0078265317 Posted July 29, 2016 Share Posted July 29, 2016 http://www.tototek.com/store/index.php?main_page=product_info&cPath=23&products_id=54 I got the adapter to convert psx to mega drive. Works on my Genesis. Lets me use playstation controllers on my genesis. Even wireless controllers I have. And works on 5200 with my masterplay clone. I can use playstation controllers on my 5200. And even works on WII. Don't remember where I got it. But I got an adapter cable to convert wiimote to playstation and can use wireless play station controllers on WII for virtual console games. But 2600 is a no go for some reason. How come? Any ideas? I thought my junior was busted. But I tested other wired controllers on it and it works. Just not my tototek adapter. Playstation controller does not work. Light don't light up and no movemet. No thumbsticks. Or dpad or buttons. Or wireless. Even wired playstation controllers are no good. Nothing works. I verified its not a bad junior as others work. And not a dead adapter because I tested right after on my genesis and its good. So why not my junior? And its just junior maybe. Haven't tried the telegames yet. But even junior why not? Why does the junior not power the adapter? Any ideas? Quote Link to comment Share on other sites More sharing options...
0078265317 Posted July 30, 2016 Author Share Posted July 30, 2016 Anyone have any idea why it does not work on 2600? Quote Link to comment Share on other sites More sharing options...
ave1 Posted July 30, 2016 Share Posted July 30, 2016 (edited) It's an adapter that requires power through one of the controller pins which the 2600 does not send power through. You can buy a B.E.'s Genesis to Atari adapter cable from Best Electronics to solve the problem or an Edladdin Seagull78 adapter if you want to play 2600/7800 games using the Tototek adapter on your 7800. On my Youtube channel I have a video that touches on this around 7 and a half minutes in: Edited July 30, 2016 by ave1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted July 30, 2016 Author Share Posted July 30, 2016 But then why does the masterplay clone work. How is that powering this adapter? Quote Link to comment Share on other sites More sharing options...
ave1 Posted July 31, 2016 Share Posted July 31, 2016 Power is being drawn from the 5200 through the controller adapter (giving power on pin 5 of the 9 pin connector so the Tototek's internal circuit is active). Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 1, 2016 Author Share Posted August 1, 2016 Can't find the link for the best electronics cable. Quote Link to comment Share on other sites More sharing options...
ave1 Posted August 4, 2016 Share Posted August 4, 2016 (edited) Sorry I just now am seeing this. On their website you can click on Index page and scroll down until you see Atari joysticks and controllers- click that. The adaptercable is near the bottom right of all the pictured items. I would say ordering over the phone is going to be the easiest and best way to buy it with your credit card... be aware they have a minimum purchase amount that's higher than $20 if I am recalling correctly. Edited August 4, 2016 by ave1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 5, 2016 Author Share Posted August 5, 2016 I see it. http://www.best-electronics-ca.com/quickguide.htm But genesis controllers already work on a 2600 so why the need for a cable? Quote Link to comment Share on other sites More sharing options...
AW127 Posted August 6, 2016 Share Posted August 6, 2016 (edited) Normally Mega-Drive (Genesis) controllers should not be used on other 9Pin systems. The C64 can be damaged by doing this (CIA chip). And using a Mega-Drive adapter instead of a stick is the same, i suppose. Maybe other 9Pin systems (Amiga, Atari-ST, Atari2600...) are not as sensitive as the C64 in this case and don`t break at once when a Mega-Drive controller is used, but i can not imagine that it`s healthy and i would not risk it. Maybe this linked "Best Electronics" cable has something like a diode-protection or similar thing, but i dont read anything about this on the side. There are good "PSX to normal-9Pin" Adapters too, like for example this one here: http://www.kipper2k.com/psx.html I have one of these and a real good included function is the possibility to remap all buttons and save four used-defined buttonmappings. With this function, it`s also possible to switch from left-hand to right-hand steering. Because the user can remap (left to right, up to down ...... and then simply turn the controller around for steering. This is especially great for PSX Arcade-controllers which normally have lefthand-steering and can be used with the right hand then. This remapping-function is really a great thing, i like it very much. Also it`s possible to map a direction to a button or a button to a direction. And this adapter works on my two Atari-VCS2600 (Darth Vader models) without a problem, by the way. Edited August 6, 2016 by AW127 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 7, 2016 Author Share Posted August 7, 2016 Nice thanks for sharing. Quote Link to comment Share on other sites More sharing options...
ave1 Posted August 7, 2016 Share Posted August 7, 2016 The Best Electronics Genesis to Atari Systems Convertor cable was made to allow Genesis controllers that have luxury functions (ie. Slow-mo, rapid fire, etc) to be able to put those functions into use on an Atari system. Quote Link to comment Share on other sites More sharing options...
AW127 Posted August 7, 2016 Share Posted August 7, 2016 ave1, your cable for changing lefthand to righthand steering is a good idea, by the way. Some of the newer controller-adapters also have such a function. Like i explained, the Kipper2K PSX-adapter can do it when the user remaps the respective buttons and adapters like the Raphnet "SNES to Atari/Commodore" have a choosable buttonmapping for that, which remaps all functions in the way, that the user can turn-around the joystick. This is really a nice feature to have, no matter if it`s made possible by a cable like yours, a choosable buttonmapping or by remapping buttons. I learned playing video- and computer-games with the right hand and i have never understood why the most arcade-machines have lefthand-steering. When i played in gambling-hall as a kid, i always crossed the arms that i can steer with my right hand on the arcade machines. 1 Quote Link to comment Share on other sites More sharing options...
ave1 Posted August 8, 2016 Share Posted August 8, 2016 AW127, I didn't get a lot of feedback on that video and I was wondering if I was the only one who appreciated the idea of using an adapter to switch left handed joysticks to right. Glad I'm not the only one 1 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted August 9, 2016 Author Share Posted August 9, 2016 I am a lefty also. Quote Link to comment Share on other sites More sharing options...
ave1 Posted August 10, 2016 Share Posted August 10, 2016 I am a lefty also. You are fortunate to get to use some of those nice Genesis arcade sticks on the 2600/7800 if you like the stick on the left. Quote Link to comment Share on other sites More sharing options...
