artrag Posted July 2, 2016 Author Share Posted July 2, 2016 I ended with this, that works but it looks ugly VoicePlayerInit: PROCEDURE SndFlag = 1 nsfx = 17: rem test value on (nsfx) goto v0,v1,v2,v3,v4,v5,v6,v7,v8,v9,v10,v11,v12,v13,v14,v15,v16,v17,v18 v0: #frames = VARPTR frame0(0):goto ok v1: #frames = VARPTR frame1(0):goto ok v2: #frames = VARPTR frame2(0):goto ok v3: #frames = VARPTR frame3(0):goto ok v4: #frames = VARPTR frame4(0):goto ok v5: #frames = VARPTR frame5(0):goto ok v6: #frames = VARPTR frame6(0):goto ok v7: #frames = VARPTR frame7(0):goto ok v8: #frames = VARPTR frame8(0):goto ok v9: #frames = VARPTR frame9(0):goto ok v10: #frames = VARPTR frame10(0):goto ok v11: #frames = VARPTR frame11(0):goto ok v12: #frames = VARPTR frame12(0):goto ok v13: #frames = VARPTR frame13(0):goto ok v14: #frames = VARPTR frame14(0):goto ok v15: #frames = VARPTR frame15(0):goto ok v16: #frames = VARPTR frame16(0):goto ok v17: #frames = VARPTR frame17(0):goto ok v18: #frames = VARPTR frame18(0):goto ok ok: END VoicePlayer: PROCEDURE if peek(#frames)<>-1 then if (ECS) then Sound 5,peek(#frames+0),peek(#frames+3) Sound 6,peek(#frames+1),peek(#frames+4) Sound 7,peek(#frames+2),peek(#frames+5) else Sound 0,peek(#frames+0),peek(#frames+3) Sound 1,peek(#frames+1),peek(#frames+4) Sound 2,peek(#frames+2),peek(#frames+5) end if #frames = #frames+6 else SndFlag = 0 end if END Am I missing something ? Quote Link to comment Share on other sites More sharing options...
artrag Posted July 2, 2016 Author Share Posted July 2, 2016 (edited) I have a doubt... At the interrupt, the music player updates the PSG registers before the ON FRAME GOSUB procedure is called, doesn't it ? I'm trying to use Music and Voice at the same time Try this rom on psg and/or on ecs Use the keypads to activate the sfx On psg only, the music is stopped by the voice, so I guess that the the music player updates the PSG registers before my code is executed PS Music by First Spear psgLoFi.rom Edited July 2, 2016 by artrag 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted July 3, 2016 Author Share Posted July 3, 2016 (edited) I've released another version of the stand alone voice encoder In order to install it without having Matlab, follow the instructions in the readme.txt This time the encoder is specialized to use the PSG (3 channels) or the ECS (3 channels). You can pass (have to pass) on the command line the number of channels to be used in the encoding. The only two possible values are 3 and 5. In case of incorrect values, the encoder will assume 5 channels. The wav files have to go in wavs subdir. The data in the genarated *.bas files are periods and volumes ready to be loaded in the PSG at each ISR No noise added, only more precision in the pitch estimation. Let me know how it goes. The player (for 3 channels) can be modeled on this one INCLUDE "constants.bas" Mode 0,6,0,6,0 Wait Border 6,0 Scroll 4,4,0 For borderNew=0 to 200 Step 20 : Poke $200+borderNew, $2000: Poke $213+borderNew, $2000 : Next borderNew Wait Wait Print At 22 Color 5 , "Voice Samples" Print At 121 Color 6 , "-- ARTRAG" temp = peek($4000) poke $4000,temp+1 if peek($4000)=temp+1 then Print At 61 Color 7 , " on ECS " ECS = 1 else Print At 61 Color 7 , " on PSG " ECS = 0 end if if (ECS) then Sound 9,$FF,&00111000 else Sound 4,$FF,&00111000 end if Wait Play Simple Wait Play MyMusic Wait ON FRAME GOSUB VoicePlayer nsfx = 15 gosub VoicePlayerInit WAIT DEFINE DEF00,5,drawings WAIT x1=80 y1=56 WHILE CONT.B2=0 FOR X=1 TO 80 WAIT GOSUB test NEXT X FOR X=80 TO 1 STEP -1 WAIT GOSUB test NEXT X WEND Print At 195 Color (Rand and 7) , "Bye." For spinWait = 0 to 110 Wait Next endloop: GOTO endloop test: PROCEDURE SPRITE 0, ( 40+X) + VISIBLE + ZOOMX2, 20 + ZOOMY2, SPR00 + SPR_WHITE SPRITE 1, (120-X) + VISIBLE + ZOOMX2, 60 + ZOOMY2, SPR01 + SPR_BLUE SPRITE 2, 20 + VISIBLE + ZOOMX2, ( 8+X) + ZOOMY2, SPR02 + SPR_RED SPRITE 3, 140 + VISIBLE + ZOOMX2, (96-X) + ZOOMY2, SPR03 + SPR_TAN SPRITE 4, X1 + VISIBLE + ZOOMX2, (Y1- + ZOOMY4, SPR04 + SPR_GREEN IF CONT1.UP THEN IF Y1>0 THEN Y1=Y1-1 IF CONT1.DOWN THEN IF Y1<104 THEN Y1=Y1+1 IF CONT1.LEFT THEN IF X1>0 THEN X1=X1-1 IF CONT1.RIGHT THEN IF X1<168 THEN X1=X1+1 nsfx = CONT1.KEY if (nsfx<12) and (SndFlag=0) then gosub VoicePlayerInit end if nsfx = CONT2.KEY if (nsfx<12) and (SndFlag=0) then nsfx = nsfx+11 gosub VoicePlayerInit end if END VoicePlayerInit: PROCEDURE SndFlag = 1 on (nsfx) goto v0,v1,v2,v3,v4,v5,v6,v7,v8,v9,v10,v11,v12,v13,v14,v15,v16,v17,v18 SndFlag = 0:goto ok v0: #frames = VARPTR frame0(0):goto ok v1: #frames = VARPTR frame1(0):goto ok v2: #frames = VARPTR frame2(0):goto ok v3: #frames = VARPTR frame3(0):goto ok v4: #frames = VARPTR frame4(0):goto ok v5: #frames = VARPTR frame5(0):goto ok v6: #frames = VARPTR frame6(0):goto ok v7: #frames = VARPTR frame7(0):goto ok v8: #frames = VARPTR frame8(0):goto ok v9: #frames = VARPTR frame9(0):goto ok v10: #frames = VARPTR frame10(0):goto ok v11: #frames = VARPTR frame11(0):goto ok v12: #frames = VARPTR frame12(0):goto ok v13: #frames = VARPTR frame13(0):goto ok v14: #frames = VARPTR frame14(0):goto ok v15: #frames = VARPTR frame15(0):goto ok v16: #frames = VARPTR frame16(0):goto ok v17: #frames = VARPTR frame17(0):goto ok v18: #frames = VARPTR frame18(0):goto ok ok: END VoicePlayer: PROCEDURE if SndFlag then if peek(#frames)<>-1 then if (ECS) then Sound 5,peek(#frames+0),peek(#frames+3) Sound 6,peek(#frames+1),peek(#frames+4) Sound 7,peek(#frames+2),peek(#frames+5) else Sound 0,peek(#frames+0),peek(#frames+3) Sound 1,peek(#frames+1),peek(#frames+4) Sound 2,peek(#frames+2),peek(#frames+5) end if #frames = #frames+6 else SndFlag = 0 if (ECS) then Sound 5,,0 Sound 6,,0 Sound 7,,0 Sound 9,0,$38 else Sound 0,,0 Sound 1,,0 Sound 2,,0 Sound 4,0,$38 end if end if end if END 'ASM ORG $C100 CONST nfiles = 19 CONST nvoices = 3 frame0: include "gradiusgaiden_0000.wavfrm_inty.bas" DATA -1 frame1: include "gradiusgaiden_0001.wavfrm_inty.bas" DATA -1 frame2: include "gradiusgaiden_0002.wavfrm_inty.bas" DATA -1 frame3: include "gradiusgaiden_0003.wavfrm_inty.bas" DATA -1 frame4: include "gradiusgaiden_0004.wavfrm_inty.bas" DATA -1 frame5: include "gradiusgaiden_0005.wavfrm_inty.bas" DATA -1 frame6: include "gradiusgaiden_0006.wavfrm_inty.bas" DATA -1 frame7: include "gradiusgaiden_0007.wavfrm_inty.bas" DATA -1 frame8: include "gradiusgaiden_0008.wavfrm_inty.bas" DATA -1 frame9: include "gradiusgaiden_0009.wavfrm_inty.bas" DATA -1 frame10: include "gradiusgaiden_0100.wavfrm_inty.bas" DATA -1 frame11: include "gradiusgaiden_0111.wavfrm_inty.bas" DATA -1 frame12: include "gradiusgaiden_0180.wavfrm_inty.bas" DATA -1 frame13: include "gradiusgaiden_0209.wavfrm_inty.bas" DATA -1 frame14: include "gradiusgaiden_0350.wavfrm_inty.bas" DATA -1 frame15: include "gradiusgaiden_0615.wavfrm_inty.bas" DATA -1 frame16: include "gradiusgaiden_1022.wavfrm_inty.bas" DATA -1 frame17: include "gradiusgaiden_1035.wavfrm_inty.bas" DATA -1 frame18: include "gradiusgaiden_9999.wavfrm_inty.bas" DATA -1 drawings: REM Invader BITMAP "#..##..#" BITMAP "########" BITMAP ".#.##.#." BITMAP ".######." BITMAP "..####.." BITMAP "..#..#.." BITMAP "..#..#.." BITMAP ".##..##." REM Spaceship BITMAP "...##..." BITMAP "...##..." BITMAP "..####.." BITMAP "..#..#.." BITMAP "..####.." BITMAP "..####.." BITMAP ".######." BITMAP "##.##.##" REM Stickman BITMAP "...##..." BITMAP "...##..." BITMAP ".######." BITMAP "...##..." BITMAP "...##..." BITMAP "..####.." BITMAP "..#..#.." BITMAP ".##..##." REM Lama BITMAP ".##....." BITMAP "###....." BITMAP ".##....." BITMAP ".#######" BITMAP ".######." BITMAP ".##..##." BITMAP ".##..##." BITMAP "###.###." REM SDK Logo BITMAP "..#.#..." BITMAP ".#####.." BITMAP ".#.##.#." BITMAP ".####.#." BITMAP "###.##.#" BITMAP "###.##.#" BITMAP ".#.#####" BITMAP "...#####" ASM ORG $D000 REM music courtesy of First Spear MyMusic: Data 4 Music - , - , - Music D3#X , - , - Music C3# , - , - Music D3# , - , - Music - , - , - Music D3# , - , - Music S , - , - Music D3# , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , G2#W , - Music C3# , - , - Music B2 , G2# , - Music A2# , - , - Music G2# , - , - Music F2# , - , - Music S , - , - Music S , - , - Music S , - , - Music G2# , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , G2# , - Music S , - , - Music S , G2# , - Music - , - , - Music G2# , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music F2# , - , - Music S , - , - Music S , G2# , - Music S , - , - Music A2# , G2# , - Music S , - , - Music C2# , - , - Music S , - , - Music E2 , - , - Music S , - , - Music S , - , - Music S , - , - Music F2# , - , - Music S , - , - Music A2# , - , - Music S , - , - Music C3# , - , - Music S , - , - Music S , - , - Music S , - , - Music A2# , G2# , - Music S , - , - Music S , G2# , - Music S , - , - Music B2# , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music S , - , - Music repeat Edited July 3, 2016 by artrag 1 Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 5, 2016 Share Posted July 5, 2016 Very cool. I can't get it to work quite yet but I think I'm close. I think I have the converter working - at least, it's creating .bas files for me for the sample .wav files you included. I'm just taking the DATA statements from one .bas file and pasting it into frame0 for now - that should work, yes? If I follow the code, frame0, frame1, etc - these are just references to the individual sound clips. Right now I just get electronic noise, whether I use the ECS or not. And whether or not I use your new .bas files or the ones I'm generating. It feels close, so I'll keep poking at it. Hopefully someone else figures it out because I just feel like I'm missing something obvious. Quote Link to comment Share on other sites More sharing options...
