7400 == G7200 (Only, In RGB To Scart Cable!)
3V/75Ohm, 12V/10kOhm, ... Are The Lines Technical/Electrical Specifications (Voltage/Impedance
Specification).
Good Luck.
Edited by Atari 2600 H.E.R.O
Hi!
I never add any resistor or component in the scart cable
The genuine RGB scart cable (french péritel) hasn't component inside.
Sir,
Specification).
Thank you both very much for your replies. This helps.
  • 2 years later...
Reviving this old thread:
What 8pin DIN connector did you use for the cable? And does the connector differ from the one used in the older G7XXX ?
I bought all components for the RGB mod as described on the site you linked above, including the correct MAB-8-SH socket. I then ordered this Odyssey/Videopac rgb cable. Before doing the RGB mod I now realized that the cable connector does not fit in the DIN socket, it must be this other DIN 8 variation mentioned in the mod manual.
I have some spare DIN-8 connectors, but those also seem to be the wrong kind, hence I hope someone here can give me a link or article number of a connector that fits into this special MAB-8-SH DIN 8 socket.
Thanks
For 8 pins, there seems to be 2 variations, that are usually called "horseshoe" and circle.
The difference is more obvious on the male connector side :
194325-2df445d5a2ebda3da49e41786fab3607.
You normally need the 270° one (circular). But apparently, you ordered the 262° socket instead of the 270°, which is why the ready-made cable you bough doesn't fit.
Edited by CatPix
Ok, thanks for the explanation, this makes it much clearer, esp. with the picture.
So the original socket (the one used in the french versions of the G7400 is a circular one and not a horseshoe as described in the RGB mod page? I want to create a mod that is close to the original french model, so I would like to know whether I should order a new socket for the pcb or a connector for the cable.
  • 1 year later...
On 6/3/2016 at 6:27 AM, Atari 2600 H.E.R.O said:
Sir,
Specification).
Good Luck.
Hi, is this view from the rear/soldering  or front/plugging side  of the 8din plug?
thanks a lot!
