First Spear Posted August 31, 2016 Share Posted August 31, 2016 I am trying to come up with a mental formula for converting a song's Beats-per-Minute to the DATA syntax in IntyBASIC, which represents Ticks per note (there are 50 ticks per second). For example, if a song is 119 BPM, what would the IntyBASIC DATA number be? Thanks. Quote Link to comment Share on other sites More sharing options...
carlsson Posted August 31, 2016 Share Posted August 31, 2016 (edited) 119 BPM means every beat takes 60/119 = 0.5042 seconds. 50 ticks per second means that you'll have 50 * 0.5042 = 25.21 ticks per beat. At least that is how I would do the math. A beat normally is a quarter note, which means a 16th of a note would be 6.30 ticks. Now I understand you can't fine tune the DATA to fractions of a tick, so for the given tempo I would probably base it on tempo 6, if 16th notes are the shortest in the song. Edit: If my reasoning is correct and you get exactly 50 ticks per second, I presume the following tempos may be possible assuming BPM means quarter notes per minute and you need resolution down to 16th notes (no triplets). Tempo 3 = 250 BPM (!) Tempo 4 = 187 BPM Tempo 5 = 150 BPM Tempo 6 = 125 BPM Tempo 7 = 107 BPM Tempo 8 = 93 BPM Tempo 9 = 83 BPM Tempo 10 = 75 BPM (I didn't check which tempos are really valid in the IntyBASIC syntax) Edited August 31, 2016 by carlsson 1 Quote Link to comment Share on other sites More sharing options...
First Spear Posted September 1, 2016 Author Share Posted September 1, 2016 Thanks for the idea. I had always defaulted to "6" but you have generally helped me unfreeze my brain. [snip] Edit: If my reasoning is correct and you get exactly 50 ticks per second, I presume the following tempos may be possible assuming BPM means quarter notes per minute and you need resolution down to 16th notes (no triplets).[snip] Quote Link to comment Share on other sites More sharing options...
First Spear Posted September 18, 2016 Author Share Posted September 18, 2016 A tempo of 3 means roughly using 24 "lines" of Music syntax to represent a quarter note, which eats a lot of ROM When a tempo of 6 needs half of that. But a 3 lets the drum track sustain. Interesting. 119 BPM means every beat takes 60/119 = 0.5042 seconds. 50 ticks per second means that you'll have 50 * 0.5042 = 25.21 ticks per beat. At least that is how I would do the math. A beat normally is a quarter note, which means a 16th of a note would be 6.30 ticks. Now I understand you can't fine tune the DATA to fractions of a tick, so for the given tempo I would probably base it on tempo 6, if 16th notes are the shortest in the song. Edit: If my reasoning is correct and you get exactly 50 ticks per second, I presume the following tempos may be possible assuming BPM means quarter notes per minute and you need resolution down to 16th notes (no triplets). Tempo 3 = 250 BPM (!) Tempo 4 = 187 BPM Tempo 5 = 150 BPM Tempo 6 = 125 BPM Tempo 7 = 107 BPM Tempo 8 = 93 BPM Tempo 9 = 83 BPM Tempo 10 = 75 BPM (I didn't check which tempos are really valid in the IntyBASIC syntax) Quote Link to comment Share on other sites More sharing options...
carlsson Posted September 18, 2016 Share Posted September 18, 2016 (edited) Hm. I thought 1 line of music = 1 sixteenth note, and then you adjust tempo to get desired number of beats per minute? At tempo 6, every sixteenth note takes 6 ticks * 4 = 24 ticks per quarter note. On one minute, you have 50 * 60 = 3000 ticks, divided by 24 makes 125 BPM (quarter notes per minute). At tempo 3, you either have 250 BPM or a resolution where 1 line = 1 thirtysecondth note which would double your precision for simulated triplets and other more complex music patterns. A quarter note at 125 BPM here would use 8 lines of music, not 24. It is possible that we mean the same thing, but use different ways of thinking to get there. Edited September 18, 2016 by carlsson Quote Link to comment Share on other sites More sharing options...
First Spear Posted September 22, 2016 Author Share Posted September 22, 2016 I have found that faster tempo songs (lower numbers like 2-3) need more ROM because if there are 64th notes and whole notes, it will take one row of MUSIC to represent the 64th note but 64 MUSIC rows to represent the whole note. The project I am working through will purposely have tempos on the slower side (9+) just so the song length can be decent and not loop too soon (annoying) - also trying to keep the notes in the same "range" so if there are quarter notes I will do half and eighth maybe 16th but if 16th then no half, or vice versa. Hopefully that makes sense, my English is not that great*. *And English is the only language I speak. Quote Link to comment Share on other sites More sharing options...
carlsson Posted September 23, 2016 Share Posted September 23, 2016 Wow, 64th notes! I'm not sure I have ever used that in chip music, or I suppose it depends how you consider ever line of music, as 16th notes at a very high BPM tempo or as 64th notes at a more moderate tempo. I'm sure you can create very cool effects and music patterns at those fast tempos, and perhaps required if you want anything that resembles arpeggios. Quote Link to comment Share on other sites More sharing options...
First Spear Posted September 26, 2016 Author Share Posted September 26, 2016 I experimented with converting to InyBASIC with the Star Blazers theme, there were 64th notes there. I also messed with tracking a couple of Led Zeppelin songs, the fast guitar playing comes out as 64th notes, which requires a speed of 1-3... I hope that IntyBASIC will get a subcommand for turning on the hardware envelopes within a track, that could allow a lot f nice song effects. Wow, 64th notes! I'm not sure I have ever used that in chip music, or I suppose it depends how you consider ever line of music, as 16th notes at a very high BPM tempo or as 64th notes at a more moderate tempo. I'm sure you can create very cool effects and music patterns at those fast tempos, and perhaps required if you want anything that resembles arpeggios. 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted September 26, 2016 Share Posted September 26, 2016 Sudden change of tempo could also be a nice addition, but then again we just discussed how to daisy-chain different songs to appear like one so tempo changes could be part of that chain. 1 Quote Link to comment Share on other sites More sharing options...