artrag Posted July 5, 2016 Author Share Posted July 5, 2016 (edited) You have to run the encoder using 3 channels and not 5.Type voicenc 3 from command-line. The .bas files included have 5 channels, so the cannot work in my template player as is Edited July 5, 2016 by artrag Quote Link to comment Share on other sites More sharing options...
artrag Posted July 5, 2016 Author Share Posted July 5, 2016 (edited) If you want to use 5 channels on inty you could play 3 channels on psg and 2 on ecs You have to modify the player accordingly. One could also play the first 3 channels on psg and skip the last 2 if ecs is not present. Edited July 5, 2016 by artrag Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 5, 2016 Share Posted July 5, 2016 Thanks - I got it working! I missed your comment about this player being for one channel. It sounds decent. Now I want to modify it for including the ECS. Why 5 channels and not 6? Quote Link to comment Share on other sites More sharing options...
artrag Posted July 5, 2016 Author Share Posted July 5, 2016 (edited) with 5 channels use +0,+1,+2,+3,+4 as periods and +5,+6,+7,+8,+9 as volumes.Move #frames of 10 positions each isr.Play these data on 3 channels of psg and 2 of the ecs.I have limited the encoder to 5 channels because of the msx (they are used in the scc chip that has 5 channels). I could extend the processing to any number of tones in case of need. Edited July 5, 2016 by artrag Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 6, 2016 Share Posted July 6, 2016 OK kids, here's a ROM with a bunch of unrelated sound clips, all using 5 sound channels so you'll need the ECS turned on in your emulator. I first dug up an old WAV archive that I probably haven't touched since the 90s, and found the ones that converted the best. I then grabbed a bunch of random movie clips from some website and did the same. This is about as clear as this method gets when it comes to using random audio files. Personally, I find some of them remarkably clear. I can easily identify the actor - granted, these are all lines I've heard a hundred times so that helps. Try these, they should most/all work: 6-12 on controller 1 1-6 on controller 2 I'm curious if other people can identify the clips. Some are better than others. I find that this method works well on higher pitched voices - I'm going to try to find some female voices and see if that works better. There's one VERY clear clip but that's because it's not a human voice I didn't modify artrag's program beyond the speech generation so it still has his sprites and whatnot in there. None of it does anything, just press keypad buttons to trigger the audio clips. A dozen clips, maybe 20-30 seconds in total, give us a ROM that's about half the maximum possible size. Kinda impressive all things considered. This would have blown people's minds in 1980. Warning: probably NSFW. There's a very 90s clip in here, those who know who it is will understand the warning. Edit - on a real console, they're not quite as clear. The RF audio does degrade them a bit. pcm_voice_samples.rom Quote Link to comment Share on other sites More sharing options...
