AL01 Posted July 12, 2016 Share Posted July 12, 2016 Hello everybody. I need some help...... I just AV modded my 2600 and when I would turn it on or screw with the video wire, (on and off the contact) the picture would flash in color and then would revert to this: BUT when I would put pressure on the wire onto the plate the picture would revert to color. I thought that the wire trace was broken so I repaired it, which didn't make much of a difference except putting pressure onto that general are would produce color. I though it could be a resistor, so I removed it, which didn't solve the color problem but made the picture clearer. I would appreciate any tips or help, I think that this problem has to do more with the PCB than anything else..... Thanks Again! Quote Link to comment Share on other sites More sharing options...
AL01 Posted July 12, 2016 Author Share Posted July 12, 2016 I have partially solved the problem by jumping R209 but I am getting a flashy picture although it is in color. Quote Link to comment Share on other sites More sharing options...
