BrianBeuken Posted July 19, 2016 Share Posted July 19, 2016 Hi all I wonder if I can get some collective help for a strange problem I am having. i've been working on a CV game for some time now, its a collection of mini games and a menu system to tie them together and code wise its all done and dusted, it works perfectly on every emulator I have found, but when I test it on hardware I get a very strange and apparently random corruption of my sprites but only on some of the games, and not always the same ones. I am using the correct terminators in the sprite list I send to the video. and I even make an extra effort to ensure the sprite attrib memory is filled with 192's before I dump my sprite list. but on some of my sub games, the sprites just go crazy.. I can reposition the games and the issue vanishes, though will crop up in another game or not appear again unless I add a few bytes of code. I don't have enough memory now to actrually just add padding until it stops so I have to find a fix.. I've re-written my sprite manager several times now, assuming I'd made some error, but the problem keeps coming back at some other point no matter what methods i use to build the sprite patterns (games usually have 2-3 16x16's to make a game char) The games are arranged to minimise sprite flicker but if it does occur it alters priority to reduce the flicker.. Its very frustrating, the only thing I can think of is if there is some area of ROM or RAM that I am not supposed to be accessing, though I see nothing in the docs that suggest that. So anyone know what is going on? I really want to get this game out on cart but until I can be sure it works on hardware I can' t release it. . Quote Link to comment Share on other sites More sharing options...
newcoleco Posted July 19, 2016 Share Posted July 19, 2016 (edited) Maybe your game is simply trying to update sprites a bit too fast while the screen is refreshing, in this case, uses extra NOPs between commands 'IN' and 'OUT' to update VRAM instead of an 'OTIR' single command. Another way is to update sprites right at each NMI interruption to avoid updating them while the screen is redrawn, and if you already do this, it might be done just a bit too late; so put it right at start of the NMI if possible. That`s all I can say without looking at the code directly. Edited July 19, 2016 by newcoleco 1 Quote Link to comment Share on other sites More sharing options...
DuggerVideoGames Posted July 19, 2016 Share Posted July 19, 2016 Unfortunately, I cannot be of any help to you on this; however, I can acknowledge that this does in fact happen. I've seen games that worked on emulators on a laptop, yet have glitched-out graphics on a console's emulator, thus making it impossible to see what you are doing. I've seen games that others played on their computers just fine, yet some of those same games freeze and are unable to be played on console emulators.I don't know what the causes or solutions are to these problems, but I'm more than glad to acknowledge that they indeed do happen and you are not losing your mind. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted July 19, 2016 Share Posted July 19, 2016 The Colecovision VDP fails if data is written too fast, so far no emulator "emulates" this. I've cycle counting in CoolCV so it could issue a warning, but the code isn't enabled for general purpose. One typical example is using this: LD HL,DUMP_TABLE LD B,4 LD C,VDP_PORT label: OUTI ; 16 cycles - This works JR NZ,label ; 12 cycles - label: OUTI ; 16 cycles - This doesn't work sometimes JP NZ,label ; 10 cycles - label: OUTI ; 16 cycles - This doesn't work always OUTI ; 16 cycles - OUTI ; 16 cycles - OUTI ; 16 cycles - This means you must be sure at least 28 cycles of instructions are happening with each OUT. OUT (VDP),A ; 12 cycles - This doesn't work OUT (VDP),A ; 12 cycles OUT (VDP),A ; 12 cycles - This will work NOP ; 4 cycles NOP ; 4 cycles NOP ; 4 cycles NOP ; 4 cycles OUT (VDP),A ; 12 cycles 3 Quote Link to comment Share on other sites More sharing options...
BrianBeuken Posted July 20, 2016 Author Share Posted July 20, 2016 This sounds very promising, thanks nanochess, I'm back home this week and will try this again on my hardware and report back to you Brian 1 Quote Link to comment Share on other sites More sharing options...
