buddyguy2 Posted May 26, 2016 Share Posted May 26, 2016 Not sure what I'm doing wrong, and hoping someone can help me... I've got a desktop shortcut to the most recent version of the AppleWin emulator (1.25.0.3), and it works fine. I figured I'd add a command line to the Target to have the shortcut boot up a game. So now my Target looks like this: "c:\AppleWin.exe" -d1 "g:\apple II\Hobbit.dsk" The shortcut doesn't even boot up the emulator now - it just pauses my mouse for a second and then nothing. I've double-checked that I've got the path and the rom name correct. What am I missing here? Thanks for anyone who can give me some insight! Quote Link to comment Share on other sites More sharing options...
Osgeld Posted May 26, 2016 Share Posted May 26, 2016 (edited) I just associate *.dsk files to applewin try dropping the quotes around "c:\AppleWin.exe", you only really need those when dealing with files or directories with spaces in them (such as your disk image folder) Edited May 26, 2016 by Osgeld Quote Link to comment Share on other sites More sharing options...
david__schmidt Posted May 26, 2016 Share Posted May 26, 2016 (edited) -d1 has a long and troubled past... looks like trouble has returned. Some problem reports over time: https://github.com/AppleWin/AppleWin/issues/286https://github.com/AppleWin/AppleWin/issues/276https://github.com/AppleWin/AppleWin/issues/108 I just tried 1.25.0.4, and fix 276 seems to have solved it: https://github.com/AppleWin/AppleWin/releases/tag/v1.25.0.4 Edited May 26, 2016 by david__schmidt Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted May 26, 2016 Share Posted May 26, 2016 you might have to assoicate with command but looks like you fixed it. Quote Link to comment Share on other sites More sharing options...
buddyguy2 Posted May 26, 2016 Author Share Posted May 26, 2016 Osgeld - thanks, but David nailed it. Ugh... thanks David, that was exactly the problem. I even saw the same bug report and fix that you pointed out, but I just assumed the problem had resurfaced. I downloaded AppleWin just about two months ago, so I assumed I had the last version. I don't know how I wound up downloading v.1.25.0.3. Goofy. But thanks - the shortcut is working fine now. Quote Link to comment Share on other sites More sharing options...
