popmilo Posted July 20, 2016 Share Posted July 20, 2016 How to get max free ram and use custom charset above $d800? I've tried different settings of portb and can't get it to work... Chars keep looking chaotic whenever I put them in upper part of ram. What am I missing? Could it be something in altirra's settings? Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 20, 2016 Share Posted July 20, 2016 If you're using the default OS charset and want to swap the Ram in/out at adhoc times then it's a good idea to copy the default charset to the 1K at $E000. The PORTB bits - bit 0 - set to 0 to replace the OS with Ram. Note this includes the $C000-$CFFF area as well as $D800-$FFFF. Also note the IO area $D000-$D7FF 2K Ram is never accessable on a standard system. Some mods and 3rd party Ram expansions allow you to access it, usually as part of a 16K bank @ $4000. bit 1 - set to 1 to replace Basic with Ram. Note the opposite to bit 0, this is because powerup default of PORTB output should be all ones, so the desired startup state is only the main portion of the OS visible. bit 2,3 - usual function on 130XE to select which one of 4 extended memory banks is made available in the 16K area @ $4000. bit 4,5 - usual function on 130XE to determine if the CPU (4) and Antic (5) see main or extended Ram in the 16K @ $4000 (1=main). bit 6 - usually provides extra bank selection for systems with >128K Ram. bit 7 - usually 1, set to 0 will make the Self-Test 2K Rom segment visible at $5000. If the OS is switched out, it will override and also switch out the Self-Test Rom. With Altirra settings, just ensure your machine type is XL/XE and the system memory is 64K or more. 2 Quote Link to comment Share on other sites More sharing options...
popmilo Posted July 20, 2016 Author Share Posted July 20, 2016 Thanks for nice info ! "Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth." It's exactly how I thought - I'm not crazy, it's just that bug was in another place Once I got info from you I was sure I'm setting correct bits. So I've started looking for error in different places and to my amusement found it rather quickly. Guess I was to tired last night so didn't see the obvious problem: jsr copy_charset jsr disable_roms Should've been this instead jsr disable_roms jsr copy_charset Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted July 20, 2016 Share Posted July 20, 2016 And of course the thing I forgot to add - unlike C64 there's no write-thru feature to Ram under the Rom. And also unlike C64, Rom present at a given location will take precedence for graphics accesses by Antic.* * though unsure of what happens in the case of 130XE Antic enabled for extended Ram but Self-Test Rom also swapped in. 2 Quote Link to comment Share on other sites More sharing options...
popmilo Posted July 20, 2016 Author Share Posted July 20, 2016 And of course the thing I forgot to add - unlike C64 there's no write-thru feature to Ram under the Rom. And also unlike C64, Rom present at a given location will take precedence for graphics accesses by Antic.* * though unsure of what happens in the case of 130XE Antic enabled for extended Ram but Self-Test Rom also swapped in. Exactly why I thought it doesn't matter when I was copying data "under" rom... Decades of c64 coding left some cognitive biases I guess Quote Link to comment Share on other sites More sharing options...
ricortes Posted July 20, 2016 Share Posted July 20, 2016 One thing I've heard but not verified is switching an XL/XE to a 400/800 OS gives you 4k of extra RAM above $C000 to play with. I'm weak on details, something like FixXL boot disk or Ominview OS give you the extra memory and allow you to change the built in character set in the OS RAM. Some severe limits of course like anything that relies on PBI or XL OS features will not work. Quote Link to comment Share on other sites More sharing options...
phaeron Posted July 21, 2016 Share Posted July 21, 2016 * though unsure of what happens in the case of 130XE Antic enabled for extended Ram but Self-Test Rom also swapped in. The self-test ROM has priority over the extended memory window on a stock 130XE. Expansions that reuse bit 7 as a bank bit may have the priority reversed. Quote Link to comment Share on other sites More sharing options...
