Lewis2907 Posted October 28, 2016 Share Posted October 28, 2016 (edited) Bb Team, I am trying to get this program to work correctly. Basically I am trying to duplicate the Original Mario style. Meaning when you jump you land on the next platform / block. When you moving left / right and hit a block you bounce back (smooth of bouncy style would work, but smooth is the preferred way). When your jumping and moving / gliding left or right you bounce back off a block, currently your get stuck. Thanks if your are able to help me with this. I have just started to work on a game with a 100 level / rooms. It should be interesting if I can pull it off, thanks. I forgot to say that I have seen several jump style codes that work well (but take up a lot of space and variables). I am trying to compress it to save space for the other items I have in mind, thanks. Jump Test.txt Test.bas.bin Edited October 28, 2016 by Lewis2907 1 Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 29, 2016 Share Posted October 29, 2016 Have you looked at this: atariage.com/forums/topic/179473-fake-gravity-platformer-test/ I haven't updated the code yet to the new style I'm using now, so the code is a little crappy. Quote Link to comment Share on other sites More sharing options...
Lewis2907 Posted October 29, 2016 Author Share Posted October 29, 2016 RT, Yea. That is my back up plan if I can't get it done with this code. DPC has those limitations. The game I want to make next will have a 100 rooms. Probably not as solid as the other games I have seen, but it would be fun and interesting to see if I can pull it off. Quote Link to comment Share on other sites More sharing options...
Lewis2907 Posted October 29, 2016 Author Share Posted October 29, 2016 I forgot I know this is not in dpc, but I did a plug a play into dpc and it works, just not the way I want it, thanks. Quote Link to comment Share on other sites More sharing options...
Lewis2907 Posted November 2, 2016 Author Share Posted November 2, 2016 (edited) Bb Team, This is what I have so far as a "Simple Jump Program for DPC+". Could be worked on some more to make it more smooth. I did use a lot of RT code to get it to work. It does get stuck and will run across the gaps. Maybe someone can assist with the portions that I get stuck in and running across and not falling down. The gaps does provide some interesting game variations. I am trying to save as much space as I can as I plan to make some with several rooms to play / explore. Thanks for any assistance I can get one this portion so I can move on with this game, thanks. Test.bas.bin Jump Test 1 Nov 16.txt Edited November 2, 2016 by Lewis2907 Quote Link to comment Share on other sites More sharing options...
