+arcadeshopper Posted February 22, 2022 Share Posted February 22, 2022 Thanks Greg - would be amazing if it worked on the CC40 too!It should work exactly the same. I'll set mine up and trySent from my Pixel 6 Pro using Tapatalk Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted February 22, 2022 Share Posted February 22, 2022 (edited) 1 hour ago, arcadeshopper said: It should work exactly the same. I'll set mine up and try Sent from my Pixel 6 Pro using Tapatalk Thanks that would be great. Edited February 22, 2022 by mutantcamel1979 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 22, 2022 Share Posted February 22, 2022 (edited) 3 hours ago, mutantcamel1979 said: Thanks Greg - would be amazing if it worked on the CC40 too! ok reading back and testing confirms the CC40 has no cassette ability. just the CC40+ So if you want to use storage with the CC40 you need the Hex-ti-r interface which is better anyway as it's a stand alone hard disk equiv Edited February 22, 2022 by arcadeshopper Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted February 22, 2022 Share Posted February 22, 2022 1 hour ago, arcadeshopper said: ok reading back and testing confirms the CC40 has no cassette ability. just the CC40+ So if you want to use storage with the CC40 you need the Hex-ti-r interface which is better anyway as it's a stand alone hard disk equiv Thanks for trying. I nearly bought a CC40+ last year. Ah well. Would be nice to have one device to work on both machines! Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 22, 2022 Share Posted February 22, 2022 12 minutes ago, mutantcamel1979 said: Thanks for trying. I nearly bought a CC40+ last year. Ah well. Would be nice to have one device to work on both machines! the hex-ti-r works on both Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted February 23, 2022 Share Posted February 23, 2022 15 minutes ago, arcadeshopper said: the hex-ti-r works on both How do you connect the hex-ti-r to each TI? I have some spare hexbus leads for my CC40, but would I have to build a lead with a dockbus plug on it for the 74? I have never seen a stand alone lead for one. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 23, 2022 Share Posted February 23, 2022 Just now, mutantcamel1979 said: How do you connect the hex-ti-r to each TI? I have some spare hexbus leads for my CC40, but would I have to build a lead with a dockbus plug on it for the 74? I have never seen a stand alone lead for one. It has a hexbus plug on it, and you use a hexbus to dockbus adapter to connect to dockbus with some dupont connectors i stock the drive and adapter Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted February 23, 2022 Share Posted February 23, 2022 11 minutes ago, arcadeshopper said: It has a hexbus plug on it, and you use a hexbus to dockbus adapter to connect to dockbus with some dupont connectors i stock the drive and adapter ok thanks did not see the adapter on your site. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 23, 2022 Share Posted February 23, 2022 15 minutes ago, mutantcamel1979 said: ok thanks did not see the adapter on your site. thanks for pointing that out, I've added it back on Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted February 23, 2022 Share Posted February 23, 2022 Thanks - I thought it was a ready made adapter to be honest. Since I nearly burnt my house down, I haven't attempted any soldering projects! Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 23, 2022 Share Posted February 23, 2022 Thanks - I thought it was a ready made adapter to be honest. Since I nearly burnt my house down, I haven't attempted any soldering projects! Pretty easy to fix I'll add optionsSent from my Pixel 6 Pro using Tapatalk Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 23, 2022 Share Posted February 23, 2022 7 hours ago, mutantcamel1979 said: Thanks - I thought it was a ready made adapter to be honest. Since I nearly burnt my house down, I haven't attempted any soldering projects! It is in fact made.. pins are installed for cables to plug into Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted February 23, 2022 Share Posted February 23, 2022 (edited) 26 minutes ago, arcadeshopper said: It is in fact made.. pins are installed for cables to plug into Ok so do you plug one side into a hexbus cable and the other pins directly into the TI-74 itself? Just trying to visualise how it all fits together. Thanks Edited February 23, 2022 by mutantcamel1979 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 23, 2022 Share Posted February 23, 2022 (edited) 1 hour ago, mutantcamel1979 said: Ok so do you plug one side into a hexbus cable and the other pins directly into the TI-74 itself? Just trying to visualise how it all fits together. Thanks Like this I can throw in a dupont cable if needed Sent from my Pixel 6 Pro using Tapatalk Edited February 23, 2022 by arcadeshopper Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted February 25, 2022 Share Posted February 25, 2022 Sadly I had to spend a lot of money on my car this month, so was unable to afford the hex-ti-r. They are sadly sold out ah well! Will keep an eye out if anymore ever appear on the scene! Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted February 25, 2022 Share Posted February 25, 2022 Sadly I had to spend a lot of money on my car this month, so was unable to afford the hex-ti-r. They are sadly sold out ah well! Will keep an eye out if anymore ever appear on the scene!Lmk when your ready I'll put one in for youSent from my Pixel 6 Pro using Tapatalk Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted March 7, 2022 Share Posted March 7, 2022 (edited) I received my own CIduino7 digital cassette interface for my TI74 at the weekend. I managed to upload a series of simple basic programs I had saved on cassette many years ago. Please find attached. I have included instructions too. Simply load using the command old "1.Game-Mix" All 6 programs are contained in the one txt file. Not sure if an original PCIF can be used or the Hex-TI-r-Hexbus. At the moment I had to modify the programs on the TI74 itself rather than my PC. I have loads more programs, so will upload more interesting things too soon! Game-Mix.txt Game-Mix Instructions.docx Edited March 7, 2022 by mutantcamel1979 4 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted March 8, 2022 Share Posted March 8, 2022 Another day another exciting program! Get your teeth into another TI74 program! Gunnery.txt 2 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted March 8, 2022 Share Posted March 8, 2022 Another one...I quite like this one! Horse-Racing.txt 1 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted March 9, 2022 Share Posted March 9, 2022 (edited) How about a simple guessing game?! Number.txt And a simple dice game! HI-DI.txt Edited March 9, 2022 by mutantcamel1979 3 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted March 9, 2022 Share Posted March 9, 2022 Final game of the day. Pretend to be Keanu Reeves in this exciting bomb detection game! Bomb.txt 1 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted March 9, 2022 Share Posted March 9, 2022 Just tried my Haunted House Text Adventure game which requires an additional 8K ram cartridge to run. Took a while but managed to upload it ok. Good little game with the facility to save your progress onto cassette! Hoping to convert some more adventure games very soon! Haunted.txt 3 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted March 10, 2022 Share Posted March 10, 2022 14 hours ago, mutantcamel1979 said: Just tried my Haunted House Text Adventure game which requires an additional 8K ram cartridge to run. Took a while but managed to upload it ok. Good little game with the facility to save your progress onto cassette! The program can be converted very easily to load/save from the SD storage solution as noted in the program listing: 5 REM WILL ALSO PLAY ON AN 18K CC-40 - BUT PLAYER WILL NOT BE ABLE TO SAVE 6 REM OR LOAD A PREVIOUS GAME - AS THE GAME USES THE TI-74'S CI-7 7 REM CASSETTE INTERFACE. LINES 6000-7200 COULD BE AMENDED TO CHANGE THIS THOUGH I have attached the amended version (binary). HAUNTED 3 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted March 10, 2022 Share Posted March 10, 2022 (edited) 3 hours ago, Vorticon said: The program can be converted very easily to load/save from the SD storage solution as noted in the program listing: 5 REM WILL ALSO PLAY ON AN 18K CC-40 - BUT PLAYER WILL NOT BE ABLE TO SAVE 6 REM OR LOAD A PREVIOUS GAME - AS THE GAME USES THE TI-74'S CI-7 7 REM CASSETTE INTERFACE. LINES 6000-7200 COULD BE AMENDED TO CHANGE THIS THOUGH I have attached the amended version (binary). HAUNTED 11.1 kB · 1 download Thanks for the amended version! If anyone wants to put these programs in a directory or on another site please feel free. I wanted to demonstrate that having a single row display does not limit the system. Just your own imagination that limits you! Edited March 10, 2022 by mutantcamel1979 2 Quote Link to comment Share on other sites More sharing options...
mutantcamel1979 Posted March 20, 2022 Share Posted March 20, 2022 (edited) Had a few issues with my Arduino, but managed to upload another TI74/CC40 3 in 1 program: Coin Flip, Aucey-Deucey (simple card game) and Hidden Words. Instructions are found within the program listings. Enjoy! 3in1.txt Edited March 20, 2022 by mutantcamel1979 3 Quote Link to comment Share on other sites More sharing options...
