ZillaRUSH Posted November 7, 2016 Share Posted November 7, 2016 I ordered the Super Pro Baseball...as it is only board/PCB and I have no experience with putting such a board into a cart shell. 1) What is the best way to take apart an old cart? 2) How do I secure the board into the Cart shell? 3) Seal up the cart shell? Thanks in advance! Pete Quote Link to comment Share on other sites More sharing options...
mthompson Posted November 7, 2016 Share Posted November 7, 2016 The best option is to use a shell that has screws holding the cover on. Remove those, lift off the cover, and replace the old board with the new. It just drops in and is held in place by some locator notches. Be sure to orient it correctly, with the chips facing down as you're looking at the open shell. It's possible to install it upside down, and that wouldn't be good. If you've got only a cartridge that's glued shut, all is not lost. I have pried them open carefully with reasonable success using a utility knife. Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted November 7, 2016 Share Posted November 7, 2016 Use a shell with screws. Two Philips screws. Simply remove the two screws and take off the "door" Lift the edge of the existing board that's away from the end you insert into the console These things are rugged, so don't be afraid to wiggle the board around a bit to get it to come out - it won't be tough When putting the new board in, keep the chips in the same orientation as the original board had them The board likely has screw holes that will line up the same way as the original board Then just put the cover and two screws back in! Quote Link to comment Share on other sites More sharing options...
ZillaRUSH Posted November 7, 2016 Author Share Posted November 7, 2016 Excellent...thanks! Sounds easy...whew! Can't wait for SPB to arrive! Quote Link to comment Share on other sites More sharing options...
+5-11under Posted November 7, 2016 Share Posted November 7, 2016 Be sure to orient it correctly, with the chips facing down as you're looking at the open shell. It's possible to install it upside down, and that wouldn't be good. When putting the new board in, keep the chips in the same orientation as the original board had them Yep. The chips should be on the side with the label. When put into the Intellivision console, the chips will be facing up. Quote Link to comment Share on other sites More sharing options...
Eric7100 Posted November 7, 2016 Share Posted November 7, 2016 Just do what I do... send your "problems" to Rev, and have him do all the work for you. Quote Link to comment Share on other sites More sharing options...
+Rev Posted November 8, 2016 Share Posted November 8, 2016 Just do what I do... send your "problems" to Rev, and have him do all the work for you. Ummm. No 1 Quote Link to comment Share on other sites More sharing options...
+intellivotion Posted November 8, 2016 Share Posted November 8, 2016 Just do what I do... send your "problems" to Rev, and have him do all the work for you. hey man, no child labour allowed around here! 1 Quote Link to comment Share on other sites More sharing options...
+Rev Posted November 8, 2016 Share Posted November 8, 2016 Use a shell with screws. Two Philips screws. Simply remove the two screws and take off the "door" Lift the edge of the existing board that's away from the end you insert into the console These things are rugged, so don't be afraid to wiggle the board around a bit to get it to come out - it won't be tough When putting the new board in, keep the chips in the same orientation as the original board had them The board likely has screw holes that will line up the same way as the original board Then just put the cover and two screws back in! You should be writing porn movie scripts. Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted November 8, 2016 Share Posted November 8, 2016 You should be writing porn movie scripts. You should have seen the original. Quote Link to comment Share on other sites More sharing options...
ZillaRUSH Posted November 8, 2016 Author Share Posted November 8, 2016 The porn is "Space C*nt, the Movie" Quote Link to comment Share on other sites More sharing options...
JasonlikesINTV Posted November 12, 2016 Share Posted November 12, 2016 (edited) I'll add a few suggestions. Use the exact same screws that you removed from the donor shell. I've seen two types of screws used for Mattel shells - narrow threaded and wider threaded. If you remove one type, but replace with the other type you may mess up the female threaded plastic inside the shell. Eventually it will crack and break. Ever hear that rattling sound inside of some carts? Speaking of which, don't overtighten the screws. I also take advantage of the opened shell to do some Spring cleaning to remove dust. Also, if the screws are rusty, wipe them down with a little WD-40 to clean off some of that oxidation. Good luck! Edited November 12, 2016 by JasonlikesINTV Quote Link to comment Share on other sites More sharing options...
m-crew Posted November 12, 2016 Share Posted November 12, 2016 I hope mine arrive soon, I would like to be screwing off and on soon too.. lol Quote Link to comment Share on other sites More sharing options...
