Steve Mynott Posted June 4, 2016 Share Posted June 4, 2016 I'm looking for a smallish (maybe 12 - 14" 4:3 LCD or similar) flat panel for mostly retro use and Raspberry PI. There are a bunch of cheapish Chinese ones for CCTV use which have a wide range of connectors (Composite, VGA, HDMI etc.) A friend just bought a "Sourcingbay 12" which looked good on Amazon but came with a hot pixel (bright white dot) and the connectors were very hard to access and its going back. Can anyone recommend anything like this? Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 4, 2016 Share Posted June 4, 2016 Ideally you'd want 16 KHz RGB which is what Amiga, ST, VBXE uses, as well as a few other older computers and consoles. Problem is they are very scarce though supposedly SCART fitted TVs will often support it. A possible untapped supply I've not yet investigated is monitors used with medical monitoring equipment. Although the problem there is they'd often be bunded with the rest of whatever large device it comes with, and often such things are used until they're virtually dead anyway. Problem 2 is that RGB will often be at the exclusion of the likes of S-Video, Composite, Component. Also, Component has supplanted RGB a long time back in home theatre applications in that it can provide almost as good quality with less connections. Quote Link to comment Share on other sites More sharing options...
Steve Mynott Posted June 5, 2016 Author Share Posted June 5, 2016 The monitor I tried looked quite bad at resolutions above 800x600 and not brilliant at that res. Wondering about a branded one rather than the cheap Chinese stuff. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted June 5, 2016 Share Posted June 5, 2016 Though prices vary on them, would a PS1 LCD screen suffice? Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted June 5, 2016 Share Posted June 5, 2016 If you can get by with "good clean" composite video, this little screen is peddled by various home security/surveillance sites on the web. http://www.security4thehome.com/accessories/docooler-8-inch-tft-lcd-color-video-monitor-screen-vga-bnc-av-input-with-remote-controller-for-pc-cctv-home-security-stand-rotating-screen/ Quote Link to comment Share on other sites More sharing options...
