New language to program Atari 2600
sunofman
Hi!
This is my first post here.
​I have created a new computer language, that makes 6502 code. ​Before I release it, it would like to test to make a Atari 2600 program.
​But as I don't have time to learn all about 2600 now, I wounder if there is a assembly program I can translate as a example. After that maybe someone would like to test it for writing their own programs. And I can provide the code for that program that i translate, as a programming example.
Does anyone know of some suitable assembly code for this? I worst case I could take some machine code, and translate that.
​Any ideas? And where can I find info about the used fileformat for Atari 2600 emulators?
The Atari is unlike any other system in that the 6507 (6502 compatible) updates the hardware in real time to draw the screen scanline by scanline. Unless you take the time to learn how that works then your new computer language will be worthless for 2600 projects.
I wrote a blog series, Collect that goes over what's involved. The blog lists the entries newest first, so go to the bottom of the 2nd page to start with Let's Make a Game!
Well you don't know if what you say is true. I have written my language, and I know what I have done.
I asked if there is any assembly code that is suitable. If a normal assembler can't be used, then thats ok, I will fix that. My language isn't based on anyone else assembler or C compiler or anything like that. It is a language made from scratch. It translates to 6502 directly.
And 6507 has the same OP codes as 6502, hasn't it? Even if it doesn't than that could be fixed quite easily. And the limited adress space for 6507 isn't a problem. My language does not use a runtime library.
And if some code need to be 100% exact, than that can be fixed also, if I have machinecode to go after.
To as I alread said. I can translte machine code, in worst case.
So if there is a short binary file that is suitable, that would be okey also.
Well, another tought. If I have your permission SpiceWare to use your code, I could translate that to my language.
Are you okay with that?
You can find this where Darrell said to look.
; colorful
; Darrell Spice, Jr
; November 5, 2013
; Simple 2600 program that shows off moving bands of colors
; compile using DASM
; dasm colorful.asm -f3 -v0 -scolorful.sym -lcolorful.lst -ocolorful.bin
; Initialize DASM
; DASM supports a number of processors, this line tells DASM the code
; is for the 6502 CPU. The Atari has a 6507, which is 6502 with an 8K
; address space and no interrupt lines.
PROCESSOR 6502
; vcs.h contains the standard definitions for TIA and RIOT registers
include vcs.h
; macro.h contains commonly used routines which aid in coding
include macro.h
; Define RAM Usage
; define a segment for variables
; .U means uninitialized, does not end up in ROM
SEG.U VARS
; RAM starts at $80
ORG $80
; holds background color for first scanline of frame
BackgroundColor: ds 1 ; stored in $80
; holds playfield color for first scanline of frame
PlayfieldColor: ds 1 ; stored in $81
; holds # of scanlines left for the kernel to draw
LineCount: ds 1 ; stored in $82
; Define Start of Cartridge
; define a segment for code
SEG CODE
; ROM starts at $F000
ORG $F000
; Initialize Atari
InitSystem:
; CLEAN_START is a macro found in macro.h
; it sets all RAM, TIA registers
; and CPU registers to 0
CLEAN_START
; set playfield to show vertical stripes
lda #$AA
sta PF0
sta PF2
lda #$55
sta PF1
; Sync Signal
VerticalSync:
lda #2 ; LoaD Accumulator with 2
sta WSYNC ; STore Accumulator to WSYNC, any value halts CPU until start of next scanline
sta VSYNC ; Accumulator D1=1, turns on Vertical Sync signal
sta VBLANK ; Accumulator D1=1, turns on Vertical Blank signal (image output off)
lda #47
sta TIM64T ; set timer for end of Vertical Blank
sta WSYNC ; 1st scanline of VSYNC
sta WSYNC ; 2nd scanline of VSYNC
lda #0 ; LoaD Accumulator with 0
sta WSYNC ; 3rd scanline of VSYNC
sta VSYNC ; Accumulator D1=0, turns off Vertical Sync signal
; Vertical Blank
VerticalBlank:
; game logic starts here
; update background color for first scanline of this frame
inc BackgroundColor
; update playfield color for first scanline this frame
dec PlayfieldColor
lda #199
sta LineCount
; game logic ends here
VBwait:
sta WSYNC
bit TIMINT
bpl VBwait ; loop until the timer ends
; Kernel
; turn on video output
sta WSYNC
lda #0
sta VBLANK
sta COLUBK ; color first scanline black
sta COLUPF ; color first scanline black
ldx BackgroundColor
ldy PlayfieldColor
; draw the screen
KernelLoop:
sta WSYNC ; wait for start of next scanline
stx COLUBK ; change background color for current scanline
sty COLUPF ; change playfield color for current scanline
inx ; increase X so next scanline has a different background color
iny ; increase Y so next scanline has a different playfield color
dec LineCount ; decrease the line count
bne KernelLoop ; if we didn't hit 0, then draw another scanline
; Overscan
; done drawing the screen
OverScan:
sta WSYNC ; Wait for SYNC (start of next scanline)
sta VBLANK ; STore Accumulator to VBLANK, D1=1 turns image output off
lda #23
sta TIM64T
; additional game logic goes here
OSwait:
sta WSYNC
bit TIMINT
bpl OSwait ; loop until the timer ends
jmp VerticalSync ; start the next frame
; Define End of Cartridge
ORG $FFFA ; set address to 6507 Interrupt Vectors
.WORD InitSystem ; NMI
.WORD InitSystem ; RESET
.WORD InitSystem ; IRQ
Edited by SIO2
Welcome to the forum.
