the_crayon_king Posted October 24, 2016 Share Posted October 24, 2016 Ah so I thought I was having issues with a S-Video mod using the LM318 so decided to use a THS7314 instead and it works no issues (that I can see). Instead of grabbing 5v from wherever I put the 12v through a 7805 power reg to get the 5v for the THS7314. So I just put the chroma through the 7314 and had 75 ohm on the output. Luma is going straight to the S-Video jack through a 75 ohm resistor. (I have vertical lines not related to this or the LM318 mod so maybe amping luma will fix it ? [Honestly I think its a grounding issue]) When I make a board around this I will put potentiometer to ground on the lines so I can adjust the picture but it looks great as-is. The benefit of the THS7314 being its easier to find and this mod would have far less parts. In the future I will probably use this board to do this and various other mods [VERY WIP]: https://easyeda.com/hotdog6394/THS7360_SD_Universal_Video_AMP-o2WQ8qHZT I know component or rgb is on this board someplace. The real question here is how I can get S-Video AND composite without having it on a switch. Anyone interested in kits for various systems check out: http://atariage.com/forums/topic/255584-mod-kits-for-various-use/ Quote Link to comment Share on other sites More sharing options...
