+Larry Posted May 23, 2016 Share Posted May 23, 2016 Long time ago, I knew how to do this, but have lost the info and certainly don't remember anymore. The idea is that (ram) Basic gets loaded and activated, then executes the SAVEd program. Can be loaded as an executable from Dos. There were several commercial programs like this, IIRC. The question about the stand alone BASIC program made me think of this. -Larry Quote Link to comment Share on other sites More sharing options...
Madi Posted May 23, 2016 Share Posted May 23, 2016 (edited) I am not completely sure of what you mean. There is a simple way to "ENTER" a listed program or data from a disk or cassette, etc. into an executed basic program (without losing the executed program) through the use of an immediate mode command. e.g. POKE 842,13:STOP ... .... CONT For more info, refer to Mapping The Atari, Revised Edition, Page 83. Edited May 23, 2016 by Madi Quote Link to comment Share on other sites More sharing options...
russg Posted May 23, 2016 Share Posted May 23, 2016 (edited) Long time ago, I knew how to do this, but have lost the info and certainly don't remember anymore. The idea is that (ram) Basic gets loaded and activated, then executes the SAVEd program. Can be loaded as an executable from Dos. There were several commercial programs like this, IIRC. The question about the stand alone BASIC program made me think of this. -Larry I haven't heard of a way to add BASIC to a SAVEd BASIC program. The solution that would make the BASIC SAVEd program run as a DOS binary load is to compile the BASIC SAVEd program with a compiler such as ABC or MMG compiler. The only restriction I can remember is you can't have floating point in the SAVEd program with ABC, all has to be integer. I have also a binary load BASIC A, B or C for use with a 800 or 400. I think they work on 800/400. Edited May 23, 2016 by russg Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 23, 2016 Share Posted May 23, 2016 I don't know why you'd want to have a Basic language processor loaded along with the program. Sort of wasteful isn't it? Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 23, 2016 Author Share Posted May 23, 2016 Thanks, but here is hopefully a better explanation. No Basic cart or rom is required. You load and execute a file version of the Basic interpreter, and after initializing, the Basic program (from the same file) is loaded executed. This goes all the way back to the pre-XL days, so no cartridge was needed. "Load and Go" on steroids. Just boot dos and then "L" the file and bingo, the Basic program was up and running. Pretty sure that this was exactly how it worked. Why? Because we could... -Larry Quote Link to comment Share on other sites More sharing options...
+mytek Posted May 23, 2016 Share Posted May 23, 2016 This can be done in either Turbo BASIC or BASIC++ by renaming your Basic program AUTORUN.BAS which will automatically load after doing a binary load of the Basic language. - Michael Quote Link to comment Share on other sites More sharing options...
JD6502 Posted May 23, 2016 Share Posted May 23, 2016 I found a reprint of an article from the Assembly Language column in Antic June 1983 that explains how to do something similar, but if I read it correctly you need the basic cart and it makes a direct boot disk-not a binary. Here's an excerpt... The system works by loading the BASIC token file to a suitable address with a program used with the Assembler Editor cartridge, and inserting a short header program in front of the token file. This, upon loading, sets up the pointers required by BASIC and then jumps into the BASIC cartridge at the address of the RUN routine. A suitable return address is provided by pushing values onto the stack. A third program is then used to dump the header and token files onto cassette or non-DOS disk. It sounds cool, I may have to try this out. Quote Link to comment Share on other sites More sharing options...
BillC Posted May 23, 2016 Share Posted May 23, 2016 DOS 2.5 had a utility which allowed creating an AUTORUN.SYS that would load a BASIC program at BOOT. I'm sure the file created was designed for use with cartridge/internal BASIC, but it might also work if appended to a file version of BASIC. http://vintagecomputerclub.org.uk/Atari%208-bit%20Autorun.html Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted May 23, 2016 Share Posted May 23, 2016 (edited) Well, there are several options: 1) compile: use a Basic compiler (ABC, MMG, TB XL comp., etc.); the compiled file can often be binary loaded from DOS... 2) convert Bas to COM: use e.g. BAS2COM by Raster (A8 program) or BAS2XEX by Fandal (PC program) or a similar application to convert BAs into a pseudo ML-file. This ML file still requires Atari Basic and therefore will only run on XL/XE computers (and the ML file is still as slow as the original Atari Basic program)... http://atariage.com/forums/topic/215992-basic-to-xex-compiler-that-keeps-original-basic-speed/?do=findComment&comment=2817638 3) use a Basic dialect with an Autorun option, then you can load the Basic dialect from DOS automatically (as Autorun.SYS) and it will load a Basic file (e.g. as Autorun.BAS) afterwards... http://atariage.com/forums/topic/240811-u-basic/?do=findComment&comment=3284045 (see also post #14) Personally I would not merge (append) a Basic dialect + a Basic program into one file, except TB XL maybe. Luckily Homesoft often does this with TB XL and programs written in TB. No clue how he does it, but you always get a single / stand-alone file in the end. You can also do it with compiled TB XL programs by using the CTB-linker (which will link the CTB Runtime and Autorun.CTB into one single file)... Edited May 23, 2016 by CharlieChaplin Quote Link to comment Share on other sites More sharing options...
GoodByteXL Posted May 25, 2016 Share Posted May 25, 2016 Thanks, but here is hopefully a better explanation. No Basic cart or rom is required. You load and execute a file version of the Basic interpreter, and after initializing, the Basic program (from the same file) is loaded executed. This goes all the way back to the pre-XL days, so no cartridge was needed. "Load and Go" on steroids. Just boot dos and then "L" the file and bingo, the Basic program was up and running. Pretty sure that this was exactly how it worked. Why? Because we could... -Larry I guess the topic is runtime versions of BASIC interpreters. It is somewhere in my dungeons from the pre-XL time. But I cannot really remember anything useful right now. Quote Link to comment Share on other sites More sharing options...
