Bikerbob Posted June 17, 2016 Share Posted June 17, 2016 I have an 800xl which I just got working by finding the bad ram chip.. now it runs.. boots anything fine.. keyboard is good. Went to play a game.. and at the very least the trigger does not work on any joystick I use.. and on another 800xl np. SO.. is cold or broken solder joints an issue on some machines? is that what I should be looking for? Also some joysticks I have just dont seem to work that great.. NOW i am wondering.. is the joystick the issue? or the port? Anything easy to test with? if I had the board out.. could I cross or connect a couple of pins and see if I get the port to work? What about testing joysticks? any program? I see the 2600 people made a tester.. but I could use a multi meter with knowing the pin out.. and just do a continuity test right? thanks James Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted June 17, 2016 Share Posted June 17, 2016 Swap joysticks. If it's the same problem, make sure all the pins are there on the port. If that's not it, touch up solder points. Might be ANTIC. Quote Link to comment Share on other sites More sharing options...
RodCastler Posted June 17, 2016 Share Posted June 17, 2016 (edited) You may want to re-seat your gtia chip as well, which reads the trigger button. About your question on the multimeter, yes it's a continuity test what you could do, but I doubt that's the issue if all of your joysticks fail equally. 10 ? strig(0): goto 10 That's your basic trigger tester. if the value changes when pushing the trigger, you're good. use strig(1) for the other port. Edited June 17, 2016 by RodCastler Quote Link to comment Share on other sites More sharing options...
Bikerbob Posted June 24, 2016 Author Share Posted June 24, 2016 After a reflow.. solder of the joystick pins on the MB we are back to A1+ Sometimes the easiest fix.. is the easiest James 1 Quote Link to comment Share on other sites More sharing options...
shoestring Posted June 25, 2016 Share Posted June 25, 2016 There's a basic program you can key in and run that will allow you to test both joyports. I did just that after wiring up my supergun joystick to use on the Atari. Do a search on google for the basic program. Quote Link to comment Share on other sites More sharing options...
