BIGHMW Posted June 12, 2016 Share Posted June 12, 2016 I was just wondering if my newly-obtained a/v-modded 4-port 5200 (I paid $300.00 for it on eBay...and yes! it DOES have an asterisk next to the serial number although the numbers next to the * are kinda faint), in which I bought for my $200 39" Insignia 720p HDTV (model no. 39-D220-NA16) I got from Best Buy, will work with the VCS adapter or not (CX55). I read that normally it should work fine with 5200 units with that asterisk in it. However I have read that there are some adapter compatibility issues with 5200 units with the audio/video/power jack mod done to them (with both the RF cable and that proprietary auto-switchbox removed), so before I order the VCS adapter from Best Electronics, or go for one on eBay, I just need some answers to those questions from all my fellow Atarians out there. Thanks, Ray Jackson Proud Atarian since 1983 My first 5200 unit was a USA-made 4-port (Serial No. 141101) that I got for my 17th Birthday back in 1983, retired April 2016 after getting an a/v/power-modded 5200 unit Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted June 12, 2016 Share Posted June 12, 2016 The AV mods disable the AV and power I believe from the cart port section, hence the VCS adapter doesn't work with any of the AV mods that are available for the 5200 that I'm aware of. Best to get yourself a 2 port unit and mod that for AV, so you can use the VCS adapter in the 4 port unit. But I'm sure it would be cheaper still, to just get a 2600 in addition to your 5200 and call it a day. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted June 12, 2016 Share Posted June 12, 2016 Yes cheaper but does not save space. Quote Link to comment Share on other sites More sharing options...
Everett1954 Posted June 13, 2016 Share Posted June 13, 2016 I can tell you for certain that the CX-55 does not work with an A/V modded 2 port either. If your A/V mod has S-Video also it has a small circuit board that takes the video signals off before they reach the RF Modulator, so even trying to use the RF modulator will not work also. The composite Video and Audio output from the CX-55 go to two pins (24 &30) on the 5200 cart slot (if it has been modified or two port) that go to the RF modulator. There is a possibility that wires can be run from these two pins to separate jacks or to the current composite jack and audio using a DPDT switch , where one position is for regular 5200 carts the other for the CX-55. I am in the progress of trying to do this with my A/V modded 2-port 5200, so it has not tested yet if it works, theory only. The easiest thing to do is get a 2600 or 7800 that can be easily a/v modded. Hope this helps. 2 Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted June 21, 2016 Share Posted June 21, 2016 A bout time someone checks in to this. I'll be keeping an eye on this, I like using my CX-55. 1 Quote Link to comment Share on other sites More sharing options...
bikeguychicago Posted June 22, 2016 Share Posted June 22, 2016 A 2600jr doesn't take up that much space. Quote Link to comment Share on other sites More sharing options...
BIGHMW Posted June 25, 2016 Author Share Posted June 25, 2016 A 2600jr doesn't take up that much space. I would love to get a near-mint (preferably a/v-modded) 2600 jr. with the "Atari 2600" short rainbow on the bezel (similar to the "Atari 5200" short rainbow on it), that would go perfect with my 5200 as they will look almost the same except for the size of course. I already own a few CX24 sticks, two Wico ball joysticks, and also two 2600 trak-balls (I also have two Redemption 5200/2600 adapters and also two Redemption 5200/7800 adapters too), so If anyone has a 2600 jr (short rainbow version) they would like to sell me then go ahead and PM me about it (and please do include pics) Quote Link to comment Share on other sites More sharing options...
chavert Posted November 6, 2016 Share Posted November 6, 2016 There is a possibility that wires can be run from these two pins to separate jacks or to the current composite jack and audio using a DPDT switch , where one position is for regular 5200 carts the other for the CX-55. I am in the progress of trying to do this with my A/V modded 2-port 5200, so it has not tested yet if it works, theory only. Me too, i'd like to run my CX55 with my 5200 console in av mode. Anyone has the answer ? Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted November 6, 2016 Share Posted November 6, 2016 Me too, i'd like to run my CX55 with my 5200 console in av mode. Anyone has the answer ? Not unless you slapped in an AV mixer in the 5200. Quote Link to comment Share on other sites More sharing options...
Everett1954 Posted November 7, 2016 Share Posted November 7, 2016 Sorry I sold my CX-55 before I was able to try what I think is the workaround (fix). Quote Link to comment Share on other sites More sharing options...
SoundGammon Posted November 7, 2016 Share Posted November 7, 2016 Shouldn't be too hard to do! Take the video & audio output of the adapter and tie them to the video & audio out of the mod! Might need to use a couple of resistors, but should work! The 7800 had a video in from the expansion port and sent it to the RF mixer! Quote Link to comment Share on other sites More sharing options...
chavert Posted November 8, 2016 Share Posted November 8, 2016 awesome https://www.youtube.com/watch?v=Q79DwRO4w7w 1 Quote Link to comment Share on other sites More sharing options...
