the_crayon_king Posted June 13, 2016 Share Posted June 13, 2016 While I do see that there are HDMI, RGB and vga options available I figured I would put this out there for anyone interested: Uses info from here: http://www94.pair.com/jsoper/cv_svideo.html I have tested everything except for the CV mixing part of the board (as this is a newer revision). If someone knows whether this will work for composite and/or if the diodes are necessary please let me know. Link to files: https://easyeda.com/hotdog6394/Colecovision-ug93lDxP7 I have many other boards for many other systems coming out very soon but can only post them as fast as I can receive and test the boards. License is: CC-BY-NC-SA 3.0 2 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted June 14, 2016 Share Posted June 14, 2016 what does the following connect to? LUIN LUO CVO CHO Quote Link to comment Share on other sites More sharing options...
the_crayon_king Posted June 14, 2016 Author Share Posted June 14, 2016 what does the following connect to? LUIN LUO CVO CHO LUIN = Luma in or Y. LUO = Luma Out CVO = Composite Video Out. CHO = Chroma Out. As said before I have only tested the S-video portion of this which would be LU and CH. 1 Quote Link to comment Share on other sites More sharing options...
