Scott_B Posted October 30, 2016 Share Posted October 30, 2016 I'm trying to make a simple game thing in visual bb but noooo In z26 and Stella it's just a black screen. am I stupid or what because I have NO idea gamestart MainLoop player0color: $40 $40 $40 $40 $40 $00 $06 $06 $02 end motorbike player0: %11100000111 %10101110101 %11101000111 %00011101000 %00000101000 %00011010000 %00000010000 %00001111100 %00001000100 end player player1: %000001100 %000001000 %000001000 %000001000 %001110000 %001000000 %011111000 %010100000 %011100000 end pfheights: 8 8 8 8 8 8 8 8 8 8 8 end pfcolors: $9C $9A $8A $88 $74 $72 $C4 $C2 $C0 $00 $00 end playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXX XXXXXXXXXXXXXXXXXXXXXXXXX..XXXXX XXXXXXXXXXXXXXXXXXXXXXXX...XXXXX XXXXXXXXXXXXXXXXXXXXXX.....XXXXX XXXXXXXXXXXXXXXXXXX........XXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end set tv ntsc set kernel multisprite pfscorecolor = $26 set romsize 4k set smartbranching on AUDV0 = 6 AUDC0 = 2 AUDF0 = 7 player0x=0 player0y=0 player1x=player0x player1y=player1x if joy0left then player0x=player0x-1:if player0x<10 then player0x=10 if joy0right then player0x=player0x+1:if player0x>137 then player0x=137 if joy0up then player0y=player0y-1:if player0y<7 then player0y=7 if joy0down then player0y=player0y+1:if player0y>99 then player0y=99 drawscreen goto MainLoop Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted October 30, 2016 Share Posted October 30, 2016 See if these links are helpful: Parts of a Program Example Programs Quote Link to comment Share on other sites More sharing options...
bogax Posted October 30, 2016 Share Posted October 30, 2016 here I've rearranged your code to be more to my liking I moved the kernel options and such to the first thing I removed the multisprite kernel, it doesn't have the options I added player1colors to the kernel options I swapped player0 and player1 'cause player1 has the colors option I turned on the pfscore bar(s) I intialized the left score bar I moved the (setup) stuff that you don't need in the mainloop in to a subroutine at the end I initialized the player0 and player1 locations to where they'd be visible when the game starts I put the player0 and player1 location intialization all on the same line because they're all getting intialized to the same value and it will save time and space (in that case) if they're all (consecutively) on the same line I added actual rem statements to what I took to be rem statements I did not fix player0 to follow player1 don't know what I might have messed up (eg not sure what you had in mind) set tv ntsc set kernel_options player1colors pfcolors pfheights set romsize 4k set smartbranching on const pfscore = 1 rem gamestart gosub setup MainLoop if joy0left then player1x=player1x-1:if player1x<10 then player1x=10 if joy0right then player1x=player1x+1:if player1x>137 then player1x=137 if joy0up then player1y=player1y-1:if player1y<7 then player1y=7 if joy0down then player1y=player1y+1:if player1y>99 then player1y=99 drawscreen goto MainLoop setup pfscorecolor = $26 : pfscore1 = %11111111 player0x = 32 : player0y = 32 : player1x = 32 : player1y = 32 AUDV0 = 6 AUDC0 = 2 AUDF0 = 7 player1color: $40 $40 $40 $40 $40 $00 $06 $06 $02 end rem motorbike player1: %11100000111 %10101110101 %11101000111 %00011101000 %00000101000 %00011010000 %00000010000 %00001111100 %00001000100 end rem player player0: %000001100 %000001000 %000001000 %000001000 %001110000 %001000000 %011111000 %010100000 %011100000 end pfheights: 8 8 8 8 8 8 8 8 8 8 8 end pfcolors: $9C $9A $8A $88 $74 $72 $C4 $C2 $C0 $00 $00 end playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXX XXXXXXXXXXXXXXXXXXXXXXXXX..XXXXX XXXXXXXXXXXXXXXXXXXXXXXX...XXXXX XXXXXXXXXXXXXXXXXXXXXX.....XXXXX XXXXXXXXXXXXXXXXXXX........XXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end return Quote Link to comment Share on other sites More sharing options...
