bradd1978 Posted August 9, 2016 Share Posted August 9, 2016 Hey, I'm relatively new to the Atari Lynx and had the opportunity to grab three broken units pretty cheap. So after doing the headphone ground trick none of them powered (i used 6 AA batteries). I was worried that the system was getting 9V throughout and these were toast. I watched a video where a guy fed 5V through the battery terminals along with the headphone ground trick and they fired up. So I tried this and Boom...both fired up with INSERT GAME. Plugged in a game and it worked excepted the screens were damaged with dead pixels. Thats ok, I've got a McWill LCD standing by :-) I replace the Mosfet and zener diode, remove the headphone ground wire, put it together and fired it up, but nothing....I recheck everything and see that Q8 was fried. I replaced that, but lifted a pad in the process so soldered up a jumper wire. Fire it up again, nothing. I start probing around checking voltage - my multimeter probe accidentally bridged the Gate and Drain on the Mosfet (left and middle pins) and the unit fired up! I recheck my soldering and reseated the replaced Mosfet but it still didn't help. So I'm a bit stumped now, is something else bad in the power section? Bad Mosfet? Because I'm new to the Lynx, I don't know a lot about its power section or how it works. I feel like its something really silly and I'm close to getting this running. Any help would be appreciated. The other unit is another story I'll save for another thread Quote Link to comment Share on other sites More sharing options...
bdoi Posted August 10, 2016 Share Posted August 10, 2016 Hi brad This thread may help :you (lynx 1 and 2 are very similar) http://atariage.com/forums/topic/225348-lynx-1-onoff-issue/ I have a similar issue and I finally solve it with the 5v regulator modd. Quote Link to comment Share on other sites More sharing options...
bradd1978 Posted August 10, 2016 Author Share Posted August 10, 2016 bdoi - Thank you very much for the link. In laziness, I went straight to the 5V mod but it still didn't help. I'm truly confused with this. I even used 2 other Lynx shells with different circuit membranes for the buttons - still nothing. Anyways not sure what to try next Quote Link to comment Share on other sites More sharing options...
cowdog360 Posted August 12, 2016 Share Posted August 12, 2016 I have one behaving similarly. It was working great, then bam.. nothing. Fires up with the shorted MOSFET as well. I'm going to check the 4069 IC and see if that's the culprit. Quote Link to comment Share on other sites More sharing options...
bradd1978 Posted August 13, 2016 Author Share Posted August 13, 2016 I have one behaving similarly. It was working great, then bam.. nothing. Fires up with the shorted MOSFET as well. I'm going to check the 4069 IC and see if that's the culprit. Yeah shorting it now with the 5V mod just brings the backlight on. I did the headphone ground trick and used batteries and it will fire up. So bizarre Quote Link to comment Share on other sites More sharing options...
leonk Posted August 14, 2016 Share Posted August 14, 2016 I'm not sure about battery/headphone mod. It killed one of my Lynx 2 systems. I think the better solution is to short the top of the mosfet and the right pin (solder in a wire). That seems to work for me. Quote Link to comment Share on other sites More sharing options...
leonk Posted August 14, 2016 Share Posted August 14, 2016 Most inportant thing is to also have a game inserted. Otherwise you need to install a wire between pin 31 and 33 on the cart connector, under the metal shield. Quote Link to comment Share on other sites More sharing options...
bradd1978 Posted August 14, 2016 Author Share Posted August 14, 2016 I'm not sure about battery/headphone mod. It killed one of my Lynx 2 systems. I think the better solution is to short the top of the mosfet and the right pin (solder in a wire). That seems to work for me. Thanks I'll have to try that. I really want these to work properly using the power button. The headphone trick I don't trust myself. On a side note, I'm definitely interested in buying a working unit if anyone has an extra :-) Quote Link to comment Share on other sites More sharing options...
