Dmitry Posted May 31, 2016 Share Posted May 31, 2016 I'm trying to do this - several articles said it's possible, but they didn't include an example. I'm trying to use a different characterset midway down the screen, but obviously I'm doing something wrong. when I run this, only the last character set is used - for the entire screen. However the color changes work as expected. So, you don't just poke in the high byte of the character set location? .export _setup_dli_asm .import FONTADR, FONTADR2 .segment "CODE" _setup_dli_asm: ldy #<DLIRTN sty $0200 ldy #>DLIRTN sty $0201 RTS DLIRTN: WSYNC=$D40A COLOR0=$D016 COLOR1=$D017 COLOR2=$D018 COLOR3=$D019 COLOR4=$D01A ; color 4 is background PHA LDA #$00 STA WSYNC LDA #$E0 ; STA $02F4 LDA #10 STA COLOR0 ; PF0 black LDA #14 STA COLOR1 ; PF1 white LDA #6 ; STA COLOR2 ; PF2 darker grey LDA #34 ; STA COLOR3 ; PF3 red LDA #0 ; STA COLOR4 ; PF4, BAK is lighter grey LDA #<DLIRTN2 STA $0200 LDA #>DLIRTN2 STA $0201 PLA RTI DLIRTN2: PHA LDA #$00 STA WSYNC; LDA #>FONTADR2 STA $02F4 LDA #$C4 ; green STA COLOR2; LDA #<DLIRTN3 STA $0200 LDA #>DLIRTN3 STA $0201 PLA RTI DLIRTN3: PHA LDA #$00 STA WSYNC LDA #>FONTADR STA $02F4 LDA #10 STA COLOR0 ; set up this third one just for testing LDA #14 STA COLOR1 LDA #6 ; STA COLOR2 LDA #34 ; STA COLOR3 LDA #0 ; STA COLOR4 LDA #<DLIRTN STA $0200 LDA #>DLIRTN STA $0201 PLA RTI Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 31, 2016 Share Posted May 31, 2016 CHBAS ($02F4) is the OS shadow location of the hardware register CHBASE ($D409). The OS copies CHBAS to CHBASE in vertical blank. This means that you can change CHBAS without causing a glitch in the middle of the screen, but since you actually need to do that for a DLI handler, you need to write to CHBASE directly. Incidentally, you have the wrong names for the color registers. COLOR0-COLOR4 are the OS shadow registers at $02C4-02C8. The hardware color registers at $D016-D01A are called COLPF0-COLPF3 and COLBK. Quote Link to comment Share on other sites More sharing options...
Dmitry Posted May 31, 2016 Author Share Posted May 31, 2016 Thanks! Working now. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 31, 2016 Share Posted May 31, 2016 You could equally do what you want with the same block of code for 2 or more DLIs. Just maintain an index then keep stuff like chset values and colours in tables. That said, your program has a bug. When it's initializing there's no way to know which DLI will trigger first, so each run there's random chance of where each chset appears (of course the one that the OS sets in VBlank will be always right). The trick there is either use indexes and same routine like I said, then set the index value to 0 again in a VBlank Immediate routine. Or have the initialize part of your program wait for the active scanline to be outside the display. lda $14 ; get rtclock value waitvb cmp $14 beq waitvb ; wait until rtclock changes, this means the active scanline will be offscreen 1 Quote Link to comment Share on other sites More sharing options...
Dmitry Posted May 31, 2016 Author Share Posted May 31, 2016 well that's easily fixed then, I can just go to the vbi code I have already and add the line JSR _setup_dli_asm that'll keep it pointing to the first one, I should hope. It's good advice, the table would be more elegant. Quote Link to comment Share on other sites More sharing options...
MaPa Posted May 31, 2016 Share Posted May 31, 2016 Btw. the value stored into WSYNC does not matter, so you don't have to LDA #0 before, just STA/X/Y WSYNC. 1 Quote Link to comment Share on other sites More sharing options...
sanny Posted May 31, 2016 Share Posted May 31, 2016 It seems that you are using cc65. You can .include "atari.inc" and get all defines you defined manually. 2 Quote Link to comment Share on other sites More sharing options...
Dmitry Posted June 11, 2016 Author Share Posted June 11, 2016 btw small update on this, I did change to indexing. But, I find that changing a charset in a dli takes a lot of time, I don't know why. But I can do very little in one scan line, I'm often taking a second one. The charset command, by my eyes, isn't a lot of cycles...I mean to just STA ---but on the simulators if I do much else, it's going to go into the next scanline. Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 11, 2016 Share Posted June 11, 2016 The trick is to preload registers. How many you do depends on how many you've saved to the stack. But generally if you save A, X, Y to the stack you'll run past the point where a STA WSYNC would return control. At the least you can preload A. Also, if you do your calculations right you can do without the STA WSYNC altogether in some situations. As long as the DMA situation is fairly stable, ie PMGs are always active or not, fine scrolling of either type isn't active on that scanline, and the line isn't in wide DMA mode. Sometimes you just don't have enough time. It's at that point where you either have to sacrifice something, or use a blank line to free up more cycles. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted June 11, 2016 Share Posted June 11, 2016 Saving and reloading the index registers to and from some pre-defined ZP locations is faster than TXA/PHA, PLA/TAX, etc. Then you have a little more time and can pre-load registers as Rybags suggests. Load up A, X and Y before STA WSYNC, then STA/STX/STY to your hardware registers. You may need to load and store again (if you're hitting more than three registers), but at least the WSYNC store was pushed back somewhat and you did more work beforehand, so there's less to do in the horizontal blank. Quote Link to comment Share on other sites More sharing options...
