tschak909 Posted August 18, 2016 Share Posted August 18, 2016 I'm putting together a YouTube tutorial on how to set up an Ultimate1MB/SIDE2 based system inside Altirra, and would love to see what AUTOEXEC and CONFIG files that you guys have been using for your daily machines, would you guys mind posting? -Thom 3 Quote Link to comment Share on other sites More sharing options...
Mark2008 Posted February 3, 2021 Share Posted February 3, 2021 I would too, every attempt to write a config.sys doesn't result in any changes to my system. I tried this directly from the spartados manual, but it does nothing. DEVICE \DRIVERS\RC_GR8.SYS ; TOOLKIT DEVICE \DRIVERS\CON.SYS; TOOLKIT ; DEVICE QUICKED DEVICE CON64 DEVICE RAMDISK O,8 autoexec.bat would work enough to load the device drivers, it doesn't do other things, example, it will never set the prompt. I can only set the prompt manually. Manual says this "SDX carries a default text file of configuration information called CONFIG.SYS on the CAR: device. To override the use of the default configuration settings create a file called 'CONFIG.SYS' and save it as a text file in the 'MAIN' directory on the boot drive, which must be a SDFS formatted medium. " Hard to imagine this the SD Card in my Side2 wasn't formatted with SDFS...the root directory is called "MAIN". Odd that the config.sys is clearly not being read, I cannot guess what I've done wrong. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted February 3, 2021 Share Posted February 3, 2021 Unless you have U1MB, CONFIG.SYS cannot be read from the HDD because it's CONFIG.SYS on the CAR: device (in ROM) which loads the driver for the HDD. Chicken and egg situation. 1 Quote Link to comment Share on other sites More sharing options...
Gunstar Posted February 4, 2021 Share Posted February 4, 2021 I use a D1: boot disk, in my case from a real floppy drive that has the config.sys file and needed tools on it. The HDD driver for whatever type of HDD you are using needs to be in the config.sys file, for me, I use it with SSDX cartridge from Dropcheck and piggy-backed MyIDE II HDD APT partitions. On my Incognito 800 I use a floppy boot disk in drive one when I want to bypass SDX for Sparta DOS 3.x for use with the ATOS desktop, I use the Side HDD driver in the config.sys for it along with devices, etc. needed to set up ATOS. This way I don't have to worry about re-flashing SDX with a new config.sys and once the system is booted up, D5: becomes the new Main directory for HDD leaving 1-4 open for SIO. 2 Quote Link to comment Share on other sites More sharing options...
Ripdubski Posted February 4, 2021 Share Posted February 4, 2021 INIDOS.SYS and CONFIG.SYS on empty disk used to boot. CONFIG.SYS: USE BANKED DEVICE SPARTA DEVICE ATARIDOS DEVICE SIO DEVICE D1:PCLINK.SYS (also on boot disk) DEVICE RTIME8 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted February 4, 2021 Share Posted February 4, 2021 These are my CONFIG.SYS and AUTOEXEC.BAT I put all my utilities in D6:\BIN\ and batch files in D5:\BAT\ CONFIG.SYS:- DEVICE SPARTA OSRAM DEVICE SIO DEVICE ATARIDOS DEVICE ULTIME DEVICE JIFFY DEVICE FATFS DEVICE RAMDISK N,20 DEVICE DOSKEY SET PATH=CAR:;D6:\BIN\;D5:\BAT\;D9: SET MANPATH=D6:\MAN\ AUTOEXEC.BAT SET BASIC=DN:BASIC.SAV SET SCRDEF=2,141,0,0 SET PROMPT=D$N$P> QUICKED.SYS ECHO "DRIVES D5: D6: D7: D8: D9:" ECHO "DJ: FAT=DO: RAMDISK=DN:" 1 Quote Link to comment Share on other sites More sharing options...
