+jedimatt42 Posted September 30, 2016 Share Posted September 30, 2016 (edited) I have a basic subroutine 'CALL' embedded in a DSR, that find the first program record in the Cartridge program chain and jumps there. So, I've tested in Classic99, with this DSR loaded: cart_DSR.bin configured like: ; EA IV name="Editor Assembler IV" rom0=3|0000|8000|MODS\EAIV\eaprom_IV_INV.bin rom1=D|4000|1000|MODS\gcc_DSR.bin That with the QI/v2.2 TI, I can go into basic and enter: CALL CART And it will take me into the ROM cart.. This is cool. Cause I have a v2.2 beige console, I want to use my memory board and a all these new ROM cartridges with... So I'd like to put this in an eprom and wire it to that little expansion port on my sideport 32k device. I imagine there are ways I could do this wrong, just use the >4000 signal on the sideport to control enabling the rom, and data buffer. But I imagine it should respect only being in when a CRU port is set... Does anyone have a starter circuit for doing this? My DSR is just these two little snippets.. header.asm # ROM header byte 0xAA, 0x00, 0x00, 0x00 # Start of power-up chain (unused) data 0x0000 # Start of program chain (unused) data 0x0000 # Start of DSR chain (unused) data 0x0000 # Start of subprogram list data callgame # This doubles as the terminator of the program chain callgame: data 0x0000 # Next program chain record data _start # Entry point for program nstring "CART" # Name of program even and def _start _start: limi 0 # Disable interrupts lwpi >8300 # Set initial workspace mov @>6004,r1 ai r1,2 blwp r1 I suppose I should actually check if >6000 contains the requisite >AA header byte. ( I know all of this has done before BITD... and more recently there is a playground solution... I'm just aiming to make this easier. ) -M@ Edited October 1, 2016 by jedimatt42 2 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted September 30, 2016 Share Posted September 30, 2016 Very nice. Regarding v2.2, you could just replace GROM 0. And for any version, you can skip the TI title-screen and go directly into the cart. Nice, though I kinda like to have title and selection. Quote Link to comment Share on other sites More sharing options...
Stuart Posted September 30, 2016 Share Posted September 30, 2016 If you look at Thierry's page for the Horizon Ramdisk [http://www.nouspikel.com/ti99/titechpages.htm] that shows the schematic for the DSR RAM as well as the ramdisk RAM. Should give you a place to start, although you should be able to simplify things considerably. Looks like you'll need something like: -- 74LS138 to decode the CRU address for your 'card'. -- 74LS259 to latch a 'card enabled/disabled' CRU bit. -- Your EPROM. -- 74LS245 data buffer. -- Miscellaneous logic gates and other components. 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted September 30, 2016 Author Share Posted September 30, 2016 Very nice.Regarding v2.2, you could just replace GROM 0.And for any version, you can skip the TI title-screen and go directly into the cart. Nice, though I kinda like to have title and selection. My entire premise is to learn how to handle the CRU selection. My secondary goals are: * No modifications to a v2.2 console * Enable running carts with multiple program entries. * Does not interfere with existing hardware * Can be left connected 24/7 * No switches required during use. I plan to expand the routine to go to a menu if there is more than one entry. -M@ 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted September 30, 2016 Author Share Posted September 30, 2016 And Stuart, Thanks! The ramdisk write up is clearer to me than his general cru selection circuit. -M@ 1 Quote Link to comment Share on other sites More sharing options...
Stuart Posted September 30, 2016 Share Posted September 30, 2016 Matt, have you got a copy of the "Interface Standard & Design Guide for TI-99/4A Peripherals" book by Tony Lewis? That covers DSRs and has some circuit bits as well - you'd probably find it interesting. Not sure where you got a copy from though - I believe it's still available so probably no scanned copies around. Someone else may chip in if they know where you can get a copy from. Stuart. 1 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted September 30, 2016 Author Share Posted September 30, 2016 (edited) Matt, have you got a copy of the "Interface Standard & Design Guide for TI-99/4A Peripherals" book by Tony Lewis? That covers DSRs and has some circuit bits as well - you'd probably find it interesting. Not sure where you got a copy from though - I believe it's still available so probably no scanned copies around. Someone else may chip in if they know where you can get a copy from. Stuart. No, I don't have that. Sounds like exactly what I need to absorb. Anyone want to sell me one? http://www.whtech.com/ti/guide.html -M@ Edited September 30, 2016 by jedimatt42 Quote Link to comment Share on other sites More sharing options...