ZillaRUSH Posted November 12, 2016 Author Share Posted November 12, 2016 Do we know when its shipping? Quote Link to comment Share on other sites More sharing options...
+intellivotion Posted November 15, 2016 Share Posted November 15, 2016 I suggest to be ready with your screwdrivers 1 Quote Link to comment Share on other sites More sharing options...
m-crew Posted November 15, 2016 Share Posted November 15, 2016 I suggest to be ready with your screwdrivers Born Ready!!!! Lol Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted November 15, 2016 Share Posted November 15, 2016 Do we know when its shipping? I got shipping notification two days ago! Quote Link to comment Share on other sites More sharing options...
ZillaRUSH Posted November 15, 2016 Author Share Posted November 15, 2016 I did as well....hope to have it up and running this weekend! Super pumped...cant wait to have that fast pitching. That means no stealing easily. Diff game. Quote Link to comment Share on other sites More sharing options...
+BBWW Posted November 15, 2016 Share Posted November 15, 2016 To think some of use have done this hundreds of times and others 1000's of times is amazing. Quote Link to comment Share on other sites More sharing options...
m-crew Posted November 15, 2016 Share Posted November 15, 2016 To think some of use have done this hundreds of times and others 1000's of times is amazing. Consider yourselves lucky , some people don't even do "this "once. lol Quote Link to comment Share on other sites More sharing options...
ZillaRUSH Posted November 18, 2016 Author Share Posted November 18, 2016 Recvd my Super Pro Baseball yesterday....used a Boxing cart shell....perfect fit. Thanks all for the details everyone. Popped it in...played for a few mins. Fantastic!!! Will play fully after work today. That pitching is fast!! Love it! Baseball was one of my fav games as a kid....we had leagues. I still play All Star Baseball often. Super Pro Baseball looks to be a step up. Will give you all my full review tomorrow. 3 Quote Link to comment Share on other sites More sharing options...
Eric7100 Posted November 18, 2016 Share Posted November 18, 2016 Recvd my Super Pro Baseball yesterday....used a Boxing cart shell....perfect fit. Thanks all for the details everyone. Popped it in...played for a few mins. Fantastic!!! Will play fully after work today. That pitching is fast!! Love it! Baseball was one of my fav games as a kid....we had leagues. I still play All Star Baseball often. Super Pro Baseball looks to be a step up. Will give you all my full review tomorrow. Didn't you also order the other game? Quote Link to comment Share on other sites More sharing options...
ZillaRUSH Posted November 18, 2016 Author Share Posted November 18, 2016 Only ordered baseball. Just played my first game....whew...def toughest baseball game. On All-Star Baseball...you hit and steal easily every time. This game is tougher to steal...2nd base is somewhat easy, but third is tough. Fast pitching is very cool. I realized if you pitch slow...the hits don't go as far for the visitors. Fast pitches get hammered. The big difference I see so far is that you better know how to play defense....especially the outfield. I had a learning curve in the first two innings and gave up 10 runs. Lost my first game (pic attached). Visitors win. Challenging....which is good. Will see if I can win one this weekend. Quote Link to comment Share on other sites More sharing options...
ZillaRUSH Posted November 19, 2016 Author Share Posted November 19, 2016 Third game...finally got a win!! 14-13. Def one awesome challenging baseball game. Visitors are tough!! Have yet to complete a 1-2-3 inning. Your fielding skills are put to the limit. Kudos Intelligentvision!! 2 Quote Link to comment Share on other sites More sharing options...
+intellivotion Posted November 19, 2016 Share Posted November 19, 2016 (...) Visitors are tough!! (...)I've always thought that Visitors are tough thanks for sharing your first impression of the game 1 Quote Link to comment Share on other sites More sharing options...
