nd2003grad Posted July 30, 2016 Share Posted July 30, 2016 (edited) Well, I'm finally getting somewhere...slowly...with this Amiga. I do have an old LCD-style TV that I'm using for my 800XL and my C64. I tried using a VGA-Svideo/composite device for the TV in conjunction with the Amiga to VGA adaptor. To my surprise, this results in a fantastic image...HOWEVER, it's in black and white only. Is there any way to remedy this? I'm a complete novice and I'm trying to avoid buying a (4th) monitor... **Addition** This is an NTSC 500. Edited July 30, 2016 by nd2003grad Quote Link to comment Share on other sites More sharing options...
carlsson Posted July 31, 2016 Share Posted July 31, 2016 So is this a passive RGB to VGA adapter similar to this one, which in its turn is connected to a device that will convert VGA to S-Video or composite video? The passive adapter would normally only work with higher resolutions found on the 500+, 600, 1200, 3000, 4000, not for games unless of course you've got a VGA monitor that syncs to 15 kHz. Now the key question is what the other device expects for input: will it accept a 15 kHz signal on the VGA input, or does it expect a 31 kHz signal? If the latter, I'm surprised you get an image at all but perhaps it manages to display one except that colour is lost. Quote Link to comment Share on other sites More sharing options...
nd2003grad Posted July 31, 2016 Author Share Posted July 31, 2016 it's a tv that I cannot determine accepts 15khz. I'm working on getting a display that does, but I didn't know if this would function well enough. It doesn't have a VGA input. You were correct in the setup. The multisync is the next step. Quote Link to comment Share on other sites More sharing options...
