+Propane13 Posted September 14, 2016 Share Posted September 14, 2016 It's been awhile. Curious what the best way to clean my console cartridge-port is. -John Quote Link to comment Share on other sites More sharing options...
Trebor Posted September 14, 2016 Share Posted September 14, 2016 It's been awhile. Curious what the best way to clean my console cartridge-port is. -John RevEng provided some good direction on this relatively recently. The information is pasted below for convenience: Clean the carts themselves with 99% isopropyl alcohol and a q-tip, cotton swab, cotton, or whatever. You can do a quick clean of the port by saturating a clean cart edge with alcohol and inserting a few times. Wait enough time for the alcohol to evaporate, and test to see if things are better. Repeat a few times if they're not. A more involved clean can be done by taking an old plastic card with a layer of cotton, soak the edge in alcohol, and use that to clean the contacts. In terribly gone cases, very fine grit sandpaper can be wrapped around a plastic card and used to abrade the contacts, to get rid of oxidation. Blow out the dust. This one is a last resort as it removes plating on the contacts, but truthfully the plating was probably worn away years ago. 1 Quote Link to comment Share on other sites More sharing options...
78001987 Posted September 15, 2016 Share Posted September 15, 2016 Armor All... *ducks* Quote Link to comment Share on other sites More sharing options...
+Propane13 Posted September 15, 2016 Author Share Posted September 15, 2016 With regards to the "taking an old plastic card with a layer of cotton, soaking the edge in alcohol" method: This may sound stupid, but how is this done, specifically? I'm picturing an old credit card (which I don't think will fit), and I'm not sure where to find a layer of cotton that's referenced (maybe gauze)? I used to have something like what's mentioned in an old cleaning kit, but I'm curious how to do this with specific household materials. -John Quote Link to comment Share on other sites More sharing options...
Jinks Posted September 15, 2016 Share Posted September 15, 2016 I have used cereal box cardboard with a bit of alcohol dipped on the end for console ports. Frosted flakes makes it grreat! Seems to work.. And qips and alcohol for carts. Quote Link to comment Share on other sites More sharing options...
RevEng Posted September 15, 2016 Share Posted September 15, 2016 A credit card will work, but yes, you'll need to trim it to fit. For cotton, use and old t-shirt or whatnot. It really doesn't matter where you get it - the goal is to create an alcohol absorbent surface that can pushed into the slot and will wipe the contacts. The card and cotton should be roughly as thick as a PCB. 1 Quote Link to comment Share on other sites More sharing options...