All the Atari games are small. You could probably use any game, but collect is probably the best choice because it is one of the most commented source files you're going to find.
I'm curious to see what new features your language will bring. Could you give an overview of what it supports and what it gains over assembler?
Thanks!
Yes, I could give a overview, and answer questions.
Well it support structured code. And it's a lot easier than assembly. And it's a good language for someone that is familiar with assembly.
And programs would be a lot smaller than assembly programs, without loosing functionality.
My brother translated a C64 assembly program with raster graphics. And that program started on the first try, without rewrite. And that was his first program in that language. So it's extremely easy language if you know assembly. And it's easy to convert assembly programs to this language.
So in some ways it's easier than C coding, and easier than assembly. It's more low level than C. And programs are more compact than c code, and assembly code.
And I could also integrates specific functionality in this language, so It's also more hi level than C. A bit like basic, with performance almost almost on pair with assembly. So if there is corner cases, or special syntax for easier programming, than I could make that if people would use it.
It is also easy to write timing specific code. I could write a table, how much data and cycles everything takes later if someone is interested.
I've been coding for the 6502 since the early 80s. I learned machine language by hand assembling code (as I didn't have an assembler), putting the results into data statements, poking it into memory, then running it on my Vic 20.
I became involved with Stella in the mid 90s when I ported it to run on OS/2.
Two of my 2600 homebrews are in the best sellers list.
etc. So yes, I'm fairly familiar with the inner workings of the 2600 :)
Feel free to use Collect for your tests. As ZackAttack points out, you're unlikely to find anything as commented as that, I wrote it specifically to be a tutorial so put in way more comments that I usually would. The code SIO2 pointed out is in colorful.zip
Yes.
Sounds promising. My biggest complaint with assembly is how difficult it is to fail at compile time. Well that and the massive amounts of macros needed to make decent code.
The Atari is very resource constrained. You may need to include either the ability to link with assembled binaries or inline assembly for the most timing critical parts. Typically this would be the display kernel(s).
I could translate some code segments, starting with this...
; Define RAM Usage
SEG.U VARS
; RAM starts at $80
ORG $80
That code would look like this...
Define RAM Usage
80: < RAM starts at $80 >
BackgroundColor:80 < holds background color for first scanline of frame >
PlayfieldColor:81 < holds playfield color for first scanline of frame >
LineCount:82 < holds # of scanlines left for the kernel to draw >
; Define RAM Usage
SEG.U VARS
; RAM starts at $80
ORG $80
Define RAM Usage
Well it would be written even shorter ...
Define RAM Usage
...that would be more correct code using my language. You don't need to set origin in this case.
Here is another translation of this assembly...
SEG CODE
ORG $F000
to this code...
F000: < ROM starts at $F000 >
; Sync Signal
VerticalSync:
lda #47
That would be translated to...
Sync Signal
VerticalSync:
#2 =WSYNC =VSYNC =VBLANC < turn on Vertical Sync and Vertical Blanc signal >
#47.0 =TIM64T =WSYNC =WSYNC < first and second scanline of VSYNC >
#0 =WSYNC =VSYNC < third scanline, and turn of Vertical Sync signal >
What type of macros is needed to make decent code for 2600 and why?
Well you can inline assembly and binary data and mashine code in this language.
OK!
Now I have managed to compile a binary identical program to Collect in my language.
But there is some minor things that I have to fix, before it's usable as a Language for Atari 2600. I had to patch the program with some in-line machine code.
I don't now how the code works, but I guess I will learn something along the way.
Even if I don't don't know how Atari 2600 works, it will still be useful for 2600 projects.
If I can use it without knowing anything, maybe it will be useful for someone who actually know how to program the Atari 2600.
OK!