+Tarzilla Posted July 6, 2016 Share Posted July 6, 2016 OK kids, here's a ROM with a bunch of unrelated sound clips, all using 5 sound channels so you'll need the ECS turned on in your emulator. I first dug up an old WAV archive that I probably haven't touched since the 90s, and found the ones that converted the best. I then grabbed a bunch of random movie clips from some website and did the same. This is about as clear as this method gets when it comes to using random audio files. Personally, I find some of them remarkably clear. I can easily identify the actor - granted, these are all lines I've heard a hundred times so that helps. Try these, they should most/all work: 6-12 on controller 1 1-6 on controller 2 I'm curious if other people can identify the clips. Some are better than others. I find that this method works well on higher pitched voices - I'm going to try to find some female voices and see if that works better. There's one VERY clear clip but that's because it's not a human voice I didn't modify artrag's program beyond the speech generation so it still has his sprites and whatnot in there. None of it does anything, just press keypad buttons to trigger the audio clips. A dozen clips, maybe 20-30 seconds in total, give us a ROM that's about half the maximum possible size. Kinda impressive all things considered. This would have blown people's minds in 1980. Warning: probably NSFW. There's a very 90s clip in here, those who know who it is will understand the warning. Edit - on a real console, they're not quite as clear. The RF audio does degrade them a bit. I understood them all, but about half took repeated listening. certain parts of some of the sentences were definitely clearer than others. Reminds me of the old "Help, I'm trapped in the computer" sample from back in the original IBM Xt single speaker days. I still think we are better off making the samples work with the Intellivoice since it off-loads the work onto the device. Bank switch a bunch of cleaned up samples and the sky is the limit (or at least LTO board specs are the limit) 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted July 6, 2016 Author Share Posted July 6, 2016 (edited) If you play the first 3 tones on psg and the last 2 on ecs it will sound decent even is ecs is absent Edited July 6, 2016 by artrag Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 6, 2016 Share Posted July 6, 2016 I still think we are better off making the samples work with the Intellivoice since it off-loads the work onto the device. Bank switch a bunch of cleaned up samples and the sky is the limit (or at least LTO board specs are the limit) We are, but the only people who've figured out how to load allophones onto the Intellivoice seem to think there's some lucrative market they need to corner, and as such are apparently unwilling to share their tools with the community at large. I'm sure as heck not smart enough to figure out how to do it Quote Link to comment Share on other sites More sharing options...
+Tarzilla Posted July 6, 2016 Share Posted July 6, 2016 We are, but the only people who've figured out how to load allophones onto the Intellivoice seem to think there's some lucrative market they need to corner, and as such are apparently unwilling to share their tools with the community at large. I'm sure as heck not smart enough to figure out how to do it You also aren't smart enough to convert between Pacific and Mountain timezones Quote Link to comment Share on other sites More sharing options...
artrag Posted July 6, 2016 Author Share Posted July 6, 2016 One of the possibile improvements could be to try to keep into account the fact the psg generates square waves and not sine waves. If you play the msx rom generated by the encoder with an scc cartridge inserted in slot 2, you will find that even 6 psg channels (psg + ecs) sound worse than the 5 scc channels (configured as tones). Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 6, 2016 Share Posted July 6, 2016 You also aren't smart enough to convert between Pacific and Mountain timezones Maybe I live in Phoenix - I live in both. Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 6, 2016 Share Posted July 6, 2016 One of the possibile improvements could be to try to keep into account the fact the psg generates square waves and not sine waves. If you play the msx rom generated by the encoder with an scc cartridge inserted in slot 2, you will find that even 6 psg channels (psg + ecs) sound worse than the 5 scc channels (configured as tones). Ah. That would explain why certain samples really sound clipped. Makes sense, given my limited understanding of audio. Quote Link to comment Share on other sites More sharing options...
