mantadoc Posted August 1, 2016 Share Posted August 1, 2016 I programmed the Atari 512kb file on the at49f040 But the program freeze ,see picture 3 is it not possible or do i something wrong here ? Richard Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted August 2, 2016 Share Posted August 2, 2016 Interesting. This cartridge image does not require 32K, so that should not be an issue. Did you check "verify after" write? Sometimes you can get a bad write. I'd try: 1) Erasing & reprogramming the chip AFTER taking a little Emory cloth or fine grit sandpaper to the contacts. I had the same exact problem when I first tried writing chips. The cheap little adapters that come with the MiniPRO SUCK! I mention this in my blog entry here << HERE >>. 1 Quote Link to comment Share on other sites More sharing options...
mantadoc Posted August 2, 2016 Author Share Posted August 2, 2016 Interesting. This cartridge image does not require 32K, so that should not be an issue. Did you check "verify after" write? Sometimes you can get a bad write. I'd try: 1) Erasing & reprogramming the chip AFTER taking a little Emory cloth or fine grit sandpaper to the contacts. I had the same exact problem when I first tried writing chips. The cheap little adapters that come with the MiniPRO SUCK! I mention this in my blog entry here << HERE >>. Ok thanks , i´ll try Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted August 8, 2016 Share Posted August 8, 2016 One thing you might want to do to test your board is to burn a chip with the bank test program and verify that your board starts up in either the first or the last bank. That will also validate the board's general operation. I built that one, so it should be OK, but I don't see a green sticker on it (the sticker indicates a first or last starting bank for the bank switching chip), and 25LS07 chips often start in random banks (not a problem when using GPL startup coded to force it to >6000 on startup, but that needs a 1284 installed). Quote Link to comment Share on other sites More sharing options...
