ianoid Posted May 29, 2016 Share Posted May 29, 2016 That's right, a 99/4, not a 4A. I have a unit with bad video. It seems to start up with jumbled random text. Seems to respond to keys, and carts work, but all graphics are jumbled. Is this an easy obvious fix? I tried the unit with multiple power supplies. Quote Link to comment Share on other sites More sharing options...
dphirschler Posted May 29, 2016 Share Posted May 29, 2016 Does it look like this? http://atariage.com/forums/topic/228756-diagnose-this-sick-ti/?do=findComment&comment=3053085 Darryl Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 29, 2016 Share Posted May 29, 2016 Every TI with video problems so far was easily fixed by plugging in << THIS >>. If you don't wand to go that route, you'll have to spend valuable time trying to hunt down the culprit then order parts and get the soldering iron out and hope that fixes it. Good luck. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted May 29, 2016 Share Posted May 29, 2016 Compare your screen output with our "bad gallery" at http://www.ninerpedia.org/index.php?title=Troubleshooting 2 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 30, 2016 Share Posted May 30, 2016 (edited) If everything works except for the garbled video, you definitely have a bad VDP RAM chip or two. If you look here and here, you will find the original TI troubleshooting guide for the 99/4. You need both halves to get the complete manual. Edited May 30, 2016 by Ksarul Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 30, 2016 Share Posted May 30, 2016 If everything works except for the garbled video, you definitely have a bad VDP RAM chip or two. If you look here and here, you will find the original TI troubleshooting guide for the 99/4. You need both halves to get the complete manual. Any reason why it is not in one piece? I have the ability to combine PDFs. Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted May 30, 2016 Share Posted May 30, 2016 I just scanned it in that way based on available time--and never took the opportunity later to combine the two files. That size also made it small enough to send as an email attachment to the person I scanned it in for initially. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 30, 2016 Share Posted May 30, 2016 I just scanned it in that way based on available time--and never took the opportunity later to combine the two files. That size also made it small enough to send as an email attachment to the person I scanned it in for initially. I dig. Quote Link to comment Share on other sites More sharing options...