artrag Posted July 6, 2016 Author Share Posted July 6, 2016 (edited) Just to be sure, have you enabled correctly the tone channels on the two psgs in your player? You should use sound command with parameters 4 and 9 indicating the bit masks corresponding to the 5 channels you are feeding. To be honest, your results sound very bad. I would bet you are playing only 2 channels out of 5. Maybe, just to be sure, if you send me your wav files, I could try to convert them and double check the result. Edited July 6, 2016 by artrag Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 6, 2016 Share Posted July 6, 2016 Just to be sure, have you enabled correctly the tone channels on the two psgs in your player? You should use sound command with parameters 4 and 9 indicating the bit masks corresponding to the 5 channels you are feeding. You shouldn't need to - sound channels work automatically with IntyBASIC. I essentially commented out the IF (ECS) lines, so your SOUND 4 and SOUND 9 commands are being issued continually anyway. The player is just this: if SndFlag then if peek(#frames)<>-1 then Sound 0,peek(#frames+0),peek(#frames+5) Sound 1,peek(#frames+1),peek(#frames+6) Sound 2,peek(#frames+2),peek(#frames+7) Sound 5,peek(#frames+3),peek(#frames+ Sound 6,peek(#frames+4),peek(#frames+9) #frames = #frames+10 else SndFlag = 0 Sound 5,,0 Sound 6,,0 Sound 7,,0 Sound 9,0,$38 Sound 0,,0 Sound 1,,0 Sound 2,,0 Sound 4,0,$38 end if end if Quote Link to comment Share on other sites More sharing options...
artrag Posted July 6, 2016 Author Share Posted July 6, 2016 Try this before the on frame gosub Sound 9,$FF,&00111000 Sound 4,$FF,&00111000 Quote Link to comment Share on other sites More sharing options...
First Spear Posted July 6, 2016 Share Posted July 6, 2016 I like the idea of having the Intellivoice do the work, but I also like the idea of not having another box daisy chained to the console. Maybe we will reach a level where we can build to either option, Intellivoice for in-game sound with clarity that doesn't eat the main CPU and non-Intellivoice for adding flavor/punctuation to a game where resource contention is not an issue. I understood them all, but about half took repeated listening. certain parts of some of the sentences were definitely clearer than others. Reminds me of the old "Help, I'm trapped in the computer" sample from back in the original IBM Xt single speaker days. I still think we are better off making the samples work with the Intellivoice since it off-loads the work onto the device. Bank switch a bunch of cleaned up samples and the sky is the limit (or at least LTO board specs are the limit) Quote Link to comment Share on other sites More sharing options...
artrag Posted July 6, 2016 Author Share Posted July 6, 2016 This technique does not eat practically any cpu. Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 6, 2016 Share Posted July 6, 2016 Try this before the on frame gosub Sound 9,$FF,&00111000 Sound 4,$FF,&00111000 They're both in there - I just commented out the IF ECS check. Like I said, you shouldn't need to set the mixer at all for these. SOUND 0-2 and 5-7 "just work" without touching the mixer register. Quote Link to comment Share on other sites More sharing options...
+Tarzilla Posted July 6, 2016 Share Posted July 6, 2016 This technique does not eat practically any cpu. No, it eats sound and music, interrupting any music playing or any sound effects in progress. That would be annoying just to have a sound sample, hence letting the Intellivoice do the work it was designed to do...play samples. Quote Link to comment Share on other sites More sharing options...
freewheel Posted July 6, 2016 Share Posted July 6, 2016 This is one of the samples that I thought converted pretty well. See if you can improve on it. gameover.wav Quote Link to comment Share on other sites More sharing options...
artrag Posted July 6, 2016 Author Share Posted July 6, 2016 (edited) No, it eats sound and music, interrupting any music playing or any sound effects in progress. That would be annoying just to have a sound sample, hence letting the Intellivoice do the work it was designed to do...play samples. Almost no cpu used and if you have ECS, no music is interrupted. Maybe you should release some coding tool for intellivoice before complaining about this method. I'm pretty sure Intellivoice is owned by less than 1/10 the active intellevision user base, this could explain why none want to spend energies on a niche of a niche .... Edited July 6, 2016 by artrag Quote Link to comment Share on other sites More sharing options...
