jt505001 Posted May 29, 2016 Share Posted May 29, 2016 I have a model Odyssey 2; it turns on and I get a video signal both with and without a game in, however, no game shows up om screen. Quote Link to comment Share on other sites More sharing options...
SSG Posted June 5, 2016 Share Posted June 5, 2016 Try cleaning the game? Quote Link to comment Share on other sites More sharing options...
jt505001 Posted June 6, 2016 Author Share Posted June 6, 2016 Yeah Quote Link to comment Share on other sites More sharing options...
SSG Posted June 6, 2016 Share Posted June 6, 2016 How do you know you have video signal if the game doesnt appear on the screen? Quote Link to comment Share on other sites More sharing options...
jt505001 Posted June 7, 2016 Author Share Posted June 7, 2016 The screen changes colour whenever the console is on Quote Link to comment Share on other sites More sharing options...
SSG Posted June 7, 2016 Share Posted June 7, 2016 It does this for all the games? Quote Link to comment Share on other sites More sharing options...
jt505001 Posted June 8, 2016 Author Share Posted June 8, 2016 Yes, I've tried it on 6 Quote Link to comment Share on other sites More sharing options...
CatPix Posted June 13, 2016 Share Posted June 13, 2016 You have to press Reset/ The red triangle button to start the game; as it says on the label? Quote Link to comment Share on other sites More sharing options...
jt505001 Posted June 13, 2016 Author Share Posted June 13, 2016 Tried it Quote Link to comment Share on other sites More sharing options...
SSG Posted June 16, 2016 Share Posted June 16, 2016 You are really not giving us enough information to give you less standard options. Quote Link to comment Share on other sites More sharing options...
jt505001 Posted June 16, 2016 Author Share Posted June 16, 2016 There is nothing else to say, I put in a game and the screen gives colour but no game Quote Link to comment Share on other sites More sharing options...
+atari2600land Posted June 16, 2016 Share Posted June 16, 2016 Does it say "SELECT GAME"? Quote Link to comment Share on other sites More sharing options...
jt505001 Posted June 18, 2016 Author Share Posted June 18, 2016 No, that's the whole problem Quote Link to comment Share on other sites More sharing options...
metarog Posted June 20, 2016 Share Posted June 20, 2016 Open up the console and clean the cartridge slot with an old toothbrush and some contact cleaner... then wipe down every pin with a q-tip. If that doesn't work check to make sure all the pins are making contact with the game (not too separated from each other). If no change then check under the cartridge slot and see if any solder is missing on the pins. Quote Link to comment Share on other sites More sharing options...
