budz2355 Posted June 4, 2016 Share Posted June 4, 2016 So when I updated my version of TIMXT to be compatible with Stuarts IB it changed the way that I "dial" an IP address. Previously I just entered ATZ, then atdt255.1.1.1,23 (insert IP,port). With the new version of TIMXT I was using the macros to dial out the same way, but it looked like this: C255.1.1.1,23 My question is previously I could manually type in any IP address I wanted, but now my keyboard appears to do nothing so I am limited to only the two BBSes in the macros. Am I doing something wrong? Thanks in advance for any help. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted June 4, 2016 Share Posted June 4, 2016 So when I updated my version of TIMXT to be compatible with Stuarts IB it changed the way that I "dial" an IP address. Previously I just entered ATZ, then atdt255.1.1.1,23 (insert IP,port). With the new version of TIMXT I was using the macros to dial out the same way, but it looked like this: C255.1.1.1,23 My question is previously I could manually type in any IP address I wanted, but now my keyboard appears to do nothing so I am limited to only the two BBSes in the macros. Am I doing something wrong? Thanks in advance for any help. I believe that when you set the UDS to the settings required for Stuarts browser you will not see any local echo if I remember right. If you change your settings back I beleive you will see echo but will have to dial out the normal way again. I tend to do this. Set it for Stuarts browser when I want to use that and then set it back so I can use TIMXT the way I have always been used to doing it. It only takes a few seconds to do it. Quote Link to comment Share on other sites More sharing options...
