Savage38 Posted October 8, 2016 Share Posted October 8, 2016 Given that I use indexed color mode, proper color palette .act file providing from this website, and have tried saving as normal .png and saving .png with "saving to web or device", have used as little as a single color of the palette, what could I be doing wrong? I also tried GIMP and it is a mixed bag for me too. Any tips or if someone could point me in the right direction, it would be greatyly appreciated. I have had no trouble building with any of the pngs provided in the samples but making my own is the problem. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Savage38 Posted October 10, 2016 Author Share Posted October 10, 2016 So, I've been using GIMP and it does work, but still a little perplexed why Photoshop PNGs aren't just as easily converted. Any help is welcome. I hate to have so many application serving the same purpose when just one should do. I use Photoshop for modern games since it has the ability to use Quixel and the like. Would like to consolidate these two application. Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 10, 2016 Share Posted October 10, 2016 I haven't personally used Photoshop since about version 5, and don't have a need to buy it now, so the best I can do is some indirect analysis. If you post one of your photoshop indexed png files, I can at least see why it's not importing. 1 Quote Link to comment Share on other sites More sharing options...
Bakasama Posted October 10, 2016 Share Posted October 10, 2016 (edited) So, I've been using GIMP and it does work, but still a little perplexed why Photoshop PNGs aren't just as easily converted. Any help is welcome. I hate to have so many application serving the same purpose when just one should do. I use Photoshop for modern games since it has the ability to use Quixel and the like. Would like to consolidate these two application. That's easy to explain. PNGs have millions of colors even though the image itself uses only four of those and you're trying to convert that into a bitmap that's that uses four colors from a pallet of 256 colors. It might work a lot better if you save as a gif and convert that. Edited October 10, 2016 by Bakasama 1 Quote Link to comment Share on other sites More sharing options...
Savage38 Posted October 18, 2016 Author Share Posted October 18, 2016 Thanks for recommendations. I will need to give it all a try later when I have time to work on it again. I definitely think it has something to do with the color palettes being saved. I can take a fresh image that works into photoshop and save it and it wont work. GIMP, oddly enough, gives you more control over the number of colors being saved, whihc kills me. Photoshop should give us more control being more expensive. Definitely fail on the part of Adobe. Quote Link to comment Share on other sites More sharing options...
Savage38 Posted October 18, 2016 Author Share Posted October 18, 2016 I haven't personally used Photoshop since about version 5, and don't have a need to buy it now, so the best I can do is some indirect analysis. If you post one of your photoshop indexed png files, I can at least see why it's not importing. How can I attach them without effecting them? a working image merely opened and then saved in Photoshop as an indexed image will cease working. No changes to the image itself, but still doesn't work. I only have the option of 2,4,8,and 16 colors using "save for deivce or web" option. Saving normal indexed PNGs also doesn't work. I don't mind sharing them, I just don't know how to attach things on this forum. Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 18, 2016 Share Posted October 18, 2016 Save it as a normal indexed PNG in Photoshop. If you hit the "more reply options" button there are options to attach the file... this won't modify the attached file, other than the file name, which doesn't matter. 1 Quote Link to comment Share on other sites More sharing options...
Mord Posted October 19, 2016 Share Posted October 19, 2016 How can I attach them without effecting them? a working image merely opened and then saved in Photoshop as an indexed image will cease working. No changes to the image itself, but still doesn't work. I only have the option of 2,4,8,and 16 colors using "save for deivce or web" option. Saving normal indexed PNGs also doesn't work. I don't mind sharing them, I just don't know how to attach things on this forum. Is it possible to do a screenshot of photoshop with your saving options open? Might be an option that's being overlooked that'll help out. Took me a while to get use to saving pngs properly in paintshop pro all because I missed an option. 2 Quote Link to comment Share on other sites More sharing options...
Savage38 Posted October 20, 2016 Author Share Posted October 20, 2016 (edited) I found a work around, so I'm good now, but I will still post those things you need to check it out. It was the bit depth. Photoshop refuses to save under 8, but I found an application called PNG Quantize, pngquant.exe. It has a small batch file and exe you can keep in your images folder. You make whatever you want in Photoshop and simply drag and drop it on the batch file and it will take the 8 bit PNG and make it a PNG with a 2 bit bitdepth. it is easy to find online. Let me know if you still want to png from photoshop, but I'm almost positive now that it was the bitdepth. Kinda sucky still that PS doesn't allow smaller bitdepth even under "save for device or web". PS does allow for everything else though; Indexed colors, custom Atari palette, number of colors, just nothing outside of 8 or 16 bit depth. Odd oversight. Edited October 20, 2016 by Savage38 Quote Link to comment Share on other sites More sharing options...
