David Baldwin Posted September 14, 2016 Share Posted September 14, 2016 How do I cycle through the adf files in my Gotek in Workbench is there a special program for the Amiga to use. Quote Link to comment Share on other sites More sharing options...
flanauf Posted September 14, 2016 Share Posted September 14, 2016 Well, you have to press the buttons on the drive emulator... I think there is a mod to add a remote control to do this, but as far as i know there is no software way to do the same thing Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted September 14, 2016 Author Share Posted September 14, 2016 yes i found out by going to a new adf you have to update all from the menu bar that works kind of Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted September 15, 2016 Share Posted September 15, 2016 (edited) If you're using cortex on the GoTek then be sure to put selektor program in to a slot. Then boot workbench and change the slot on the gotek to the slot with selektor loaded.You will then be able to run the selektor program in workbench so you can load up slots and check to see what slots you might need to change to.It's the same program the GoTek boots to when set to 00 .Heck, you can even copy the selektor GoTek disk to an actual floppy and run it that way if you needed to. I haven't tried copying it to HDD though. Good idea, thanks for making me think of this now.bbiab. Edited September 15, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
