Heaven/TQA Posted July 7, 2016 Share Posted July 7, 2016 i did some quick tests of drawing via "sprites" is faster with CPU or with Suzy... and ironicly I found out: - Poly drawing is faster with sprites - sprite objects are faster with hardware (yeah obvious) - pixel effects like drawing 1 x y size slices are slower than done only by CPU (like 40x chained together) that was quite a suprise but I guess the SCB overhead is causing that... I personally thought that the 16mhz "blitter" will outperform the 4mhz 65sc02... but highly optimised code seems to outperform in some cases. What is your experience? for clear screen or paste logos etc I still use suzy... and the maths operations in suzy are running "parallel" to cpu so massive gain here, too. 1 Quote Link to comment Share on other sites More sharing options...
+selgus Posted January 5, 2017 Share Posted January 5, 2017 I'm assuming you did these tests on real hardware and not emulation.. do you have the actual timings you could post? Would be interesting to see the deltas. I'm in the process of writing my Lynx engine and one of the questions I had was around accessing the display buffer while SUZY was doing it's sprite rendering. Quote Link to comment Share on other sites More sharing options...
+xucaen Posted January 5, 2017 Share Posted January 5, 2017 Pixel effects, I you mean what I think you mean, are CPU intensive because of the calculations involved. Quote Link to comment Share on other sites More sharing options...
ThomH Posted March 7, 2017 Share Posted March 7, 2017 It'd be interesting to know what tests you applied for the 1 x y case; can you provide any more information on that? How many different values of y were tested? Was your CPU routine drawing masked sprites, with a full read/modify/write? Were you scaling? Did you compare speeds if also using a collision buffer? Quote Link to comment Share on other sites More sharing options...
