omegadot Posted September 2, 2016 Share Posted September 2, 2016 I have a Mother 3 fan translation hack cart that doesn't save. I'm wondering if it's worth trying to replace the battery to see if that's the issue. I've never done it before. Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted September 5, 2016 Share Posted September 5, 2016 That is most likely why it does not save. They should be soldered but you can do a pry method and use electrical tape if that is your only option. You're not to far from me I could swap it if you ever go east past Rochester. Quote Link to comment Share on other sites More sharing options...
Cobra Kai Posted September 7, 2016 Share Posted September 7, 2016 I have a Mother 3 fan translation hack cart that doesn't save. I'm wondering if it's worth trying to replace the battery to see if that's the issue. I've never done it before. You'll have to get the special Nintendo security bit driver, plus a battery, and a cheap solder kit would work. An investment of around $30 will get you set up. The actual replacement isn't very hard even for a novice. I've replaced about 20 SNES batteries myself. Quote Link to comment Share on other sites More sharing options...
omegadot Posted September 7, 2016 Author Share Posted September 7, 2016 Cool, thanks for the feedback. I have a solder kit I've used for work on guitars and I think I have the bit in a kit I bought to fix my Wii U Gamepad. I'll give it a shot. Quote Link to comment Share on other sites More sharing options...
CatPix Posted September 8, 2016 Share Posted September 8, 2016 Just a warning : it's more adviseable to solder a battery holder if you're a beginner in soldering, the battery might pop if you overheat it. Quote Link to comment Share on other sites More sharing options...
Cobra Kai Posted September 8, 2016 Share Posted September 8, 2016 (edited) Edited September 8, 2016 by Nuclear Pacman Quote Link to comment Share on other sites More sharing options...
icemanxp300 Posted September 8, 2016 Share Posted September 8, 2016 Just a warning : it's more adviseable to solder a battery holder if you're a beginner in soldering, the battery might pop if you overheat it. There is no room for a holder in a Gameboy cart. Quote Link to comment Share on other sites More sharing options...
