WIZZARD77 Posted June 21, 2016 Share Posted June 21, 2016 I was thinking of purchasing a Surface tablet with Win8.1 and was wondering if anyone has had any experience running APE and an Atarimax SIO2USB on one of these. It has a full size usb 3.0 port so I don't see why it won't work, but I might be overlooking something. Quote Link to comment Share on other sites More sharing options...
Rybags Posted June 21, 2016 Share Posted June 21, 2016 SIO2USB might mean the battery life isn't as long but shouldn't affect it too much. Though with such use you'd probably just hang it off the AC adaptor anyway. Quote Link to comment Share on other sites More sharing options...
+Larry Posted June 21, 2016 Share Posted June 21, 2016 The closest I can come to giving you an answer is that I've used registered APE with the Atarimax USB adapter with a Win 7-64 laptop and it works fine. I'd look at the Atarimax forum and see if there is anything posted about Win 8.x. I believe it should work, but Win 8.x has a few quirks. I've actually upgraded to Win 10, but haven't tried that with APE. Considered going to Win 10 with the Surface? (I presume you can if you wish?) -Larry Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted June 21, 2016 Author Share Posted June 21, 2016 Thanks for the replies I might pick it up. It would make things easier than having to have a laptop or pc chained to my Atari all the time. Quote Link to comment Share on other sites More sharing options...
WIZZARD77 Posted June 27, 2016 Author Share Posted June 27, 2016 Just an update I received my Surface Pro and with the 64bit drivers off the forum I have tested APE in Win 8, WIn 8.1, and Win 10 and it works great. The Surfaces USB port powers the Sio2usb device perfectly. 1 Quote Link to comment Share on other sites More sharing options...
MEtalGuy66 Posted June 30, 2016 Share Posted June 30, 2016 sio2usb is a german made device that lets you plug usb sticks into your atari. What you are referring to is the USB version of SIO2PC.. Quote Link to comment Share on other sites More sharing options...
kogden Posted June 30, 2016 Share Posted June 30, 2016 I have an Asus Vivotab Note 8 tablet running Win 8.1. With a USB OTG adapter w/ power input I can use an SIO2PC interface just fine. Just make sure it's not one of the mutant ARM-based WinRT tablets. The real Surface has a real USB port I believe. Quote Link to comment Share on other sites More sharing options...
