Txnathan Posted May 31, 2016 Share Posted May 31, 2016 Hi everyone New to the site and this is my first post. I dug my 2600 out of the attic for the first time in 25 years and this is what I see on the screen. Accompanied by a nasty sound or loud beep. I checked the voltage in and after the regulator chip and that is correct at 5volts after reg. I tried a new RF cable and no difference. Any ideas? Quote Link to comment Share on other sites More sharing options...
Txnathan Posted May 31, 2016 Author Share Posted May 31, 2016 Ok. I give up....how do you post pics? Is there a FAQ for that? Quote Link to comment Share on other sites More sharing options...
0078265317 Posted June 1, 2016 Share Posted June 1, 2016 I use blogger to make short blogs with photos. And then I just share the links here. Quote Link to comment Share on other sites More sharing options...
Txnathan Posted June 1, 2016 Author Share Posted June 1, 2016 (edited) Let's try this for the pics http://s1224.photobucket.com/user/nathand2/library/Atari Thanks for the tip by the way!! Edited June 1, 2016 by Txnathan Quote Link to comment Share on other sites More sharing options...
EdwardK Posted June 1, 2016 Share Posted June 1, 2016 had that happen on cartridges(more frequently with non atari carts without the little trap door) that were badly worn or needed a cleaning. Cleaning the contacts on the cartridge or adjusting the way it's seated in the systems cartridge slot might clear that up for you. Worth a try atleast. Quote Link to comment Share on other sites More sharing options...
chas10e Posted June 1, 2016 Share Posted June 1, 2016 yeah looks like a dirty or bad cart ... http://atariage.com/howto/clean_cartridges.html use a high percentage rubbing alcohol like 90% also while cart is still wet with the stuff run cart in & out of slot a few times to help clean that too ...on your hosting site , there are "share links" ... the "IMG" link is for forums Quote Link to comment Share on other sites More sharing options...
Txnathan Posted June 1, 2016 Author Share Posted June 1, 2016 Thanks. I'll try it tonight! Quote Link to comment Share on other sites More sharing options...
Txnathan Posted June 1, 2016 Author Share Posted June 1, 2016 That worked guys thanks! At first I tried it with an Activision cart but nothing changed. Tried another one and after a few attempts the concord was up. The first cart still won't play but I'll try to get a better look at the contacts in it. This console was stored in no Texas attic so it's nasty inside. Any advice for general clean up inside. Is it oK to spray some contact cleaner through the switches? I was thinking a light q-tip swabbing OD the rest of the circuitry to remove some of the dirt etc Quote Link to comment Share on other sites More sharing options...
chas10e Posted June 2, 2016 Share Posted June 2, 2016 That worked guys thanks! At first I tried it with an Activision cart but nothing changed. Tried another one and after a few attempts the concord was up. The first cart still won't play but I'll try to get a better look at the contacts in it. This console was stored in no Texas attic so it's nasty inside. Any advice for general clean up inside. Is it oK to spray some contact cleaner through the switches? I was thinking a light q-tip swabbing OD the rest of the circuitry to remove some of the dirt etc http://atariage.com/forums/topic/184296-slowcoders-guide-to-cleaning-up-your-2600/ Activision carts are more difficult to clean at times ... wrights copper clean should be at your local grocery store the games are always great though so well worth tinkering with Quote Link to comment Share on other sites More sharing options...
Txnathan Posted June 2, 2016 Author Share Posted June 2, 2016 Nice link. I'll take a look at my console again. It's very different from that one. Perhaps older or newer. The one in question is a 4 switch Atari I bought new in 81 I think. Still have the box. I'm happy to have it working again. 1 Quote Link to comment Share on other sites More sharing options...