The meat of any 2600 project is the graphics kernel. Most of the time is taken up by manually drawing the screen. So, without that sorted out there's little benefit over straight assembly.
That doesn't mean I think your effort are in vain! I just think that maybe another 650x system would be a better fit. Perhaps you could target the NES and use an available graphics/io library.
The Atari 2600 already has 2 high level languages (bB and vwBASIC). Besides C you'd be the only game in town for the NES.
Does any one know, why the empty part of the ROM file is filled with $FF ?
In my ROM generated in my language, the empty part of the ROM is filled with $00 and is fully working in stella.
But I can change the empty filling to $FF if it's a problem when writing Atari 2600 programs.
Otherwise, that rom is identical to Collect ROM file.
At the moment, the program converted to my language is mostly translated to my language. But some instructions is in-line assembly.
And there is one instruction type that is still machine code (relative BEQ and BNE), that should be fixed so it can use my language syntax with 100% efficiency, like it was hand-coded assembly. But I will fix that sooner or later.
What is the reason why DASM is used to write Atari 2600 programs? Is there some special functionality in it that is needed?
I'm thinking of making a feature to disassemble Atari 2600 roms, and be able to recompile them immediately and start converting and modifying. I already have a disassembler half made. And it can probably be fixed to it uses real names for hardware registers automatically if i spend a little time on it.
Ok! what parts is the graphics kernel? I have already converted the Collect program, doesn't that have a graphics kernel. I use the exact the same variable names and label names as the Collect program. What more programs has to be converted to get a full graphics kernel?
Ok thanks for the advise on NES, I will tackle that later. But I will fix Atari 2600 first I guess. I used to play on it back in the early 80s, and later on i played games on c64, vic20 and NES and Lynx. So I will probably fix them also. But I think I will do things chronologically, so maybe Atari 800 is the next stop.
Define RAM Usage
I would not want to use that method. When RAM usage is defined like this:
        ORG $80
Player1X:   ds 1
Player1Y:   ds 1
Player2X:   ds 1
Player2Y:   ds 1
Shot1X:     ds 1
Shot1Y:     ds 1
Shot2X:     ds 1
Shot2Y:     ds 1
Score:      ds 3
If you later decide to start using 16 bit values for subpixel positioning you'd just do this:
        ORG $80
Player1X:   ds 2
Player1Y:   ds 2
Player2X:   ds 2
Player2Y:   ds 2
Shot1X:     ds 2
Shot1Y:     ds 2
Shot2X:     ds 2
Shot2Y:     ds 2
Score:      ds 3
With your method you'd have to go to each and every variable you've defined and manually update where in RAM they are located. That's a tedious, and very error prone, thing to do.
Yes, in Collect I list out where the variables end up in RAM; however, that's only in the comments, and only because it's a tutorial where I don't expect people to already know that's how RAM usage gets assigned.
Fill value doesn't matter
That's like asking why most people use Windows based computers - people use dasm because most of the existing 2600 source code is in the format used by dasm. There have been investigations into replacing dasm, such as this one in 2011, but they've gone nowhere.
Covered in Step 1 - Generate a Stable Display
        ORG $80
Player1X:   ds 1
Player1Y:   ds 1
Player2X:   ds 1
Player2Y:   ds 1
Shot1X:     ds 1
Shot1Y:     ds 1
Shot2X:     ds 1
Shot2Y:     ds 1
Score:      ds 3
        ORG $80
Player1X:   ds 2
Player1Y:   ds 2
Player2X:   ds 2
Player2Y:   ds 2
Shot1X:     ds 2
Shot1Y:     ds 2
Shot2X:     ds 2
Shot2Y:     ds 2
Score:      ds 3
I agree on that. It was just some hasty translation, without much thought. I have support for what you talk about, it's quite essential.
Well then I already has support for the graphics kernel, I have tested to write that code, and it worked.
So there isn't anything specific that is needed for Atari 2600 support, more than a efficient compiler on pair with assembly.
Is there anything I have missed?
A bit curious, is there a C compiler that is efficient enough to write programs to Atari 2600?
The biggest thing is going to be, for the display kernel, the ability for the programmer to have EXACT control over the timings of everything. For a game of any complexity, you need to carefully work out exactly when each machine instruction runs, which involves carefully counting the cycles of each instruction. Any language that abstracts that away is not going to work for the kernel. So to make your language viable, one of the following will probably have to be true:
1. Your language is meant to be used just in the game logic, and the programmers will still plan to use assembly for the kernel
2. Your language is just a different syntax but logically is just a different mapping of source to machine code. (ie like how different assemblers may have slightly different syntax)
3. You include pre-written display kernels (like batari basic) and your users will just use one of yours.
